DSS32 THRU DSS36
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 60 Volts
Forward Current - 3.0 Ampere
SOD-123FL
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.8± 0.2
1.0±0.2
Cathode Band
Top View
1.3± 0.15
0.10-0.30
2.8±0.2
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical thermal resistance (NOTE 1)
Operating junction temperature range
Storage temperature range
SYMBOLS
DSS32
D32
DSS33
D33
DSS34
D34
DSS35
D35
DSS36
D36
UNITS
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
60
42
60
I(AV)
3.0
VOLTS
VOLTS
VOLTS
Amp
IFSM
80.0
Amps
VF
IR
RθJA
TJ
TSTG
0.52
0.55
0.70
Volts
0.5
20.0
mA
K/W
180
-55 to +125
C
C
-55 to +150
Note:
1.PCB mounted on 0.2*0.2" (5.0*5.0mm) coppeer pad area.
STAR SEA
FIG. 1- FORWARD CURRENT DERATING CURVE
3
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
0.6
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES DSS32 THRU DSS36
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
80
64
48
32
16
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
10
1
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
0.1
DSS32-DSS34
DSS35-DSS36
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
TJ=100 C
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
100
NUMBER OF CYCLES AT 60 Hz
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
STAR SEA
很抱歉,暂时无法提供与“DSS34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46110
- 100+0.38766
- 300+0.35094
- 3000+0.31422
- 6000+0.29219
- 9000+0.28117
