10BQ015
Surface Mount Schottky Barrier Rectifiers
Features
SMB/DO-214AA
Schottky barrier rectifier
Guardring protection
Low forward voltage
Reverse energy tested
High current capability
Extremely low thermal resistance
0.180(4.57)
0.160(4.06)
0.086(2.20)
0.077(1.95)
0.155(3.94)
0.130(3.30)
0.209(5.30)
0.201(5.10)
Mechanical Data
0.012(0.30)
0.006(0.15)
0.096(2.44)
0.084(2.13)
Case: SMB molded plastic body
Polarity: Color band denotes cathode end
Mounting position: ANY
Weight: 0.003 ounces, 0.093 gram
1111
0.059(1.50)
0.035(0.90)
0.008(0.20)
0.002(0.05)
Dimensions in inches and(millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
10BQ015
UNITS
Maximum repetitive peak reverse voltage
VRRM
15
V
Maximum RMS voltage
VRWS
10
V
Maximum DC blocking voltage
VDC
15
V
Maximum average forward rectified current at
TL=90
IF(AV)
1.0
A
Peak forward surge current 8.3ms single
half-sine-wave
IFSM
40
A
Maximum instantaneous forward voltage
at I FM=1.0A (NOTE1)
VF
0.32
V
Maximum DC reverse current
TJ=25
at rated DC blocking voltage TJ=125
Maximum thermal resistance
Operating temperature range
Storage temperature range
IR
R
JL
0.2
6.0
28
mA
o
C/W
TJ
-55 ---- +150
o
C
TSTG
-55 ---- +150
o
C
NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 %
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
10BQ015
Ratings AND Charactieristic Curves
1.0
FIG.2-- PEAK FORWARD SURGE CURRENT
PEAK FORWARD SURGE
CURRENT,AMPERES
CURRENT,AMPERES
FIG.1 -- FORWARD DERATING CURVE
Resistive or
inductive Load
0.5
P.C.B.MOUNTED ON
0.2X0.2(5.0X5.0mm)
COPPERPAD AREAS
60
70 80
90 100 110 120 130 140 150 160 170
40
LEAD TEMPERATURE
SS12B-SS14B
10
Pulse Width=300
1%DUTY CYCLE
S
0 .1
0 .2
0 .4
0 .6
0 .8
1 .0
1 .2
1 .4
1 .6
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
10 0
100
10
TJ=125℃
1
0.1
T J=25℃
SS12B-SS16B
0.01
0.001
60
80
1 00
PERCENT OF RATED PEAK REVERSE VOLTAGE,
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMB
3000/REEL
48000
36X35.8X36.5
12.00
11.00
ht t p : //
10
FIG.4 -- TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE
CURRENT,MICRO AMPERES
CURRENT,AMPERES
50
0 .0 1
NUMBER OF CYCLES AT 60Hz
FIG.3 -- TYPICAL FORWARD CHARACTERISTICS
1
O
TL=100 C
8 .3 m s S in g le H a lf S in e -W a v e
(J E D E C M e th o d )
www.lgesemi .c o m
很抱歉,暂时无法提供与“10BQ015”相匹配的价格&库存,您可以联系我们找货
