SD103AX
SD103AX
    HOTTECH(合科泰)
    SOD-523
    SD103AX
SD103AX 数据手册
SD103AX SCHOTTKY BARRIER DIODE FEATURES  Low Forward Voltage  Low Reverse Recovery Time  Low Reverse Capacitance  Guard Ring Construction for Transient Protection SOD-523 MECHANICAL DATA      Case: SOD-523 Case Material: Molded Plastic. UL lammability Classification Rating: 94V-0 Moisture Sensitivity: Level 1 per J-STD-020 Weight: 0.0015 grams (approximate) MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Parameter Symbol Value Unit 40 V Reverse Voltage VR Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM RMS Reverse Voltage VR(RMS) 28 V Non-Repetitive Peak Forward Surge Current @ t = 8.3 ms IFSM 2 A Forward Continuous Current IFM 350 mA Power Dissipation PD 150 mW Thermal Resistance From Junction To Ambient RθJA 667 °C/W Junction Temperature TJ 125 °C Storage Temperature TSTG -55 ~+150 °C ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified) Parameter Reverse voltage Forward voltage Symbol Min V(BR) 40 VF Reverse voltage IR Total capacitance Reverse recovery time Ctot tRR ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD Type Max 0.60 0.37 Unit V V 0.32 0.27 1 2 5 50 10 uA uA uA pF ns Conditions IR=100uA IF=200mA IF=20mA IF=5mA IF=1mA VR=10V VR=20V VR=30V VR=0V,f=1MHz IF=IR=200mA, Irr=0.1×IR, RL=100Ω E-mail:hkt@heketai.com 1/4 SD103AX SCHOTTKY BARRIER DIODE Typical Characteristics Forward 1000 Characteristics Reverse 1000 Characteristics (uA) Ta=100℃ 100 REVERSE CURRENT IR FORWARD CURRENT IF (mA) Ta=100℃ Ta=25℃ 10 100 10 Ta=25℃ 1 1 100 200 400 300 FORWARD VOLTAGE VF 500 0.1 600 10 20 40 30 REVERSE VOLTAGE (mV) Capacitance Characteristics 50 0 VR (V) Power Derating Curve 200 Ta=25℃ (mW) 150 PD POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) f=1MHz 40 30 20 100 50 10 0 0 5 10 15 REVERSE VOLTAGE 20 VR 25 (V) ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD 30 0 0 25 50 75 AMBIENT TEMPERATURE E-mail:hkt@heketai.com 100 Ta 125 (℃ ) 2/4 SD103AX SCHOTTKY BARRIER DIODE SOD-523 Package Outline Dimensions Symbol Dimensions In Millimeters Dimensions In Inches Min. Max. Min. Max. A 0.510 0.770 0.020 0.031 A1 0.010 0.070 0.001 0.003 A2 0.500 0.700 0.020 0.028 b 0.250 0.350 0.010 0.014 c 0.080 0.150 0.003 0.006 D 0.750 0.850 0.030 0.033 E 1.100 1.300 0.043 0.051 E1 1.500 1.700 0.059 0.067 L 0.200 RE F 0.008 REF L1 0.250 0.400 0.010 0.016 θ 0° 8° 0° 8° SOD-523 Suggested Pad Layout Note: 1.Controlling dimension: in millimeters 2.General tolerance: ±0.05mm 3.The pad layout is for reference purposes only ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 3/4 SD103AX SCHOTTKY BARRIER DIODE SOD-523 Tape and Reel SOD-523 Embossed Carrier Tape DIMENSIONS ARE IN MILLIMETER TYPE A B C d E F P0 P P1 W SOD-523 0.90 1.94 0.73 Ø1.50 1.75 3.50 4.00 2.00 2.00 8.00 TOLERANCE ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 SOD-523 Tape Leader and Trailer SOD-523 Reel DIMENSIONS ARE IN MILLIMETER REEL OPTION 7’’ DIA TOLERANCE D D1 D2 G H I W1 W2 Ø178 54.40 13.00 R78 R25.60 R6.50 9.50 12.30 ±2 ±1 ±1 ±1 ±1 ±1 ±1 ±1 ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 4/4
SD103AX 价格&库存
很抱歉,暂时无法提供与“SD103AX”相匹配的价格&库存,您可以联系我们找货
