DF13-2630SCFA
DF13-2630SCFA
    HRS(广濑)
    DF13-2630SCFA
DF13-2630SCFA 数据手册
1.25mm Pitch Miniature Crimping Connector (UL Listed) DF13 Series Straight Type Right Angle Type Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Type Mounting Height(h) Mounting Type DIP 5.3mm SMT 5.8mm DIP 3.6mm SMT ■Features Correspond to Automatic Mounting 1. Miniature Size Secure the automatic plain area for the absorption type automatic mounting machine. Designed in the low profile at mounting height 5.8mm. (SMT mounting straight type) (For DIP type, the mounting height is to 5.3mm to the straight and 3.6mm at the right angle) Straight Type Absorption area 2. Multi-contact The double row type achieves the multi-contact up to 40 contacts, and secures 30% higher density in the mounting area, compared with the single row type. 3. Correspond to Automatic Mounting The header provides the grade with the vacuum absorption area, and secures automatic mounting by the embossed tape packaging. In addition, the tube packaging can be selected. (Fig.1) 4. Integral Basic Function Despite Miniature Size The header is designed in a scoop-proof box structure, and completely prevents mis-insertion. In addition, the surface mounting (SMT) header is equipped with the metal fitting to prevent solder peeling. (Fig.1) Metal fitting Right Angle Type Absorption area 5. UL Certifled 6. Glow wire compliance (Compliant with IEC 60695-2-11) ■Applications Note PC, mobile terminal, miniature type business equipment, and other various consumer equipment, including video camera B242 Fig.1 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Product Specifications Specification 1A UL Specification AC 150V Voltage rating UL AC/DC 29.9V Current rating Rating Item Operating Temperature Range : -35 to +85ç (Note 1) Storage Temperature Range : -10 to +60ç (Note 2) Operating Moisture Range : 20 to 80% (Note 3) Storage Moisture Range : 40 to 70% (Note 2) Specification Condition 1.Insulation Resistance 500Mø min. 100V DC 2.Withstanding voltage No flashover or insulation breakdown. 500V AC/1 minute 3.Contact Resistance 30mø max. 100mA Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.Single Insertion/Extraction Force 0.3N (30gf) min., 3N (300gf) max. Measured at the square steel pin of 0.35±0.002mm No electrical discontinuity of 1μs or more 5.Vibration Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 6.Humidity (Steady state) Contact resistance : 30mø max. Insulation resistance : 500Mø min. 96 hours at temperature of 40ç and humidity of 90% to 95% Contact resistance : 30mø max. Insulation resistance : 500Mø min. 7.Temperature Cycle (-55ç : 30 minutes➝ 5 to 35ç : 10 minutes➝ 85ç : 30 minutes➝ 5 to 35ç : 10 minutes) 5 cycles 8.Durability (Mating/un-mating) Contact resistance : 30mø max. Tin plating : 30 cycles Gold plating : 50 cycles No deformation of components affecting performance. 9.Resistance to Soldering heat Flow : 250ç for 10 seconds Manual soldering : 300ç for 3 seconds Reflow : At the recommended temperature profile Manual soldering : 300ç for 3 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3 : Use without condensation on parts. ■UL File No. and Recognition No. UL : E52653 ■Materials/Finish Product Crimping Socket Crimping Contact for Socket Pin Header (Through hole) Pin Header (SMT Single row) Pin Header (SMT Double row) Part Insulator Contact Insulator Contact Insulator Contact Metal Fitting Insulator Contact Metal Fitting Material Polyamide Phosphor copper Polyamide Brass Polyamide Brass Phosphor copper Polyamide Brass Phosphor copper Finish Beige Tin plated or gold plated Beige Tin plated Beige Tin plated or gold plated Tin plated Beige Tin-copper plated or gold plated Tin plated Remarks UL94V-0 UL94V-0 UL94V-0 UL94V-0 - ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Connector DF13 q # - * S - 1.25 C w e r t y q Series Name : DF13 e Number of Contacts t Contact Pitch: 1.25mm w Style Symbol : Blank : With boss r Single row : 2 to 12, 14, 15 y Connection Form / Contact Style. ( A : Without boss r Double row : 10, 20, 30, 40 C : Crimping socket / DSA : Straight through hole C : Without boss r Connector Type DS : Right angle through hole / V : Straight SMT t S : Single row socket / P : Single row pin header H : Right angle SMT t DS : Double row socket / DP : Double row pin header ●Contact DF13 # - 2630 SCF A q w e r q Style Symbol Blank: Standard e Packaging Type SCF : Socket Contact/Reel G: Low insertion / extraction r Plating Type w Applicable Cable Size 2630 : 26 to 30 AWG Blank : Tin plated A : Gold plated 3032 : 30 to 32 AWG B243 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Single Row Socket Photo: Contact insertion Part No. HRS No. No. of Contacts 536-0001-4 DF13-2S-1.25C 2 536-0002-7 DF13-3S-1.25C 3 536-0003-0 DF13-4S-1.25C 4 536-0004-2 DF13-5S-1.25C 5 536-0005-5 DF13-6S-1.25C 6 536-0006-8 DF13-7S-1.25C 7 536-0007-0 DF13-8S-1.25C 8 Note 1. The quantity is delivered per bag (100 A 1.25 2.50 3.75 5.00 6.25 7.50 8.75 pcs.). B RoHS Part No. HRS No. No. of Contacts 4.15 536-0008-3 DF13- 9S-1.25C 9 536-0009-6 5.40 DF13-10S-1.25C 10 6.65 536-0010-5 DF13-11S-1.25C 11 Yes 7.90 536-0011-8 DF13-12S-1.25C 12 9.15 536-0012-0 DF13-13S-1.25C 13 10.40 536-0013-3 DF13-14S-1.25C 14 11.65 536-0014-6 DF13-15S-1.25C 15 If needed, please select and order the products per bag. ■Double Row Socket Photo: Contact insertion state Part No. DF13-10DS-1.25C DF13-20DS-1.25C DF13-30DS-1.25C DF13-40DS-1.25C Note : The quantity B244 Unit : mm HRS No. No. of Contacts A B RoHS 536-0550-2 10 10.40 5.00 536-0555-6 20 16.65 11.25 Yes 536-0560-6 30 22.90 17.50 536-0565-0 40 29.15 23.75 is delivered per bag (100pcs). If needed, please select and order the products per bag. A 10.00 11.25 12.50 13.75 15.00 16.25 17.50 Unit : mm B RoHS 12.90 14.15 15.40 16.65 Yes 17.90 19.15 20.40 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Single Row Straight Pin Header (Through hole) [Specific No.] (**), ** Blank : Tin plated (20) : Tin plated, tube packaging BTube Dimensions 10 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5 ●Board Through-hole Diameter:Ø0.6±0.03 Unit: mm Part No. HRS No. No. of Contacts A B Tube Packaging Quantity RoHS Part No. HRS No. No. of Contacts A B Tube Packaging Quantity RoHS 115 37 DF13-2P-1.25DSA(**) 536-0101-9 ** 2 1.25 4.15 DF13- 9P-1.25DSA(**) 536-0108-8 ** 9 10.00 12.90 89 34 DF13-3P-1.25DSA(**) 536-0102-1 ** 3 2.50 5.40 DF13-10P-1.25DSA(**) 536-0109-0 ** 10 11.25 14.15 72 31 DF13-4P-1.25DSA(**) 536-0103-4 ** 4 3.75 6.65 DF13-11P-1.25DSA(**) 536-0110-0 ** 11 12.50 15.40 61 29 Yes DF13-12P-1.25DSA(**) 536-0111-2 ** Yes DF13-5P-1.25DSA(**) 536-0104-7 ** 5 5.00 7.90 12 13.75 16.65 52 27 DF13-6P-1.25DSA(**) 536-0105-0 ** 6 6.25 9.15 DF13-13P-1.25DSA(**) 536-0112-5 ** 13 15.00 17.90 46 25 DF13-7P-1.25DSA(**) 536-0106-2 ** 7 7.50 10.40 DF13-14P-1.25DSA(**) 536-0113-8 ** 14 16.25 19.15 41 23 DF13-8P-1.25DSA(**) 536-0107-5 ** 8 8.75 11.65 DF13-15P-1.25DSA(**) 536-0114-0 ** 15 17.50 20.40 Note 1. The quantity at the specific No."None" is delivered per bag (100 pcs.). If needed, please select and order the products per bag. Note 2. Order the tube packaging product, multiplying the tube packaging quantity. ■Single Row Right Angle Pin Header (Through hole) [Specific No.] (**), ** (20) : Tin plated tube packaging BTube Dimensions ●Board Through-hole Diameter:Ø0.6±0.03 Part No. HRS No. No. of Contacts A B Tube Packaging Quantity RoHS Part No. 2 1.25 4.15 115 DF13-2P-1.25DS(20) 536-0151-7 20 DF13- 9P-1.25DS(20) 3 2.50 5.40 89 DF13-3P-1.25DS(20) 536-0152-0 20 DF13-10P-1.25DS(20) 4 3.75 6.65 72 DF13-4P-1.25DS(20) 536-0153-2 20 DF13-11P-1.25DS(20) Yes DF13-12P-1.25DS(20) 5 5.00 7.90 61 DF13-5P-1.25DS(20) 536-0154-5 20 6 6.25 9.15 52 DF13-6P-1.25DS(20) 536-0155-8 20 DF13-14P-1.25DS(20) 7 7.50 10.40 46 DF13-7P-1.25DS(20) 536-0156-0 20 DF13-15P-1.25DS(20) 8 8.75 11.65 41 DF13-8P-1.25DS(20) 536-0157-3 20 Note 1.Order the tube packaging product, multiplying the tube packaging quantity. HRS No. No. of Contacts 9 536-0158-6 20 10 536-0159-9 20 11 536-0160-8 20 12 536-0161-0 20 14 536-0163-6 20 15 536-0164-9 20 Unit : mm A B Tube Packaging Quantity RoHS 10.00 12.90 37 11.25 14.15 34 12.50 15.40 31 Yes 13.75 16.65 29 16.25 19.15 25 17.50 20.40 23 B245 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Single Row Straight Pin Header (SMT) ■(Three-Wall/Correspond to Vacuum Absorption) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.8 BPCB mounting pattern B246 Note 1.Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. This pin header is a three-wall type, header has sufficiently large flat areas to allow pick-up with vacuum nozzles of automatic placement equipment. [Specific No.] (**), ** (21) : Tin plated embossed tape packaging (51) : Gold plated embossed tape packaging Unit : mm Part No. HRS No. No. of Contacts A 1.25 2 536-0401-2 ** DF13C- 2P-1.25V(**) 2.50 3 536-0402-5 ** DF13C- 3P-1.25V(**) 3.75 4 536-0403-8 ** DF13C- 4P-1.25V(**) 5.00 5 536-0404-0 ** DF13C- 5P-1.25V(**) 6.25 6 536-0405-3 ** DF13C- 6P-1.25V(**) 7.50 7 536-0406-6 ** DF13C- 7P-1.25V(**) 8.75 8 536-0407-9 ** DF13C- 8P-1.25V(**) 10.00 9 536-0408-1 ** DF13C- 9P-1.25V(**) 11.25 10 536-0409-4 ** DF13C-10P-1.25V(**) 12.50 11 536-0410-3 ** DF13C-11P-1.25V(**) 13.75 12 536-0411-6 ** DF13C-12P-1.25V(**) 16.25 14 536-0413-1 ** DF13C-14P-1.25V(**) 17.50 15 536-0414-4 ** DF13C-15P-1.25V(**) Note 1.Please order the embossed tape packaging product according B C D E F 4.15 5.40 6.65 7.90 9.15 10.40 11.65 12.90 14.15 15.40 16.65 19.15 20.40 7.15 8.40 9.65 10.90 12.15 13.40 14.65 15.90 17.15 18.40 19.65 22.15 23.40 5.65 6.90 8.15 9.40 10.65 11.90 13.15 14.40 15.65 16.90 18.15 20.65 21.90 1.95 3.20 4.45 5.70 6.95 8.20 9.45 10.70 11.95 13.20 14.45 16.95 18.20 2.20 3.45 3.10 4.35 5.60 6.85 8.10 9.35 10.60 11.85 13.10 15.60 16.85 to reel number. (1000pcs/reel) Emboss Width 16 16 24 24 24 24 24 24 24 32 32 32 44 RoHS Yes DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Single Row Right Angle Pin Header (SMT) ■(Four-Wall/Correspond to Vacuum Absorption) 1.8 Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BPCB mounting pattern [Specific No.] (**), ** (21) : Tin plated embossed tape packaging (51) : Gold plated embossed tape packaging Unit : mm Part No. HRS No. No. of Contacts A 1.25 2 536-0301-8 ** DF13A- 2P-1.25H(**) 2.50 3 536-0302-0 ** DF13A- 3P-1.25H(**) 3.75 4 536-0303-3 ** DF13A- 4P-1.25H(**) 5.00 5 536-0304-6 ** DF13A- 5P-1.25H(**) 6.25 6 536-0305-9 ** DF13A- 6P-1.25H(**) 7.50 7 536-0306-1 ** DF13A- 7P-1.25H(**) 8.75 536-0307-4 ** 8 DF13A- 8P-1.25H(**) 10.00 9 536-0308-7 ** DF13A- 9P-1.25H(**) 11.25 10 536-0309-0 ** DF13A-10P-1.25H(**) 12.50 11 536-0310-9 ** DF13A-11P-1.25H(**) 13.75 12 536-0311-1 ** DF13A-12P-1.25H(**) 16.25 14 536-0313-7 ** DF13A-14P-1.25H(**) 17.50 15 536-0314-0 ** DF13A-15P-1.25H(**) Note 1.Please order the embossed tape packaging product according B 4.15 5.40 6.65 7.90 9.15 10.40 11.65 12.90 14.15 15.40 16.65 19.15 20.40 to reel C D Emboss Width 7.15 5.65 16 8.40 6.90 16 9.65 8.15 24 10.90 9.40 24 12.15 10.65 24 13.40 11.90 24 14.65 13.15 24 15.90 14.40 24 17.15 15.65 24 18.40 16.90 32 19.65 18.15 32 22.15 20.65 32 23.40 21.90 44 number. (1000pcs/reel) RoHS Yes B247 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Double Row Straight Pin Header (SMT) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■(Four-Wall/Correspond to Vacuum Absorption) BPCB mounting pattern Note 1. Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. [Specific No.] (**), ** (21) : Tin-copper plated embossed tape packaging (51) : Gold plated embossed tape packaging Unit: mm Spec No. Spec No. Emboss Part No. HRS No. No. of Contacts A B C DF13EA-10DP-1.25V(**) 536-0570-0 10 12.10 5.00 DF13EA-20DP-1.25V(**) 536-0571-0 20 (21) (51) Width 8.70 ✔ ✔ 24 18.35 11.25 14.95 ✔ ✔ 32 44 44 DF13EA-30DP-1.25V(**) 536-0572-0 30 24.60 17.50 21.20 ✔ ✔ DF13EA-40DP-1.25V(**) 536-0573-0 40 30.85 23.75 27.45 – ✔ Note 1. Please order the embossed tape packaging product according to reel number. (1000pcs/reel) Note 2. The absorption cap is attached to the embossed tape packaging product. B248 RoHS Yes DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) ■Crimping Contact wire HRS No. UL styleRecommended Wire size Wire conductor Jacket diameter Packaging Finish RoHS 26AWG 7pieces/φ0.16mm 1061 28AWG 7pieces/φ0.127mm φ0.56 to DF13-2630SCF 536-0300-5 1571 30AWG 7pieces/φ0.1mm φ1.0mm 10,000pcs/reel Tin plating 1061 30AWG 7pieces/φ0.1mm φ0.52 to DF13-3032SCF 536-0299-8 1571 32AWG 7pieces/φ0.08mm φ0.8mm 1061 26AWG 7pieces/φ0.16mm to DF13-2630SCFA(04) 536-0298-5 04 1571 28AWG 7pieces/φ0.127mm φ0.56 φ1.0mm 30AWG 7pieces/φ0.1mm 10,000pcs/reel Gold plating Yes 1061 φ0.52 to DF13-3032SCFA 536-0641-6 00 1571 30AWG 7pieces/φ0.1mm φ0.8mm 32AWG 7pieces/φ0.08mm 1061 26AWG 7pieces/φ0.16mm φ0.56 to DF13G-2630SCF 536-0643-1 Tin plating 1571 28AWG 7pieces/φ0.127mm φ1.0mm 30AWG 7pieces/φ0.1mm 10,000pcs/reel 1061 26AWG 7pieces/φ0.16mm φ0.56 to (Low insertion/extraction) DF13G-2630SCFA 536-0642-9 Gold plating 1571 28AWG 7pieces/φ0.127mm φ1.0mm 30AWG 7pieces/φ0.1mm Note 1. Contact extraction tool : DF-C-PO(B) Note 2. Material used as a conductor of recommended wire is annealed tinned copper wire. Note 3. Please contact your local Hirose sales REP if you plan on using wires other than those listed above. Part No. KDF13G 1 1.5 0.15 BApplicable Crimping Tool Part No. HRS No. AP105-DF13-2630S 901-4531-9 AP105-DF13-3032S Press Main Unit CM-105C Manual Crimping Tool DF13-TB2630HC 901-4552-9 901-0001-0 550-0256-1 0.8 Type 0.5 2 0.9 3.7 3.3 Applicator 7.2 Extraction Tool DF-C-PO(B) 550-0179-2 Applicable Contact DF13-2630SCF/SCFA DF13G-2630SCF/SCFA DF13-3032SCF/SCFA --------------DF13-2630SCF DF13-2630SCF/SCFA DF13G-2630SCF/SCFA DF13-3032SCF/SCFA Note 1. If a trouble has occurred due to other tools, which are not designated by Hirose, Hirose won't guarantee any product. Note 2. The manual crimping tool is used to sequentially cut the reel contact with carrier. Note 3. Please conduct crimping work according to the "Crimping quality standard" and "Crimping condition table". BApplication Pattern Through hole (Single Row Product) SMT (Double Row Product) Right Angle SMT (Single Row Product) Straight Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. KDF13 B249 DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) Nov.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Crimp contact with cable B250 ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. DF13-2630SF 1571 - 26 A 9 - 300 1 2 3 4 5 3 Wire size 1 Part No. of adopted crimping contact 5 Wire color 26 : 26AWG DF13-2630SF : DF13-2630SCF DF13-2630SFA : DF13-2630SCFA(04) 9 : White 4 Crimp position / End processing A : Both end crimped 2 Wire type 1571 : UL1571 6 B : One side crimped without end processing 0 : Black 6 Wire length 300 : 300mm S : One side crimped with striped end processing Part No. DF13-2630SF1571-26A9-300 DF13-2630SFA15711-26A9-300 HRS No. Quantity Finish 536-9001-0 00 100pcs/Pack Tin plating Under development 100pcs/Pack Gold plating Note 1. Bag packaging (100pcs/pack). Order by number of packs. Note 2. Please contact your local sales rep if you plan on using specification other than those listed above. DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed) BEmbossed Carrier Tape Dimensions 5.2±0.15 A−A (1.4) C±0.1 Product name label Ø370±2 B±0.1 A±0.3 Ø21±0.8 A A +2 D 0 (D+6)MAX A   DIRECTION OF UNREELING 0.2 A−A (1.1) 2±0.5 3± 4.1±0.15 0.3±0.1 Ø1 Ø21± (Ø80) A C±0.1 B±0.1 A±0.3 Product name label Ø330±2 2±0.1(A
DF13-2630SCFA 价格&库存
很抱歉,暂时无法提供与“DF13-2630SCFA”相匹配的价格&库存,您可以联系我们找货
DF13-2630SCFA
    • 100+0.25556
    • 1000+0.20696
    • 3000+0.17996
    • 10000+0.15838
    DF13-2630SCFA
      • 10000+0.17160
