GP1601 – GP1607
Taiwan Semiconductor
16A, 50V - 1000V Standard Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High current capability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
50 - 1000
V
IFSM
150
A
TJ MAX
150
°C
Package
TO-220AB
Configuration
Dual dies
● DC to DC converters
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.82g (approximately)
TO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
GP
GP
GP
PARAMETER
SYMBOL
1601 1602 1603
GP
GP
GP
Marking code on the device
1601
1602
1603
Repetitive peak reverse voltage
VRRM
50
100
200
Reverse voltage, total rms value
VR(RMS)
35
70
140
GP
1604
GP
1604
400
GP
1605
GP
1605
600
GP
1606
GP
1606
800
280
420
560
GP
UNIT
1607
GP
1607
1000
V
700
V
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Junction temperature
IF
16
A
IFSM
150
A
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: G2104
GP1601 – GP1607
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
Reverse current @ rated VR per diode
Junction capacitance per diode
IF = 8A, TJ = 25°C
(2)
TJ = 25°C
SYMBOL
TYP
MAX
UNIT
VF
1.1
V
10
µA
250
µA
50
pF
IR
TJ = 125°C
1MHz, VR = 4.0V
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
GP16x
TO-220AB
50 / Tube
GP16xH
TO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 50V(GP1601) to 1000V(GP1607)
2. “H” means AEC-Q101 qualified
2
Version: G2104
GP1601 – GP1607
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
16
CAPACITANCE (pF)
12
8
100
10
4
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
1
150
10
CASE TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
100 10
10
UF1DLW
1
TJ=125°C
TJ=25°C
0.1
1
0.01
0.1
0.001
0.6
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.8
0.4
1.0
0.5
1.2
1.4
0.6
0.7
0.8
1.6
0.9
1.8
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
175
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: G2104
1.2
GP1601 – GP1607
PACKAGE OUTLINE DIMENSIONS
TO-220AB
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: G2104
GP1601 – GP1607
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: G2104
很抱歉,暂时无法提供与“GP1601 C0G”相匹配的价格&库存,您可以联系我们找货
