KBP2005G
THRU
KBP210G
Technical Data
Data Sheet N1746, Rev. A
KBP2005G THRU KBP210G
SINGLE PHASE 2.0AMP GLASS PASSIVATED BRIDGE RECTIFIER
Features
Glass passivated die construction
Low forward voltage drop
High current capability
High surge current capability
Plastic material-UL flammability 94V-0
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
KBP
Circuit Diagram
Mechanical Data
Case: KBP, molded plastic
Terminals: plated leads solderable per MIL-STD-202,
Method 208
Polarity: as marked on case
Mounting position: Any
Lead Free: For RoHS / Lead Free Version
Maximum Ratings: @TA=25°C unless otherwise specified
Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Symbol
KBP
2005G
KBP
201G
KBP
202G
KBP
204G
KBP
206G
KBP
208G
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
50
100
200
400
600
800
1000
V
RMS Reverse Voltage
VRMS
35
70
140
280
420
560
700
V
Type number
Average Rectified Output Current
@ TA=50℃
Peak forward surge current 8.3ms single half
sine-wave superimposed on rated load (JEDEC
Method)
KBP
Units
210G
Io
2.0
A
IFSM
60
A
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
KBP2005G
THRU
KBP210G
Technical Data
Electrical Characteristics:
Type Number
Symbol
KBP
2005G
KBP
201G
KBP
202G
KBP
204G
KBP
206G
KBP
208G
KBP
Units
210G
Forward Voltage per element @IF=2.0A
VF
1.1
V
Peak Reverse Current @TA=25℃
At Rated DC Blocking Voltage @TA=125℃
IR
5.0
500
µA
* Pulse width < 300 µs, duty cycle < 2%
Thermal-Mechanical Specifications:
Type Number
Typical Thermal Resistance Junction to Ambient
(Note 1)
Typical Thermal Resistance Junction to Lead
(Note 1)
Junction Temperature
Storage Temperature Range
Approximate Weight
Symbol
KBP
2005G
KBP
201G
KBP
202G
KBP
204G
KBP
206G
KBP
208G
KBP
Units
210G
RθJA
25
RθJL
8
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
wt
1.4
g
Case Style
KBP
Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad.
Ratings and Characteristics Curves
°C/W
KBP2005G
THRU
KBP210G
Technical Data
Ordering Information
Device
Package
Plating
Shipping
KBP(Pb-Free)
Pure Sn
35pcs / tube
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging
specification.
KBP2005G
THRU
KBP210G
Technical Data
Mechanical Dimensions KBP (Inches/Millimeters)
Tube Specification
Marking Diagram
Where XXXXX is YYWWL
SSG
YY
WW
L
KBP206G
= SSG
= Year
= Week
= Lot Number
= Type Number
Cautions:Molding resin
Epoxy resin UL:94V-0
KBP2005G
THRU
KBP210G
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations.
很抱歉,暂时无法提供与“KBP208G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.45671
- 10+1.20734
- 35+1.10042
