BUJD203AD
NPN power transistor with integrated diode
23 July 2018
Product data sheet
1. General description
High voltage, high speed, planar passivated NPN power switching transistor with integrated antiparallel E-C diode in a SOT428 (DPAK) surface-mountable plastic package.
2. Features and benefits
Fast switching
High voltage capability
Integrated anti-parallel E-C diode
Surface mountable package
Very low switching and conduction losses
3. Applications
DC-to-DC converters
Electronic lighting ballasts
Inverters
Motor control systems
4. Pinning information
Table 1. Pinning information
Pin
Symbol Description
1
B
base
2
C
collector[1]
3
E
emitter
mb
C
mounting base; connected to
collector
Simplified outline
C
B
E
sym131
DPAK (SOT428)
[1]
Graphic symbol
it is not possible to make a connection to pin 2 of the SOT428 (DPAK) package
BUJD203AD
WeEn Semiconductors
5. Ordering information
Table 2. Ordering information
Type number
BUJD203AD
BUJD203AD
Product data sheet
Package
Name
Description
Version
DPAK
plastic single-ended surface-mounted package (DPAK); 3 leads
(one lead cropped)
SOT428
All information provided in this document is subject to legal disclaimers.
23 July 2018
WeEn Semiconductors Co., Ltd. 2018. All rights reserved
2 / 13
BUJD203AD
WeEn Semiconductors
6. Limiting values
Table 3. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCESM
collector-emitter peak
voltage
VBE = 0 V
850
V
VCBO
collector-base voltage
IE = 0 A
850
V
VCEO
collector-emitter voltage
IB = 0 A
425
V
IC
collector current
DC; Fig. 1; Fig. 2; Fig. 3
4
A
ICM
peak collector current
8
A
IB
base current
DC
2
A
IBM
peak base current
4
A
Ptot
total power dissipation
80
W
Tstg
storage temperature
-65
150
°C
Tj
junction temperature
150
°C
Tmb ≤ 25 °C; Fig. 4
VCC
001aac000
10
IC
(A)
LC
VCL(CE)
probe point
8
IBon
VBB
6
LB
DUT
001aab999
4
Fig. 2. Test circuit for reverse bias safe operating area
2
400
600
800
1000
VCEclamp (V)
Fig. 1. Reverse bias safe operating area
BUJD203AD
Product data sheet
23 July 2018
3 / 13
BUJD203AD
WeEn Semiconductors
001aac001
102
IC
(A)
duty cycle = 0.01
10
ICM(max)
IC(max)
II(3)
(1)
1
tp = 20 µs
50 µs
100 µs
200 µs
500 µs
DC
(2)
10- 1
I(3)
10- 2
III(3)
10- 3
1
102
10
VCEclamp (V)
103
1)Ptot maximum and Ptot peak maximum lines
2)Second breakdown limits
3) I = Region of permissable DC operation
II = Extension for repetitive pulse operation
III = Extension during turn-on in single transistor converters
provided that RBE ≤ 100 Ω and tp ≤ 0.6 μs
Fig. 3. Forward bias safe operating area for Tmb ≤ 25 °C
001aab993
120
Pder
80
40
80
120
Tmb (°C)
160
Fig. 4. Normalized total power dissipation as a function of mounting base temperature
BUJD203AD
Product data sheet
23 July 2018
4 / 13
BUJD203AD
WeEn Semiconductors
7. Thermal characteristics
Table 4. Thermal characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
Fig. 5
1.56
K/W
Rth(j-a)
thermal resistance
from junction to
ambient free air
printed circuit board (FR4) mounted;
minimum footprint; Fig. 6
75
K/W
001aab998
10
Zth(j-mb)
(K/W)
1
δ = 0.5
0.2
0.1
10- 1
0.05
0.02
Ptot
δ=
tp
T
0.01
tp
10- 2
10- 5
10- 4
10- 3
10- 2
10- 1
1
t
T
tp (s)
10
Fig. 5. Transient thermal impedance from junction to mounting base as a function of pulse width
7.0
7.0
1.5
2.15
2.5
4.57
001aab021
Fig. 6. Minimum footprint SOT428
BUJD203AD
Product data sheet
23 July 2018
5 / 13
BUJD203AD
WeEn Semiconductors
8. Characteristics
Table 5. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Static characteristics
collector-emitter cut-off VBE = 0 V; VCE = 850 V; Tj = 125 °C
current (base shorted)
VBE = 0 V; VCE = 850 V; Tj = 25 °C
[1]
2
mA
[1]
1
mA
ICBO
collector-base cut-off
current (emitter open)
VCB = 850 V; IE = 0 A
[1]
1
mA
ICEO
collector-emitter cut-off VCE = 425 V; IB = 0 A
current (base open)
[1]
0.1
mA
IEBO
emitter-base cut-off
VEB = 7 V; IC = 0 A
current (collector open)
10
mA
VCEOsus
collector-emitter
sustaining voltage
(base open)
IB = 0 A; IC = 10 mA; LC = 25 mH;
Fig. 7; Fig. 8
400
450
V
VCEsat
collector-emitter
saturation voltage
IC = 3 A; IB = 0.6 A; Fig. 9; Fig. 10
0.29
1
V
VBEsat
base-emitter saturation IC = 3 A; IB = 0.6 A; Fig. 11
voltage
0.99
1.5
V
VF
forward voltage
IF = 2 A; Tj = 25 °C
1.04
1.5
V
hFE
DC current gain
IC = 1 mA; VCE = 5 V; Tmb = 25 °C;
Fig. 12
10
15
32
IC = 500 mA; VCE = 5 V; Tmb = 25 °C;
Fig. 12
13
21
32
IC = 2 A; VCE = 5 V; Tmb = 25 °C;
Fig. 12
11
16
22
IC = 3 A; VCE = 5 V; Tmb = 25 °C;
Fig. 12
12.5
IC = 2.5 A; IBon = 0.5 A; IBoff = -0.5 A;
RL = 75 Ω; Tj = 25 °C; resistive load;
Fig. 13; Fig. 14
0.52
0.6
µs
2.7
3.3
µs
IC = 2 A; IBon = 0.4 A; VBB = -5 V;
LB = 1 µH; Tj = 25 °C; inductive load;
Fig. 15; Fig. 16
1.2
1.4
µs
LB = 1 µH; Tj = 100 °C; inductive load;
Fig. 15; Fig. 16
1.8
µs
RL = 75 Ω; resistive load; Fig. 13;
Fig. 14
0.3
0.35
µs
LB = 1 µH; inductive load; Fig. 15;
Fig. 16
0.12
µs
0.03
0.06
µs
ICES
Dynamic characteristics
ton
turn-on time
ts
storage time
tf
[1]
fall time
Measured with half-sine wave voltage (curve tracer)
BUJD203AD
Product data sheet
23 July 2018
6 / 13
BUJD203AD
WeEn Semiconductors
IC
(mA)
50 V
100 Ω to 200 Ω
horizontal
oscilloscope
250
vertical
6V
300 Ω
1Ω
100
30 Hz to 60 Hz
001aab987
10
Fig. 7. Test circuit for collector-emitter sustaining
voltage
min
VCE (V)
VCEOsus
001aab988
Fig. 8. Oscilloscope display for collector-emitter
sustaining voltage test waveform
001aab995
2.0
VCEsat
(V)
1.6
IC = 1 A
2A 3A
001aab997
VCEsat
(V) 0.5
4A
0.4
1.2
0.3
0.8
0.2
0.4
0.1
10- 1
1
IB (A)
10
Fig. 9. Collector-emitter saturation voltage as a function
of base current; typical values
BUJD203AD
Product data sheet
1
IC (A)
10
Fig. 10. Collector-emitter saturation voltage as a
function of collector current; typical values
23 July 2018
7 / 13
BUJD203AD
WeEn Semiconductors
001aab996
1.4
VBEsat
(V)
1.2
001aab994
102
Tj = 25 °C
hFE
1.0
VCE = 5 V
0.8
10
1V
0.6
0.4
0.2
1
IC (A)
1
10- 2
10
Fig. 11. Base-emitter saturation voltage as a function of
VIM
RB
1
10
IC (A)
Fig. 12. DC current gain as a function of collector
IC
VCC
RL
10- 1
ICon
90 %
90 %
DUT
10 %
tp
T
001aab989
IB
ts
ton
tf
t
toff
IBon
Fig. 13. Test circuit for resistive load switching
10 %
t
tr ≤ 30 ns
- IBoff
001aab990
Fig. 14. Switching times waveforms for resistive load
BUJD203AD
Product data sheet
23 July 2018
8 / 13
BUJD203AD
WeEn Semiconductors
VCC
IC
ICon
90 %
LC
IBon
VBB
LB
DUT
001aab991
10 %
Fig. 15. Test circuit for inductive load switching
IB
tf
ts
toff
t
IBon
t
- IBoff
001aab992
Fig. 16. Switching times waveforms for inductive load
BUJD203AD
Product data sheet
23 July 2018
9 / 13
BUJD203AD
WeEn Semiconductors
9. Package outline
Fig. 17. Package outline DPAK (SOT428)
BUJD203AD
Product data sheet
23 July 2018
10 / 13
BUJD203AD
WeEn Semiconductors
Right to make changes — WeEn Semiconductors reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
10. Legal information
Suitability for use — WeEn Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical
or safety-critical systems or equipment, nor in applications where failure
or malfunction of an WeEn Semiconductors product can reasonably
be expected to result in personal injury, death or severe property or
environmental damage. WeEn Semiconductors and its suppliers accept no
liability for inclusion and/or use of WeEn Semiconductors products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. WeEn Semiconductors makes
no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.ween-semi.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. WeEn Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local WeEn
Semiconductors sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
WeEn Semiconductors and its customer, unless WeEn Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the WeEn Semiconductors product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, WeEn Semiconductors does not
give any representations or warranties, expressed or implied, as to the
accuracy or completeness of such information and shall have no liability for
the consequences of use of such information. WeEn Semiconductors takes
no responsibility for the content in this document if provided by an information
source outside of WeEn Semiconductors.
In no event shall WeEn Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, WeEn Semiconductors’ aggregate and cumulative liability
towards customer for the products described herein shall be limited in
accordance with the Terms and conditions of commercial sale of WeEn
Semiconductors.
BUJD203AD
Product data sheet
Customers are responsible for the design and operation of their applications
and products using WeEn Semiconductors products, and WeEn
Semiconductors accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the WeEn Semiconductors product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
WeEn Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using WeEn
Semiconductors products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). WeEn does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific WeEn Semiconductors product is automotive
qualified, the product is not suitable for automotive use. It is neither qualified
nor tested in accordance with automotive testing or application requirements.
WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without WeEn Semiconductors’ warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
WeEn Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies WeEn Semiconductors for
any liability, damages or failed product claims resulting from customer
design and use of the product for automotive applications beyond WeEn
Semiconductors’ standard warranty and WeEn Semiconductors’ product
specifications.
23 July 2018
11 / 13
BUJD203AD
WeEn Semiconductors
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
BUJD203AD
Product data sheet
23 July 2018
12 / 13
BUJD203AD
WeEn Semiconductors
11. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Pinning information......................................................1
5. Ordering information....................................................2
6. Limiting values............................................................. 3
7. Thermal characteristics............................................... 5
8. Characteristics..............................................................6
9. Package outline.......................................................... 10
10. Legal information..................................................... 11
For more information, please visit: http://www.ween-semi.com
For sales office addresses, please send an email to: salesaddresses@ween-semi.com
Date of release: 23 July 2018
BUJD203AD
Product data sheet
23 July 2018
13 / 13
