Page 1 of 3
LilyPad Simple Power Hookup Guide
Overview
The LilyPad Simple Power is a basic power board that enables you to
power your wearable circuit with a lipo battery. It also allows battery
charging in the circuit via microUSB cable, and it provides a nice on/off
switch for your project.
The LilyPad Simple Power. Small and simple!
Being part of the LilyPad line of boards, you can wash this PCB even after
it’s been sewn to a garment. Just remember to remove the battery first
before doing any washing!
With this quick tutorial, you’ll learn how to get started with the Simple
Power.
Suggested Reading
Please check out the following tutorials, if you aren’t familiar with any of the
topics.
How to Power Your Project
Battery Technologies
E-Textile Basics
Sewing with Conductive Thread
Hardware Overview
True to its name, the LilyPad Simple power is really simple! There’s only a
few features you need to be aware of.
Page 2 of 3
Battery JST Connector
The Simple Power is designed to work with 3.7V lipo batteries. In order to
connect the battery to the board, there should be a female JST connector
on the battery you would like to use. Check out a list of compatible batteries
here.
microUSB Connector
This allows you to charge your battery via a computer USB port, using a
microB USB cable.
Positive/Negative Terminals
These sew taps are the connection points from where the power to your
circuit will flow. The positive terminal outputs 3.7V, and the negative
terminal is the ground (GND) connection.
On/Off Switch
This switch enables and disables power to flow out of the LilyPad Simple
board. When it is in the ‘on’ position, you can measure the battery voltage
across the positive (+) and negative (-) terminals. When it is in the ‘off’
position, there is no measurable voltage output from the board.
Mounting Holes
These four holes spaced across the board are designed as additional
anchoring sew taps. They are not conductive, and have no electrical
functionality.
Hardware Hookup
In our example, we are going to assume you are powering a basic LilyPad
LED. However, you can use the Simple Power to power a LilyPad Main
board, or various other products.
One thing to note about the Simple Power- it is designed for e-textile
applications, but you can solder to the board. Just keep in mind it’s going to
take more solder and more heat to attach wires to the sew taps.
Our example circuit using the Simple Power and a LilyPad LED.
Page 3 of 3
Find the ‘+’ terminal on the Simple Power and run a stitch/wire to the ‘+’
sew tap on the LED (or whatever board you are powering). Then run a wire
or stitch from the ‘-’ terminal on the Simple Power to the ‘-’ sew tap on the
LED. If you are using conductive thread, make sure you don’t let the two
lines touch! This will short out your battery, possibly short out your Simple
Power, and you’ll have a bad time.
Once your boards are connected, plug in your battery, and flip the Simple
Power switch to the ‘on’ position. Bask in that happy LED glow!
Charging the Battery
If your battery runs down, have no fear! Simply plug in a microUSB cable
into your computer and also into the LilyPad Simple board, and have some
patience. There’s a yellow LED that indicates when the board is charging
the battery. The board may also get warm while charging, but this is totally
normal. Charging times will vary depending on the capacity of the battery
connected to the Simple Power.
Resources and Going Further
Going Further
Now that you know how to use the LilyPad Simple Power, you can start
integrating it into your own projects. If you need to check out the design
files for the board, you can find them in the GitHub repo. You can also dig
into the datasheet for the MCP7383 charger IC here.
Additional Resources
If you have any feedback, please visit the comments or contact our
technical support team at TechSupport@sparkfun.com.
Check out these additional resources for more information and other project
ideas.
• E-Textile Mask
• Introducing the LilyPad Design Kit
• Dungeons and Dragons Dice Gauntlet
https://learn.sparkfun.com/tutorials/lilypad-simple-power-hookup-guide?_ga=1.26596846... 11/24/2015
很抱歉,暂时无法提供与“DEV-11893”相匹配的价格&库存,您可以联系我们找货
