GHSE-19-100-A-02-10-S 数据手册
For use in:
Factory Automation
PLC Position Feedback
Test and Measurement
Packaging Equipment
GHS-19 Series
Spring-Loaded LVIT Linear Position Sensor
Low Cost, Compact, High Performance Gaging Probes
The GHS-19 series of LVIT (Linear Variable Inductance Transducer) spring-loaded position sensors by Alliance
Sensors Group are contactless devices designed for dimensional measurements in QA labs, or position
measuring applications in factory automation systems and in various industrial and commercial applications,
such as: automotive testing, mil/aero test stands, robotic arms, and packaging equipment. An ideal solution for
when the sensing element cannot be attached to the object being measured. GHS-19s are offered in nominal full
scale ranges from 6.4 to 100 mm (0.25 to 4.0 inches) with excellent resolution and high stroke-to-length ratios.
The maximum tip contact force on the item being measured is 1 pound.
GHS-19 sensors have a 0.75 inch (19 mm) diameter aluminum or stainless steel body with a 1/2-20 UNF-2A
thread 1.5 inches (38 mm) long with two 19 mm (0.75 inch) hex jam nuts for drop-in installation in place of a
spring-loaded DC-LVDT gage head. These sensors utilize a probe equipped with a No. 9 contact tip, and are
offered with a PT02-10-6P (6-pin) connector. Operating from a variety of DC voltages. These sensors are
available with a choice of one of four analog outputs. They all include ASG's proprietary Senset™ field
recalibration feature.
Features:
Spring-loaded LVIT Technology™ (Linear Variable Inductance Transducer)
Contactless operation prevents internal wearout from dithering or rapid cycling
Excellent stroke-to-length ratio
Proprietary SenSet™ field adjustable range scaling
Specifications:
Analog I/Os: 0-5 V or 0.5-4.5 V output with 8 -30 V input, 35 mA max.
0-10 V output with 12-30 V input, 35 mA max.
4-20 mA (3-wire) output with 18-30 V input, 60 mA max (75 C max).
Measuring Ranges: 6.4 to 100 mm (0.25 to 4.0 inches) Full Scale (nominal)
Linearity Error: ± 0.15% of FSO typical, ± 0.25% of FSO max
Resolution: 0.025% of FSO
Operating Temperature: -20 to 85 C (-40 to 105 C extended temperature range)
Temperature Coefficient:
GHSE-19-100-A-02-10-S 价格&库存
很抱歉,暂时无法提供与“GHSE-19-100-A-02-10-S”相匹配的价格&库存,您可以联系我们找货
