TSI10L200CW
Taiwan Semiconductor
10A, 200V Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ high efficiency
High forward surge capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
200
V
IFSM
100
A
TJ MAX
150
°C
2
Package
TO-262 (I PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
2
Case: TO-262 (I PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: As marked
Weight: 1.60g (approximately)
2
TO-262 (I PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSI10H200CW
UNIT
TSI10H200CW
Repetitive peak reverse voltage
VRRM
200
V
Reverse voltage, total rms value
VR(RMS)
140
V
IF
10
A
IFSM
100
A
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Forward current
Surge peak forward current, 8.3ms single half sine wave
superimposed on rated load
Critical rate of rise of off-state voltage
1
Version: B2104
TSI10L200CW
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 5A, TJ = 25°C
Forward voltage per diode
IF = 10A, TJ = 25°C
(1)
IF = 5A, TJ = 125°C
VF
IF = 10A, TJ = 125°C
Reverse current @ rated VR per diode
(2)
TJ = 25°C
TJ = 125°C
IR
TYP
MAX
UNIT
0.84
0.90
V
0.92
0.98
V
0.72
0.78
V
0.80
0.86
V
50
µA
5
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE
TSI10L200CW
PACKAGE
2
TO-262 (I PAK)
2
PACKING
50 / Tube
Version: B2104
TSI10L200CW
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
10
CAPACITANCE (pF)
8
6
4
100
2
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
10
TJ=150°C
0.1
TJ=125°C
0.01
TJ=100°C
0.001
0.0001
TJ=25°C
0.00001
10
40
50
60
70
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
80
90 100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
100 10
10
1
0.1
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
(A)
AVERAGE FORWARD CURRENT (A)
12
TJ=100°C
1
TJ=25°C
0.01
0.1
0.001
0.2
0.3
Pulse width 300μs
1% duty cycle
Pulse width
0.4
0.4
0.5
0.6
0.6
0.8
0.7
0.8
1.0
0.9
1.2
1
1.1
FORWARD VOLTAGE (V)
3
Version: B2104
1.2
TSI10L200CW
PACKAGE OUTLINE DIMENSIONS
2
TO-262 (I PAK)
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: B2104
TSI10L200CW
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: B2104
很抱歉,暂时无法提供与“TSI10L200CW C0G”相匹配的价格&库存,您可以联系我们找货
