VTI7064xxxxx
64Mbit Serial SRAM
Document Title
64Mbit Serial SRAM Specification
Revision History
Revision No.
History
Date
Remark
0.1
Initial Draft
March. 31 2017
Preliminary
1
Vilsion Technology Inc.
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
1.General Description
This document defines “64Mbit Serial SRAM”, which support 1.8v & 3.0V 64Mbit of SPI/QPI (Serial Peripheral
Interface/Quad Peripheral Interface) SRAM device. This RAM is configurable as 1 bit Input and Output separate or 4
bit I/O common interface. All of necessary Refresh operation is taken care by device itself.
Features
-SPI Bus Interface:
SPI compatible
SQI(qual) compatible
20 MHz Clock rate for all mode
-Low-Power CMOS Technology:
Read Current: Max.25mA
Standby Current: Typical 50uA
-Unlimited Read and Write Cycles
-8M x 8-bit Organization & 1Kbytes page size
-High Reliability
-RoHS Compliant
-8 Lead SOIC Package
-Temperature Ranges Supported:
Extended(E):
-25°C to +85°C
Industrial(I):
-40°C to +85°C
Product Family
Part Number
Temperature Ranges
Power Supply
Packages
VTI7064LSME
E
1.6V~2.0V
8pin SOIC
VTI7064LSMI
I
1.6V~2.0V
8pin SOIC
VTI7064MSME
E
2.7V~3.3V
8pin SOIC
VTI7064MSMI
I
2.7V~3.3V
8pin SOIC
2.Pin Description
8pin SOIC 150mil
VDD
#CE
SO/SIO1
SIO3
SIO2
SCLK
VSS
SI/SIO0
2
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
Symbol
Signal Type
SPI Mode
QPI Mode
VDD
Power
Core Power Supply
VSS
Ground
Core Supply Ground
CE#
Input
CLK
Input
Clock Signal
SI/SIO[0]
I/O
Serial Input
I/O[0]
SO/SIO[1]
I/O
Serial Output
I/O[1]
SIO[3:2]
I/O
Chip select signal, Active Low. When CE# input isHigh, memory will be in
Standby state
1
I/O[3:2]
I/O[3:2]
Note:1,Fast read Quad access and Quad Write access in SPI Mode use SIO[3:2].Recommend to pull down to GND if no use of SIO[3:2] in SPI
mode.
3. Power up initialization
All products include an on−chip voltage sensor used to start the self−initialization process. When VDD reaches a
stable level at or above minimum VDD, the device will require 150μs to complete its self−initialization process. From
the beginning of power ramp to the end of the 150μs period, CLK should remain LOW, CE# should remain HIGH
(track VDD within 200mV) and SI/SO/SIO[3:0] should remain LOW.
After the 150us period the device requires initialization command sequence as it’s shown in Figure 2, and then the
device is ready for normal operation.
Figure 1. Power-Up Initialization Timing
Figure 2. Reset command sequence for Device Initialization
3
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
4.Interface Description
4.1 Address Space
All devices are byte−addressable. 64M device is addressed with A[22:0].
4.2 Page Length
Read and write operations are always linear address space. The Linear Burst can cross page boundary as long as
tCEM(max.) is met.
4.3 Drive Strength
The device powers up in 50Ω.
4.4 Power-on Status
The device powers up in SPI Mode.
It is required to have CE# high before beginning any operations.
4.5 Command/Address Latching Truth
The device recognizes the following commands specified by the various input methods
SPI Mode(QE=0)
Command
Code
Cmd
Addr
Wait
Cycle
QPI Mode(QE=1)
DIO
Max Freq.
Cmd
Addr
Wait
Cycle
DIO
Max Freq.
Read
0x03
S
S
S
33
N.A.
N.A.
N.A.
N.A.
N.A.
Fast Read
0x0B
S
S
8
S
104
Q
Q
4
Q
84
Fast Read Quad
0xEB
S
Q
6
Q
104
Q
Q
6
Q
104
Write
0x02
S
S
S
104
Q
Q
Q
104
Quad Write
0x38
S
Q
Q
104
Enter Quad Mode
0x35
S
104
N.A.
N.A.
N.A.
N.A.
N.A.
Exit Quad Mode
0xF5
N.A.
N.A.
N.A.
N.A.
N.A.
Q
104
Reset Enable
0x66
S
104
Q
104
Reset
0x99
S
104
Q
104
Read ID
0x9F
S
S
S
104
N.A.
N.A.
N.A.
N.A.
N.A.
same as 0x02
Remark: S = Serial IO, Q = Quad IO
4.6 Command termination
All All Reads & Writes must be completed by CE# LOW to HIGH. This CK# rising edge is the trigger to terminate
the activated wordline for the read/write and set the device into standby.Not doing so will block internal refresh
perations until the device sees the read/write wordline terminated.Command termination operation is necessary
not only for Reads & Write operation and also any command operation, such as Enter Quad mode command and
Reset commands.
Figure 3
4
Rev.0.1,1/2017
VTI7064xxxxx
5. SPI Mode Operations
64Mbit Serial SRAM
The device powers up into SPI mode by default but can also be switched into QPI mode.
5.1 SPI Read Operations
All read operation, data will be available tACLK after the falling edge of CLK. SPI read operation can be done in three
ways:
1) 0x03: Serial CMD, Serial IO, slow frequency
2) 0x0B: Serial CMD, Serial IO, fast frequency
3) 0xEB: Serial CMD, Quad IO, fast frequency
Figure 4: SPI Read 0x03 (max frequency @ 33MHz)
Figure 5: SPI Fast Read 0x0B (max frequency @ 104MHz)
5
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
Figure 6: SPI Fast Quad Read 0xEB (Max frequency 104Mhz)
5.2 SPI Write Operations
Figure 7: SPI Write 0x02
Figure 8: SPI Quad Write 0x38
6
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
5.3 SPI to QPI Mode Enable Operation
This command switches the device into QPI mode.
Figure 9. Quad Mode Enable 0x35
5.4 SPI Read ID Operation
This command is similar to Fast Read, but without the wait cycles and the device outputs EID value instead of data.
Figure 10 : SPI Read ID 0x9F (available only in SPI mode)
6.QPI Mode Operations
6.1 QPI Read Operations
All read operation, data will be available tACLK after the falling edge of CLK. QPI read operation can be done in one of
two ways:
1) 0x0B : Quad CMD, Quad IO, slow frequency
2) 0xEB : Quad CMD, Quad IO, fast frequency
Figure 11 : QPI Fast Read 0x0B (max frequency 84Mhz)
7
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
Figure 12 : QPI Fast Read 0xEB (max frequency 104Mhz)
6.2 QPI Write Operations
QPI write command can be input as 0x02 or 0x38. It does not matter Clock frequency.
Figure 13 : QPI Write 0x02 or 0x38
6.3 QPI Mode Exit Operation
This command will switch the device back into SPI mode.
Figure 14 : Quad Mode Exit 0xF5 (Only available in QPI mode)
8
Rev.0.1,1/2017
VTI7064xxxxx
7.Reset Operation
64Mbit Serial SRAM
The Reset operation is used as a system (software) reset that puts the device in SPI standby mode which is also the
default mode after power up. This operation consists of two commands: Reset Enable (RSTEN) and Reset (RST).
Figure 15. SPI Reset
Figure 16 : QPI Reset
The Reset operation requires the Reset Enable command followed by the Reset command. Any command other
than the Reset command after the Reset Enable command will disable the Reset Enable procedure.
9
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
8.Input / Output Timing
Figure 17: Input Timing
Figure 18: Output Timing
9.Electrical Specifications:
9.1 Absolute Maximum Ratings
Parameter
Symbol
Rating
Unit
Voltage to any ball except VDD relative to VSS
VT
-0.3 to VDD+0.3
V
Voltage on VDD supply relative to VSS
VDD
-0.2 to +2.45
V
Storage Temperature
TSTG
-55 to +150
°C
Notes
1
Notes 1: Storage temperature refers to the case surface temperature on the center/top side of the SRAM.
2: Exposing the device to stress above those listed in Absolute Maximum Ratings could cause permanent damage. The device is not
meant to be operated under conditions outside the limits described in the operational section of this specification. Exposure to
Absolute Maximum Rating conditions for extended periods may affect device reliability.
9.2 Operating Conditions
Parameter
Min
Max
Unit
Operating Temperature (standard)
-25
+85
°C
10
Notes
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
9.3 DC Characteristics
Symbol
Parameter
VDD
Supply Voltage
VIH
Min
Typ.
Max
Unit
VTI7064Lxx
1.60
1.8
2.0
V
VTI7064Mxx
2.7
3.0
3.3
V
Input high voltage
VDD-0.4
VDD+0.2
V
VIL
Input low voltage
-0.2
0.4
V
VOH
Output high voltage (IOH=-0.2mA)
0.8 VDD
V
VOL
Output low voltage (IOL=+0.2mA)
0.2 VDD
V
ILI
Input leakage current
1
uA
ILO
Output leakage current
1
uA
ICC
Read/Write
25
mA
ISB
Standby current
VTI7064Lxx
50
uA
VTI7064Mxx
60
uA
Notes
9.4 AC Characteristics
Symbol
Min
Max
Unit
CLK period-SPI Read (0x03) @33MHz
30.3
ns
CLK period-QPI Fast Read (0x0B) @84MHz
11.9
ns
CLK period-all other operations @104MHz
9.6
ns
tCH/tCL
Clock high/low width
0.45
0.55
tCLK
tKHKL
CLK rise or fall time
1.5
ns
1
tCLK
tCLK
tCPH
Parameter
CE# HIGH between subsequent burst operations
tCEM
CE# low pulse width
4
μs
tCSP
CE# setup time to CLK rising edge
3
ns
tSP
Setup time to active CLK edge
2.5
ns
tHD
Hold time from active CLK edge
2
ns
tHZ
Chip disable to DQ output high.Z
7
ns
tACLK
CLK to output delay
7
ns
tKOH
Data hold time from clock falling edge
1.5
ns
11
Notes
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
10.Code Information:
V
T
I
X
X
X
X
X
X
X
X
X
X
X
1
2
3
4
5
6
7
8
9
10
11
12
13
14
Digit-No.
Remark
Code
1,2,3
Vilsion Technology Inc. Product
VTI
4
Serial SRAM
7
5,6,7
8
9
10
11
Density
Vcc
Package
Die Version
Temperature range
12
Packing type
13,14
Special function
12
16Mb
016
32Mb
032
64Mb
064
1.8V
L
3.0V
M
3.3V
N
8 SOIC
S
8 TSSOP
T
8 DIP
D
Monther Die
M
2nd Generation
A
3rd Generation
B
-25℃ to 85℃
E
-40℃ to 85℃
I
-40℃ to 125℃
A
Tube
Blank
Tape and Reel
T
TBD
TBD
Rev.0.1,1/2017
VTI7064xxxxx
64Mbit Serial SRAM
11.Package Information
8pin SOIC(150mil)
Symbol
A
A1
b
c
D
E1
E
e
L
Min
1.35
0.10
0.33
0.15
4.75
3.80
5.80
Max
1.75
0.25
0.51
0.25
5.05
4.00
6.20
1.27(TYP.)
0.40
0°
0.80
8°
Unit:mm
13
Rev.0.1,1/2017
很抱歉,暂时无法提供与“VTI7064MSME”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+30.04560
- 10+26.67600
- 30+24.66720
- 100+22.63680
