MBR2035CT – MBR20200CT
Taiwan Semiconductor
20A, 35V - 200V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
PARAMETER
VALUE
UNIT
IF
A
VRRM
35 - 200
V
IFSM
150
A
TJ MAX
150
°C
Package
TO-220AB
Configuration
Dual dies
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.88g (approximately)
TO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
MBR
2035
CT
MBR
2035
CT
MBR
2045
CT
MBR
2045
CT
MBR
2050
CT
MBR
2050
CT
MBR
2060
CT
MBR
2060
CT
VRRM
35
45
50
60
90
100
150
200
V
VR(RMS)
24
31
35
42
63
70
105
140
V
SYMBOL
Marking code on the
device
Repetitive peak
reverse voltage
Reverse voltage, total
rms value
Forward current
Surge peak forward
current, 8.3ms single
half sine wave
superimposed on rated
load
Peak repetitive reverse
(1)
surge current
Peak repetitive forward
current (Rated VR,
Square wave, 20KHz)
MBR MBR MBR MBR
2090 20100 20150 20200 UNIT
CT
CT
CT
CT
MBR
MBR
MBR
MBR
CT
CT
CT
CT
IF
A
IFSM
150
A
IRRM
1
0.5
IFRM
A
A
Version: M2104
MBR MBR MBR MBR MBR MBR MBR MBR
2035
2045 2050 2060 2090 20100 20150 20200 UNIT
PARAMETER
SYMBOL
CT
CT
CT
CT
CT
CT
CT
CT
Critical rate of rise of offdv/dt
10,000
V/μs
state voltage
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Notes:
1. tp = 2.0μs, 1.0KHz
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
1
°C/W
RӨJC
2
°C/W
MBR2035CT
MBR2045CT
MBR2050CT
MBR2060CT
MBR2090CT
MBR20100CT
MBR20150CT
MBR20200CT
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per
(1)
diode
CONDITIONS
MBR2035CT
MBR2045CT
MBR2050CT
MBR2060CT
MBR2090CT
MBR20100CT
MBR20150CT
MBR20200CT
MBR2035CT
MBR2045CT
MBR2050CT
MBR2060CT
MBR2090CT
MBR20100CT
MBR20150CT
MBR20200CT
MBR2035CT
MBR2045CT
MBR2050CT
MBR2060CT
MBR2090CT
MBR20100CT
MBR20150CT
MBR20200CT
MBR2035CT
MBR2045CT
MBR2050CT
MBR2060CT
MBR2090CT
MBR20100CT
MBR20150CT
MBR20200CT
SYMBOL
TYP
MAX
UNIT
V
0.80
V
0.85
V
0.99
V
0.84
V
0.95
V
1.23
V
0.57
V
0.70
V
0.75
V
0.87
V
0.72
V
0.85
V
1.10
V
IF = 10A, TJ = 25°C
IF = 20A, TJ = 25°C
VF
IF = 10A, TJ = 125°C
IF = 20A, TJ = 125°C
2
Version: M2104
PARAMETER
Reverse current @ rated VR
(2)
per diode
CONDITIONS
MBR2035CT
MBR2045CT
MBR2050CT
MBR2060CT
MBR2090CT
MBR20100CT
MBR20150CT
MBR20200CT
MBR2035CT
MBR2045CT
MBR2050CT
MBR2060CT
MBR2090CT
MBR20100CT
MBR20150CT
MBR20200CT
SYMBOL
TJ = 25°C
TYP
MAX
UNIT
100
µA
15
mA
10
mA
5
mA
0.15
mA
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBR20xCT
TO-220AB
50 / Tube
MBR20xCTH
TO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBR2035CT) to 200V(MBR20200CT)
2. “H” means AEC-Q101 qualified
3
Version: M2104
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
15
10
MBR2035CT - 2045CT
1000
MBR2050CT - 20200CT
5
f=1.0MHz
Vsig=50mVp-p
100
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
1
TJ=75°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100 10
10
1
TUF1DLW
J=125°C
TJ=125°C
0.1
0.01
0.1
0.001
0.0
TJ=25°C
TJ=25°C
2035CT-2045CT
2050CT-2060CT
2090CT-20100CT
20150CT-20200CT
1
Pulse width 300μs
1% duty cycle
Pulse width
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.2
0.4
0.6
0.4
0.5
0.6
0.8
0.7
1.0
0.8
1.2
0.9
1.4
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
1000
100
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
MBR2035CT-2045CT
MBR2050CT-20100CT
MBR20150CT-20200CT
10
(A)
AVERAGE FORWARD CURRENT (A)
25
8.3ms single half sine wave
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: M2104
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: M2104
PACKAGE OUTLINE DIMENSIONS
TO-220AB
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: M2104
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: M2104
很抱歉,暂时无法提供与“MBR2035CTHC0G”相匹配的价格&库存,您可以联系我们找货
