rev.
page
1 of 5
date
01/2009
DESCRIPTION: modular incremental encoder
PART NUMBER: LME
The LME Series are high performance, low cost, 3 channel optical incremental encoders. Each encoder contains a LED
source, an integrated circuit with detectors and circuitry, and an optical disc which rotates between the emitter and
detector IC. These encoders can be quickly and easily mounted to a motor.
ELECTRICAL SPECIFICATIONS
output waveform
output signals
current consumption
output phase difference
supply voltage
output resolution (ppr)
frequency response
output current
Square wave
A, B, Z phase
≤ 60 mA
90° ± 45°
5 V dc
1000, 1024, 2000, 2048
(other resolutions available upon request)
0~100 KHz
0~5 mA
MECHANICAL SPECIFICATIONS
6.0x10-8 kgm2
980 m/s2 ,6ms, 2 times each on XYZ
50 m/s2 ,10~200 Hz, 2 hours each on XYZ
MTBF ≥ 5000h(+25°C, 2000rpm)
25g (with 0.5 meter cable)
rotor inertia of code-wheel
shock resistance
vibration proof
working life
weight
ENVIRONMENTAL SPECIFICATIONS
operating temp
storage temp
humidity
protection
-25° to +85° C
-40° to +85° C
30~85% no condensation
IP50
ORDERING INSTRUCTIONS
LME - XXXXX - XXXXXX
Resolution:
1000 = 1000 PPR
1024 = 1024 PPR
2000 = 2000 PPR
2048 = 2048 PPR
Output type:
D = line driver 26LS31
V = voltage
Bore type:
“blank” = standard
T = thru bore
Bore size:
600 = 6mm
635 = 6.35mm (1/4”)
800 = 8mm
1000 = 10mm
1400 = 14mm
1900 = 19mm
2000 = 20mm
"blank" = no kit
K = kit (Digi-Key only):
contains encoder,
centering tool, and
Allen wrench
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383
rev.
page
2 of 5
date
01/2009
PART NUMBER: LME
OUTPUT WAVEFORM
T(TD)
X
X2
X3
•Square-wave accuracy:
X4
•Pitch error of period:
•Pitch error of phase position:
•Z phase:
•Period of pulses:
•Signal accuracy:
A
B
X1 +X2 = 1/2T ± 1/12T
X3 +X4 = 1/2T ± 1/12T
±0.01T
≤ 1/18T
Tz=1/4T (1T, 1/2T, 1/4T...)
T=360° /N (N: output pulses)
Xn=1/4T ± 1/12T (n=1, 2, 3, 4)
A leads B clockwise when viewing the encoder shaft end.
The position of Z phase against A, B phase is not specified.
Z
Tz
T
X1
Voltage output
VCC
20Ω
X2
A
Output
B
0V
Z
Tz
Line driver output
T
H
Q
AM26LS31
OUT A
L
OUT A
H
L
Q
X1
Q = A.B.Z
Q = A.B.Z
X2
H
OUT B
L
OUT B
H
L
H
OUT Z
L
OUT Z
H
Tz
L
rev.
PART NUMBER: LME
page
3 of 5
date
01/2009
INSTALLATION DRAWING
REV.
A
56.0 2.205
DESCRIPTION
NEW DRAWING
17.0 0.669
A
DATE
4/15/2008
46.0 1.811
0.05
2.0 0.079
3.3 0.130
(2 PLCS)
CODE
WHEEL
25.91 1.020
B
66.0 2.597
24.38 0.960
2.4 0.094
(2 PLCS)
3.0 0.118
A
30.0 1.181
SECTION A-A
500.0 19.685
5.0 0.197
RoHS
3.0 0.118
(8 PLCS)
ØB
(bore size)
6mm
6.35mm
8mm
10mm
14mm
19mm
LME - STANDARD BORE COPYRIGHT 2008
BY CUI INC.
20050 SW 112th Ave.
Tualatin, OR 97062
Phone: 503-612-2300
800-275-4899
Fax: 503-612-2383
Website: www.cui.com
TOLERANCE:
±0.3mm UNLESS OTHERWISE
SPECIFIED
-0.00
+0.033
20mm
PC FILE NAME:
SCALE 1:2
tolerance
Cable Code
Cable Color
Line Driver Output
Cable Code
Cable Color
Voltage Output
1
Black
0V
1
Black
0V
2
Red
Vcc
2
Yellow
Z
3
Green
A
3
Green
A
4
Brown
_
A
4
Red
Vcc
5
White
B
5
White
B
6
Grey
_
B
7
Yellow
Z
8
Orange
_
Z
TITLE:
LME - MODULAR OPTICAL ENCODER
PART NO.
LME - STANDARD BORE
DRAWN BY:
ZRJ
APPROVED BY:
UNITS:
REV:
A
MM [INCHES]
SCALE:
1:1
REV.
A
THRU HOLE VERSION
56.0 2.205
DESCRIPTION
NEW DRAWING
17.0 0.669
A
DATE
4/15/2008
46.0 1.811
0.05
2.0 0.079
A
CODE
WHEEL
3.3 0.130
(2 PLCS)
25.91 1.020
B
66.0 2.597
24.38 0.960
2.4 0.094
(2 PLCS)
3.0 0.118
A
30.0 1.181
SECTION A-A
500.0 19.685
5.0 0.197
RoHS
3.0 0.118
(8 PLCS)
ØA
(case opening)
ØB
(bore size)
11mm
15mm
20mm
6mm
6.35mm
8mm
10mm
14mm
19mm
21mm
20mm
10mm
SCALE 1:2
tolerance
-0.00
+0.033
PC FILE NAME:
LME-THROUGH BORE COPYRIGHT 2009
BY CUI INC.
20050 SW 112th Ave.
Tualatin, OR 97062
Phone: 503-612-2300
800-275-4899
Fax: 503-612-2383
TOLERANCE:
SPECIFIED
Cable Code
Cable Color
Line Driver Output
Cable Code
Cable Color
Voltage Output
1
Black
0V
1
Black
0V
2
Red
Vcc
2
Yellow
Z
3
Green
A
3
Green
A
4
Brown
_
A
4
Red
Vcc
5
White
B
5
White
B
6
Grey
_
B
7
Yellow
Z
8
Orange
_
Z
TITLE:
PART NO.
LME-THROUGH BORE
DRAWN BY:
ZRJ
APPROVED BY:
REV:
A
UNITS:
MM [INCHES]
SCALE:
1:1
很抱歉,暂时无法提供与“LME-2000D-T600K”相匹配的价格&库存,您可以联系我们找货
