FDN338P
P-Ch 20V Fast Switching MOSFETs
Description
Product Summary
The FDN338P is the high cell density trenched Pch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The FDN338P meet the RoHS and Green Product
requirement with full function reliability approved.
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
VDS
-20
V
RDS(ON),typ
89
mΩ
ID
-3
A
SOT23 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-20
V
VGS
Gate-Source Voltage
±12
V
ID@TA=25℃
Continuous Drain Current, VGS @ -4.5V1
-3
A
ID@TA=70℃
-2.4
A
IDM
Pulsed Drain Current2
-12
A
PD@TA=25℃
Total Power Dissipation3
1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
RθJC
www.hs-semi.cn
Typ.
Max.
Unit
Thermal Resistance Junction-ambient 1
125
℃/W
Thermal Resistance Junction-Case1
80
℃/W
Ver 2.0
1
FDN338P
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-20
V
VGS=-4.5V , ID=-3A
89
100
VGS=-2.5V , ID=-2A
130
140
VGS=VDS , ID =-250uA
-0.3
-0.5
-1.0
VDS=-16V , VGS=0V , TJ=25℃
-1
VDS=-16V , VGS=0V , TJ=55℃
-5
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
12.2
S
Qg
Total Gate Charge (-4.5V)
10.1
Qgs
Gate-Source Charge
1.21
Qgd
Gate-Drain Charge
2.46
VDS=-15V , VGS=-4.5V , ID=-3A
nC
5.6
Rise Time
VDD=-10V , VGS=-4.5V , RG=3.3
32.2
Turn-Off Delay Time
ID=-3A
45.6
Fall Time
29.2
Ciss
Input Capacitance
677
Coss
Output Capacitance
82
Crss
Reverse Transfer Capacitance
73
Min.
Typ.
Max.
Unit
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Conditions
Continuous Source Current1,4
VG=VD=0V , Force Current
-3
A
Diode Forward Voltage2
VGS=0V , IS=-1A , TJ=25℃
-1
V
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
FDN338P
Typical Characteristics
12
VGS=-5V
VGS=-4.5V
-ID Drain Current (A)
10
VGS=-3V
8
VGS=-2.5V
6
VGS=-1.8V
4
2
1
1.5
-VDS , Drain-to-Source Voltage (V)
2
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
10
-IS Source Current(A)
8
6
TJ=150℃
TJ=25℃
4
2
0.8
1.2
-VSD , Source-to-Drain Voltage (V)
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
1.8
Normalized On Resistance
1.8
Normalized VGS(th)
1.4
1.4
1
1.0
0.6
0.6
0.2
0.2
-50
100
150
TJ ,Junction Temperature (℃ )
100
150
TJ , Junction Temperature (℃)
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
-50
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
FDN338P
1000
100.00
Ciss
100us
-ID (A)
Capacitance (pF)
10.00
Coss
100
10ms
1.00
100ms
Crss
1s
0.10
TA=25℃
Single Pulse
F=1.0MHz
10
DC
0.01
1
5
9
13
17
-VDS , Drain to Source Voltage (V)
21
0.1
1
Fig.7 Capacitance
10
-VDS (V)
100
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TA + PDM x RθJA
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.0
4
FDN338P
Ordering Information
Part Number
FDN338P
www.hs-semi.cn
Package code
SOT-23
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“FDN338P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.26882
- 100+0.21517
- 300+0.18834
- 3000+0.16822
- 6000+0.15212
