MMBT3906(2A)
MMBT3906(2A)
    ST(先科)
    MMBT3906(2A)
MMBT3906(2A) 数据手册
MMBT3906 PNP Silicon General Purpose Transistor for switching and amplifier applications. As complementary types the NPN transistors MMBT3904 is recommended. TO-236 Plastic Package Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Collector Base Voltage -VCBO 40 V Collector Emitter Voltage -VCEO 40 V Emitter Base Voltage -VEBO 6 V Collector Current -IC 200 mA Power Dissipation Ptot 350 mW Tj 150 O Tstg - 55 to + 150 O Junction Temperature Storage Temperature Range C C SEMTECH ELECTRONICS LTD. ® Dated : 16/03/2015 Rev: 01 MMBT3906 Characteristics at Ta = 25 OC Parameter Symbol Min. Max. Unit hFE hFE hFE hFE hFE 60 80 100 60 30 300 - - -ICBO - 50 nA -IEBO - 50 nA -V(BR)CBO 40 - V -V(BR)CEO 40 - V -V(BR)EBO 6 - V -VCE(sat) -VCE(sat) - 0.25 0.4 V V -VBE(sat) -VBE(sat) 0.65 - 0.85 0.95 V V fT 250 - MHz Cobo - 4.5 pF Delay Time at -VCC = 3 V, -VBE = 0.5 V, -IC = 10 mA, -IB1 = 1 mA td - 35 ns Rise Time at -VCC = 3 V, -VBE = 0.5 V, -IC = 10 mA, -IB1 = 1 mA tr - 35 ns Storage Time at -VCC = 3 V, -IC = 10 mA, -IB1 = IB2 = 1 mA ts - 225 ns Fall Time at -VCC = 3 V, -IC = 10 mA, -IB1 = IB2 = 1 mA tf - 75 ns DC Current Gain at -VCE = 1 V, -IC = 0.1 mA at -VCE = 1 V, -IC = 1 mA at -VCE = 1 V, -IC = 10 mA at -VCE = 1 V, -IC = 50 mA at -VCE = 1 V, -IC = 100 mA Collector Base Cutoff Current at -VCB = 30 V Emitter Base Cutoff Current at -VEB = 6 V Collector Base Breakdown Voltage at -IC = 10 µA Collector Emitter Breakdown Voltage at -IC = 1 mA Emitter Base Breakdown Voltage at -IE = 10 µA Collector Emitter Saturation Voltage at -IC = 10 mA, -IB =1 mA at -IC = 50 mA, -IB = 5 mA Base Emitter Saturation Voltage at -IC = 10 mA, -IB = 1 mA at -IC = 50 mA, -IB = 5 mA Current Gain Bandwidth Product at -VCE = 20 V, -IC = 10 mA, f = 100 MHz Output Capacitance at -VCB = 5 V, IE = 0, f = 1 MHz SEMTECH ELECTRONICS LTD. ® Dated : 16/03/2015 Rev: 01 MMBT3906 Power Dissipation vs Ambient Temperature Power Dissipation: Ptot (mW) 300 250 200 150 100 50 0 0 25 50 75 125 100 150 Ambient Temperature: Ta ( C) O SEMTECH ELECTRONICS LTD. ® Dated : 16/03/2015 Rev: 01
MMBT3906(2A) 价格&库存
很抱歉,暂时无法提供与“MMBT3906(2A)”相匹配的价格&库存,您可以联系我们找货
MMBT3906(2A)
  • 20+0.11200
  • 100+0.09240
  • 300+0.05980
  • 800+0.04870
  • 3000+0.03300
库存:54546
