Adafruit Motor Shield V2
Created by lady ada
https://learn.adafruit.com/adafruit-motor-shield-v2-for-arduino
Last updated on 2021-11-22 09:40:54 AM EST
©Adafruit Industries
Page 1 of 49
Table of Contents
Overview
5
FAQ
7
Install Headers & Terminals
12
• Installing Standard Headers
• Installing Terminal Blocks and more
• Installing with Stacking Headers
12
15
15
19
Install Software
21
21
22
22
22
24
Install Adafruit Motor Shield V2 library
Running the Example Code
DC Motor
Stepper Motor Test
Library Reference
class Adafruit_MotorShield;
Adafruit_MotorShield(uint8_t addr = 0x60);
void begin(uint16_t freq = 1600);
Adafruit_DCMotor *getMotor(uint8_t n);
Adafruit_StepperMotor *getStepper(uint16_t steps, uint8_t n);
void setPWM(uint8_t pin, uint16_t val);void setPin(uint8_t pin, boolean val);
class Adafruit_DCMotor
Adafruit_DCMotor(void);
void run(uint8_t);
void setSpeed(uint8_t);
class Adafruit_StepperMotor
Adafruit_StepperMotor(void);
void step(uint16_t steps, uint8_t dir, uint8_t style = SINGLE);
void setSpeed(uint16_t);
uint8_t onestep(uint8_t dir, uint8_t style);
void release(void);
26
27
27
27
27
28
28
28
28
29
29
30
30
30
31
31
31
Arduino Library Docs
31
Powering Motors
31
Voltage requirements:
31
Current requirements:
32
Setting up your shield for powering Hobby Servos
32
Setting up your shield for powering DC and Stepper Motors
32
If you would like to have a single DC power supply for the Arduino and motors
33
If you would like to have the Arduino powered off of USB and the motors powered off of a DC power supply 34
If you would like to have 2 separate DC power supplies for the Arduino and motors.
34
Using RC Servos
• Powering Servos
Using DC Motors
• Connecting DC Motors
34
35
36
36
Page 2 of 49
Include the required libraries
Create the Adafruit_MotorShield object
Create the DC motor object
Connect to the Controller
Set default speed
Run the motor
Using Stepper Motors
Create the stepper motor object
Set default speed
Run the motor
Python & CircuitPython
CircuitPython Microcontroller Wiring
CircuitPython Installation of MotorKit and Necessary Libraries
CircuitPython Usage
DC Motors
Stepper Motors
Full Example Code
36
37
37
37
37
37
38
39
39
39
39
39
40
40
41
42
42
43
44
Python Docs
45
Stacking Shields
45
• Addressing the Shields
• Writing Code for Multiple Shields
Resources
• Motor ideas and tutorials
46
47
48
48
Page 3 of 49
Page 4 of 49
Overview
The original Adafruit Motorshield kit is one of our most beloved kits, which is why we
decided to make something even better. We have upgraded the shield kit to make the
bestest, easiest way to drive DC and Stepper motors. This shield will make quick work
of your next robotics project! We kept the ability to drive up to 4 DC motors or 2
stepper motors, but added many improvements:
Instead of a L293D darlington driver, we now have the TB6612 MOSFET drivers
with 1.2A per channel current capability (you can draw up to 3A peak for approx 20ms
at a time). It also has much lower voltage drops across the motor so you get more
torque out of your batteries, and there are built-in flyback diodes as well.
Instead of using a latch and the Arduino's PWM pins, we have a fully-dedicated PWM
driver chip onboard. This chip handles all the motor and speed controls over I2C.
Only two GPIO pins (SDA & SCL) plus 5v and GND. are required to drive the multiple
motors, and since it's I2C you can also connect any other I2C devices or shields to
the same pins. This also makes it drop-in compatible with any Arduino, such as the
Uno, Leonardo, Due and Mega R3.
Completely stackable design: 5 address-select pins means up to 32 stackable shields:
that's 64 steppers or 128 DC motors! What on earth could you do with that many
steppers? I have no idea but if you come up with something send us a photo because
that would be a pretty glorious project.
Page 5 of 49
Lots of other little improvements such as a polarity protection FET on the power pins
and a big prototyping area. And the shield is assembled and tested here at Adafruit
so all you have to do is solder on straight or stacking headers and the terminal blocks.
Lets check out these specs again:
• 2 connections for 5V 'hobby' servos connected to the Arduino's high-resolution
dedicated timer - no jitter!
• 4 H-Bridges: TB6612 chipset provides 1.2A per bridge (3A for brief 20ms peaks)
with thermal shutdown protection, internal kickback protection diodes. Can run
motors on 4.5VDC to 13.5VDC.
• Up to 4 bi-directional DC motors with individual 8-bit speed selection (so, about
0.5% resolution)
• Up to 2 stepper motors (unipolar or bipolar) with single coil, double coil,
interleaved or micro-stepping.
• Motors automatically disabled on power-up
• Big terminal block connectors to easily hook up wires (18-26AWG) and power
• Arduino reset button brought up top
• Polarity protected 2-pin terminal block and jumper to connect external power,
for separate logic/motor supplies
• Tested compatible with Arduino UNO, Leonardo, ADK/Mega R3, Diecimila &
Duemilanove. Works with Due with 3.3v logic jumper. Works with Mega/ADK R2
and earlier with 2 wire jumpers.
• Download the easy-to-use Arduino software library, check out the examples and
you're ready to go!
• 5v or 3.3v compatible logic levels - jumper configurable.
Page 6 of 49
As of Arduino 1.5.6-r2 BETA, there is a bug in the Due Wire library that prevents
multiple Motor Shields from working properly with the Due!
FAQ
How many motors can I use with this shield?
You can use 2 DC hobby servos that run on 5V and up to 4 DC motors or 2 stepper
motors (or 1 stepper and up to 2 DC motors) that run on 5-12VDC
Can I connect more motors?
Yes, by stacking shields! Every shield you stack on will add 4 DC motors or 2
stepper motors (or 1 more stepper and 2 more DC motors).
You will not gain more servo connections as the servo contacts go to pin #9 and
#10 on the Arduino.
What if I also need some more servos?
Check out our lovely servo shield, also stackable with this motor shield and adds
16 free-running servos per shield http://learn.adafruit.com/adafruit-16-channel-pwmslash-servo-shield (https://adafru.it/ciQ)
What Arduinos is this shield compatible with?
It is tested to work with Duemilanove, Diecimila, Uno (all revisions), Leonardo and
Mega/ADK R3 and higher.
It can work with Mega R2 and lower if you solder a jumper wire from the shield's
SDA pin to Digital 20 and the SCL pin to Digital 21
For use with the Due or other 3.3v processors, you must configure the board for
3.3v logic levels. Find the set of 3 pads labeled "Logic". Cut the small trace
between the center pad and 5v and add a jumper from 3.3v to the center.
multiple Motor Shields from working properly!
Page 7 of 49
I get the following error trying to run the example code:
"error: Adafruit_MotorShield.h: No such file or directory...."
Make sure you have installed the Adafruit_MotorShield library
How do I install the library?
Check the tutorial page on the subject here http://learn.adafruit.com/adafruitmotor-shield-v2-for-arduino/install-software (https://adafru.it/ciO)
What stepper motors can I used with the shield?
The TB6612B driver chip are simple H-bridge drivers with a 1.2A continuous current
limit. There is no active current limiting, so you need to choose a stepper motor
that will not try to pull more than that. For a detailed explanation, see this
guide (https://adafru.it/r2d)
A simple rule of thumb is to use a motor with a phase resistance of 10 ohms or
more. This will be safe to use with supply voltages up to 12v.
The NEMA 17 motor we have in the shop has a phase resistance of about 35 ohms,
so it is a good match for the shield.
Can I use this NEMA-17 motor?
NEMA-17 is just a motor frame-size designation. It tells us that the motor body is
1.7" square. It tells us nothing about the electrical characteristics. You will need to
know at least the motor's phase resistance in order to determine compatibility.
See this guide for details: Matching the Driver to the Stepper (https://adafru.it/r2d)
HELP! My motor doesnt work! - HELP! My motor doesnt
work!...But the servos work FINE!
Is the power LED lit? The Stepper and DC motor connections will not work if the
onboard green Power LED is not lit brightly!
You must connect 5-12VDC power to the shield through the POWER terminal
blocks or through the DC barrel jack on the Arduino and VIN jumper.
Page 8 of 49
What is the green Power LED for?
The LED indicates the DC/Stepper motor power supply is working. If it is not lit
brightly, then the DC/Stepper motors will not run. The servo ports are 5V powered
and does not use the DC motor supply
What pins are/are not used on the motor shield?
GND and either 5v (default) or 3.3v are required to power the logic on-board. (5v or
3v operation is selectable via jumper)
The shield uses the SDA and SCL i2c pins to control DC and stepper motors. On
the Arduino UNO these are also known as A4 and A5. On the Mega these are also
known as Digital 20 and 21. On the Leonardo these are also known as digital 2 and
3. Do not use those pins on those Arduinos with this shield with anything other
than an i2c sensor/driver.
Since the shield uses I2C to communicate, you can connect any other i2c sensor or
driver to the SDA/SCL pins as long as they do not use address 0x60 (the default
address of the shield) or 0x70 (the 'all call' address that this chip uses for groupcontrol)
If you want to use the servo connections, they are on pins #9 and #10. If you do not
use the connector then those pins are simply not used.
You can use any other pins for any other use
Note that pins A4 and A5 are connected to SDA and SCL for compatibility with
classic Arduinos. These pins are not available for use on other processors.
How can I connect to the unused pins?
All pins are broken out into 0.1" spaced header along the edges of the shield
My Arduino freaks out when the motors are running! Is the
shield broken?
Motors take a lot of power, and can cause 'brownouts' that reset the Arduino. For
that reason the shield is designed for seperate (split) supplies - one for the
electronics and one for the motor. Doing this will prevent brownouts. Please read
the user manual for information about appropriate power supplies.
Page 9 of 49
I'm trying to build this robot and it doesn't seem to run on
a 9V battery....
You cannot power motors from a 9V battery. You must use AA batteries or a lead
acid battery for motors.
Can this shield control small 3V motors?
Not really, its meant for larger, 5V+ motors. It does not work for 3V motors unless
you overdrive them at 5V and then they will burn out faster
I have good solid power supplies, but the DC motors
seem to 'cut out' or 'skip'.
Try soldering a ceramic or disc 0.1uF capacitor between the motor tabs (on the
motor itself!) this will reduce noise that could be feeding back into the circuit
(thanks macegr (https://adafru.it/clc)!)
When the motors start running nothing else works.
Many small DC motor have a lot of "brush noise". This feeds back into the Arduino
circuitry and causes unstable operation. This problem can be solved by soldering
some 0.1uF ceramic noise suppression capacitors to the motor.
You will need 3 total. 1 between the motor terminals, and one from each terminal
to the motor casing.
Page 10 of 49
But my motor already has a capacitor on it and it still
doesn't work.
These motors generate a lot of brush noise and usually need the full 3-capacitor
treatment for adequate suppression.
Why don't you just design capacitors into the shield?
They would not be effective there. The noise must be suppressed at the source or
the motor leads will act like antennae and broadcast it to the rest of the system!
Why won't my stepper motor go any faster?
Since the shield is controlled by i2c, the maximum step rate is limited by the i2c
bus speed. The default bus speed is 100KHz and can be increased to 400KHz by
editing the library file in your Arduino installation folder. The file can be found in
hardware/libraries/wire/utility/twi.h.
Find the line with: "#define TWI_FREQ 100000L"
and change it to "#define TWI_FREQ 400000L"
Page 11 of 49
Or, you can add the following code to your setup() function: (Note: this line must
be inserted after the call to begin())
TWBR = ((F_CPU /400000l) - 16) / 2; // Change the i2c clock to 400KHz
What I2C addresses are used by this shield?
The shield is addressable from 0x60-0x7F. 0x70 is an "all call" address that all
boards will answer to.
My shield doesn't work with my LED backpack.
Some backpacks have a default address of 0x70. This is the "all call" address of
the controller chip on the motor shield. If you re-address your backpack, it will
work with the shield.
The shield comes with 0.1" standard header. Standard header does not permit
stacking but it is mechanically stronger and they're much less expensive too! If you
want to stack a shield on top, do not perform this step as it is not possible to uninstall
Page 12 of 49
the headers once soldered in! Skip down to the bottom for the stacking tutorial
Break apart the 0.1" header into 6, 8 and/
or 10-pin long pieces and slip the long
ends into the headers of your Arduino
Place the assembled shield on top of the
header-ed Arduino so that all of the short
parts of the header are sticking through
the outer set of pads
Page 13 of 49
Solder each one of the pins into the
shield to make a secure connection
Next, you will attach the terminal blocks,
power jumper and servo connections
Page 14 of 49
That's it! Now you can install the terminal
blocks and jumper...
After you have installed either normal or stacking headers, you must install the
terminal blocks.
Next we will install the terminal blocks.
These are how we will connect power
and motors to the shield. They're much
easier to use than soldering direct, just
use a small screwdriver to release/attach
wires!
First, though, we must solder them in.
Slide the 3-pin terminal blocks into 2-pin
terminal blocks so that you have 2 x 5pin and 1 x 2-pin blocks. The two 5-pin
sets go on either side. The 2-pin piece
goes near the bottom of the shield. Make
sure that the open holes of the terminal
blocks face out!
Page 15 of 49
Flip the board over so that you can see &
solder the pins of the terminal blocks
Solder in the two pins of the external
power terminal-block
Page 16 of 49
Solder in both motor blocks, 5 pads each
That's it for the terminal blocks. Next up,
servo connections.
Page 17 of 49
OK next up take the 2x3 pin header and
place it with the short legs down into the
top corner where it says SERVO 1 and
SERVO 2
You might have to sort of angle the part a
little to get it to fit into both sets of 3-pin
holes. we did this so it wont fall out easily
when you turn it over!
Then flip the board over and solder the 6
pins
Page 18 of 49
Finally, break off a 2-pin piece of header
and place it next to the POWER terminal
block, short legs down, tape it in place if
necessary and solder it in.
You will need to purchase Arduino
stacking headers for this step, the shield
does not come with them. (http://
adafru.it/85)
We don't show soldering in the 2x3 stacking header but you should solder that in
as well - even though this shield does not use it, the one above may need those
pins!
Page 19 of 49
Start by sliding the 10 pin, 2 x 8 pin and
6-pin stacking headers into the outer
rows of the shield from the top. Then flip
the board over so its resting on the four
headers. Pull on the legs if necessary to
straighten them out.
Tack one pin of each header, to get them
set in place before more soldering. If the
headers go crooked you can re-heat the
one pin while re-positioning to straighten
them up
Page 20 of 49
Once you've tacked and straightened all
the headers, go back and solder the
remaining pins for each header.
Install Software
To use the shield on an Arduino, you'll need to install the Adafruit Motorshield v2
library. This library is not compatible with the older AF_Motor library used for v1
shields. However, if you have code for the older shield, adapting the code to use the
new shield isn't difficult. We had to change the interface a little to support shield
stacking, & we think its worth it!
To begin controlling motors, you will need to install the
Adafruit_Motor_Shield_V2_Library library (code on our github repository) (https://
adafru.it/ciN). It is available from the Arduino library manager so we recommend using
that.
From the IDE open up the library manager...
Page 21 of 49
And type in adafruit motor to locate the library. Click Install
If you plan to use AccelStepper for acceleration control or for simultaneous control of
multiple stepper motors, you will also need to download and install the AccelStepper
library:
AccelStepper Library
https://adafru.it/IpB
For more details on how to install Arduino libraries, check out our detailed tutorial! (ht
tps://adafru.it/aYM)
DC Motor
The library comes with a few examples to get you started up fast. We suggest getting
started with the DC motor example. You can use any DC motor that can be powered
by 6V-12VDC
First, restart the IDE to make sure the new library is loaded.
Page 22 of 49
Plug the shield into the Arduino and connect a DC motor to motor port 1 - it does not
matter which wire goes into which terminal block as motors are bi-directional.
Connect to the top two terminal ports, do not connect to the middle pin (GND) See
the photo below for the red and blue wire example. Be sure to screw down the
terminal blocks to make a good connection!
You must also supply 5-12VDC to power the motor. There are two ways to do this
1. You can power the Arduino via the DC Barrel Jack and insert the VIN Jumper
shown as the tall black handle right next to the green Power LED below
2. You can power the Arduino via the DC Barrel jack or USB port. Then Power the
shield via the 5-12VDC motor power terminal port, the double terminal block
next to the green Power LED and remove the VIN jumper
If the Green LED next to the power terminal block isn't lit up brightly do not
continue!
Page 23 of 49
Once you have verified the motor is connected properly and you have the power LED
lit up brightly, we can upload our code.
In the IDE, load File->Examples->Adafruit_MotorShield->DCMotorTest
You should see and hear the DC motor turn on and move back and forth, attaching a
slip of paper or tape as a 'flag' can help you visualize the movement if you have
trouble seeing the movement
Stepper Motor Test
You can also test a stepper motor connection with the shield. The shield can run unip
olar (5-wire and 6-wire) and bipolar (4-wire) steppers. It cannot run steppers with any
other # of wires! The code is the same for unipolar or bipolar motors, the wiring is just
slightly different.
Plug the shield into the Arduino and connect a stepper motor to motor port 2 - unlike
DC motors, the wire order does 'matter'. Connect to the top two terminal ports (coil #1)
and the bottom two terminal ports (coil #2).
• If you have a bipolar motor, do not connect to the middle pin (GND).
• If you are using a unipolar motor with 5 wires, connect the common wire to
GND.
• If you are using a unipolar motor with 6 wires, you can connect the two 'center
coil wires' together to GND
Page 24 of 49
If the Green LED isn't lit up brightly do not continue - you must power it via the VIN
jumper or the terminal block
Page 25 of 49
In the IDE, load File->Examples->Adafruit_MotorShield->StepperTest
You should see and hear the stepper motor turn on and move back and forth,
attaching a slip of paper or tape as a 'flag' can help you visualize the movement if you
have trouble seeing the movement. There are four ways to move a stepper, with
varying speed, torque and smoothness tradeoffs. This example code will demonstrate
all four.
Library Reference
Page 26 of 49
The Adafruit_MotorShield class represents a motor shield and must be instantiated
before any DCMotors or StepperMotors can be used. You will need to declare one
Adafruit_MotorShield for each shield in your system.
The constructor takes one optional parameter to specify the i2c address of the shield.
The default address of the constructor (0x60) matches the default address of the
boards as shipped. If you have more than one shield in your system, each shield must
have a unique address.
begin() must be called in setup() to initialize the shield. An optional frequency
parameter can be used to specify something other than the default maximum: 1.6KHz
PWM frequency.
This function returns one of 4 pre-defined DC motor objects controlled by the shield.
The parameter specifies the associated motor channel: 1-4.
Page 27 of 49
n);
This function returns one of 2 pre-defined stepper motor objects controlled by the
shield.
The first parameter specifies the number of steps per revolution.
The second parameter specifies the associated stepper channel: 1-2.
These are low-level functions to control pins on the on-board PWM driver chip. These
functions are intended for internal use only.
The Adafruit_DCMotor class represents a DC motor attached to the shield. You must
declare an Adafruit_DCMotor for each motor in your system.
The constructor takes no arguments. The motor object is typically initialized by
assigning a motor object retrieved from the shield class as below:
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Page 28 of 49
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
// You can also make another motor on port M2
Adafruit_DCMotor *myOtherMotor = AFMS.getMotor(2);
void run(uint8_t);
The run() function controls the motor state. The parameter can have one of 3 values:
• FORWARD - Rotate in a forward direction
• BACKWARD - Rotate in the reverse direction
• RELEASE - Stop rotation
Note that the "FORWARD" and "BACKWARD" directions are arbitrary. If they do not
match the actual direction of your vehicle or robot, simple swap the motor leads.
Also note that "RELEASE" simply cuts power to the motor. It does not apply any
braking.
The setSpeed() function controls the power level delivered to the motor. The speed
parameter is a value between 0 and 255.
Note that setSpeed just controls the power delivered to the motor. The actual speed
of the motor will depend on several factors, including: The motor, the power supply
and the load.
Page 29 of 49
The Adafruit_StepperMotor class represents a stepper motor attached to the shield.
You must declare an Adafruit_StepperMotor for each stepper motor in your system.
The constructor takes no arguments. The stepper motor is typically initialized by
assigning a stepper object retrieved from the shield as below:
// Connect a stepper motor with 200 steps per revolution (1.8 degree)
// to motor port #2 (M3 and M4)
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
SINGLE);
The step() function controls stepper motion.
• The first parameter specifies how many steps to move.
• The second parameter specifies the direction: FORWARD or BACKWARD
• The last parameter specifies the stepping style: SINGLE, DOUBLE,
INTERLEAVED or MICROSTEP
The ste() function is synchronous and does not return until all steps are complete.
When complete the motor remains powered to apply "holding torque" to maintain
Page 30 of 49
position.
The setSpeed() function controls the speed of the stepper motor rotation. Speed is
specified in RPM.
The oneStep() function is a low-level internal function called by step(). But it can be
useful to call on its own to implement more advanced functions such as acceleration
or coordinating simultaneous movement of multiple stepper motors. The direction and
style parameters are the same as for step(), but onestep() steps exactly once.
Note: Calling step() with a step count of 1 is not the same as calling onestep(). The
step function has a delay based on the speed set in setSpeed(). onestep() has no
delay.
void release(void);
The release() function removes all power from the motor. Call this function to reduce
power requirements if holding torque is not required to maintain position.
Arduino Library Docs (https://adafru.it/AvQ)
Powering Motors
Motors need a lot of energy, especially cheap motors since they're less efficient.
The first important thing to figure out what voltage the motor is going to use. If you're
lucky your motor came with some sort of specifications. Some small hobby motors are
only intended to run at 1.5V, but its just as common to have 6-12V motors. The motor
controllers on this shield are designed to run from 5V to 12V.
Page 31 of 49
MOST 1.5-3V MOTORS WILL NOT WORK
The second thing to figure out is how much current your motor will need. The motor
driver chips that come with the kit are designed to provide up to 1.2 A per motor, with
3A peak current. Note that the 'peak' rating is for very brief peaks such as during
startup. Peak current levels can only be tolerated for a few milliseconds. If you will
be pushing the 1.2A continuous limit you'll probably want to put a heat-sink on the
motor driver, otherwise you will get thermal failure, possibly burning out the chip.
You can't run motors off of a 9V battery so don't waste your time/batteries!
Use a big Lead Acid or NiMH battery pack. Its also very much suggested that you set
up two power supplies (split supply) one for the Arduino and one for the motors. 99%
of 'weird motor problems' are due to noise on the power line from sharing power
supplies and/or not having a powerful enough supply! Even small DC motors can draw
up to 3 Amps when they stall.
Servos
Servos are powered off of the same regulated 5V that the Arduino uses. This is OK for
the small hobby servos suggested. Basically, power up your Arduino with the USB
port or DC barrel jack and you're good to go. If you want something beefier, cut the
trace going to the optional servo power terminal and wire up your own 5-6V supply!
Stepper Motors
The motors are powered off of a 'high voltage supply' and NOT the regulated 5V. Do
n't connect the motor power supply to the Arduino's 5V power pin. This is a very very
very bad idea unless you are sure you know what you're doing! You could damage
your Arduino and/or USB port!
Page 32 of 49
There are two places you can get your motor 'high voltage supply' from.
1. One is the DC barrel jack on the Arduino board
2. The other is the 2-terminal block on the shield that is labeled DC Motor Power
5-12VDC.
The DC Jack on the Arduino has a protection diode so you won't be able to mess
things up too bad if you plug in the wrong kind of power. The terminal block has a
protection FET so you will not damage the arduino/shield if you wire up your battery
supply backwards, but it wont work either!
Here's how it works:
Arduino and motors
Say a wall adapter or a single battery pack with 6-12VDC output, simply plug it into
the DC jack on the Arduino or the 2-pin power terminal block on the shield. Place the
power jumper on the motor shield.
Note that you may have problems with Arduino resets if the battery supply is not able
to provide constant power, so it is not a suggested way of powering your motor
project. You cannot use a 9V battery for this, it must be 4 to 8 AA batteries or a single
/double lead acid battery pack.
Page 33 of 49
Plug in the USB cable. Then connect the motor supply to the power terminal block on
the shield. Do not place the jumper on the shield.
This is a suggested method of powering your motor project as it has a split supply,
one power supply for logic, and one supply for motors
Plug in the supply for the Arduino into the DC jack, and connect the motor supply to
the power terminal block. Make sure the jumper is removed from the motor shield.
No matter what, if you want to use the DC motor/Stepper system the motor shield LED
should be lit indicating good motor power
Using RC Servos
Page 34 of 49
Hobby servos are the easiest way to get going with motor control. They have a 3-pin
0.1" female header connection with +5V, ground and signal inputs. The motor shield
simply brings out the PWM output lines from Arduino pins 9 and 10 to two 3-pin
headers so that its easy to plug in and go. They can take a lot of power so a 9V
battery wont last more than a few minutes!
The nice thing about using the onboard PWM is that its very precise and goes about
its business in the background. You can use the built in Servo library
Using the servos is easy, please read the official Arduino documentation for how to
use them and see the example Servo sketches in the IDE (https://adafru.it/aOD).
Powering Servos
Power for the Servos comes from the Arduino's on-board 5V regulator, powered
directly from the USB or DC power jack on the Arduino. If you need an external
supply, cut the 5v trace on the bottom of the board and connect a 5V or 6V DC
supply directly to the Opt Servo power input. Using an external supply is for advanced
users as you can accidentally destroy the servos by connecting a power supply
incorrectly!
When using external servo power, be careful not to let it short out against the
USB socket shell on the processor board. Insulate the top of the USB socket
with some electrical tape.
Page 35 of 49
Using DC Motors
DC motors are used for all sort of robotic projects.
The motor shield can drive up to 4 DC motors bi-directionally. That means they can be
driven forwards and backwards. The speed can also be varied at 0.5% increments
using the high-quality built in PWM. This means the speed is very smooth and won't
vary!
Note that the H-bridge chip is not meant for driving continuous loads of 1.2A, so this is
for small motors. Check the datasheet for information about the motor to verify its OK!
To connect a motor, simply solder two wires to the terminals and then connect them
to either the M1, M2, M3, or M4. Then follow these steps in your sketch
Make sure you #include the required libraries
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
Page 36 of 49
Request the DC motor from the Adafruit_MotorShield:
with getMotor(port#). Port# is which port it is connected to. If you're using M1 its 1, M2
use 2, M3 use 3 and M4 use 4
In your setup() function, call begin() on the Adafruit_MotorShield object:
AFMS.begin();
Set default speed
Set the speed of the motor using setSpeed(speed) where the speed ranges from 0
(stopped) to 255 (full speed). You can set the speed whenever you want.
myMotor->setSpeed(150);
Run the motor
To run the motor, call run(direction) where direction is FORWARD, BACKWARD or REL
EASE. Of course, the Arduino doesn't actually know if the motor is 'forward' or
'backward', so if you want to change which way it thinks is forward, simply swap the
two wires from the motor to the shield.
myMotor->run(FORWARD);
Page 37 of 49
Stepper motors are great for (semi-)precise control, perfect for many robot and CNC
projects. This motor shield supports up to 2 stepper motors. The library works
identically for bi-polar and uni-polar motors
Before connecting a motor, be sure to check the motor specifications for compatibility
with the shield (https://adafru.it/r2d).
For unipolar motors: to connect up the stepper, first figure out which pins connected
to which coil, and which pins are the center taps. If its a 5-wire motor then there will
be 1 that is the center tap for both coils. Theres plenty of tutorials online on how to
reverse engineer the coils pinout. (https://adafru.it/aOO) The center taps should both
be connected together to the GND terminal on the motor shield output block. then
coil 1 should connect to one motor port (say M1 or M3) and coil 2 should connect to
the other motor port (M2 or M4).
For bipolar motors: its just like unipolar motors except theres no 5th wire to connect
to ground. The code is exactly the same.
Running a stepper is a little more intricate than running a DC motor but its still very
easy
Page 38 of 49
#include <Wire.h>
#include "utility/Adafruit_PWMServoDriver.h"
Request the Stepper motor from the Adafruit_MotorShield:
...with getStepper(steps, stepper#) .
Steps indicates how many steps per revolution the motor has. A 7.5 degree/step
motor has 360/7.5 = 48 steps.
Stepper# is which port it is connected to. If you're using M1 and M2, its port 1. If
you're using M3 and M4 indicate port 2
Set default speed
Set the speed of the motor using setSpeed(rpm) where rpm is how many
revolutions per minute you want the stepper to turn.
Run the motor
Then every time you want the motor to move, call the step(#steps, direction,
steptype) procedure. #steps is how many steps you'd like it to take. direction is
Page 39 of 49
either FORWARD or BACKWARD and the step type is SINGLE, DOUBLE, INTERLEAVE
or MICROSTEP.
• "Single" means single-coil activation
• "Double" means 2 coils are activated at once (for higher torque)
• "Interleave" means that it alternates between single and double to get twice the
resolution (but of course its half the speed).
• "Microstepping" is a method where the coils are PWM'd to create smooth motion
between steps.
Theres tons of information about the pros and cons of these different stepping
methods in the resources page.
You can use whichever stepping method you want, changing it "on the fly" to as you
may want minimum power, more torque, or more precision.
By default, the motor will 'hold' the position after its done stepping. If you want to
release all the coils, so that it can spin freely, call release()
The stepping commands are 'blocking' and will return once the steps have finished.
Because the stepping commands 'block' - you have to instruct the Stepper motors
each time you want them to move. If you want to have more of a 'background task'
stepper control, check out the AccelStepper library (https://adafru.it/X1e) . There are
several AccelStepper examples included with the motor shield library.
We've written a handy CircuitPython library for the various DC Motor and Stepper kits
called Adafruit CircuitPython MotorKit (https://adafru.it/DdU) that handles all the
complicated setup for you. All you need to do is import the appropriate class from the
library, and then all the features of that class are available for use. We're going to
show you how to import the MotorKit class and use it to control DC and stepper
motors with the Adafruit Stepper + DC Motor Shield.
First assemble the Shield exactly as shown in the previous pages. There's no wiring
needed to connect the Shield to the Metro. The example below shows wiring two DC
motors to the Shield once it has been attached to a Metro. You'll want to connect a
Page 40 of 49
barrel jack to the power terminal to attach an appropriate external power source to
the Shield. The Shield will not function without an external power source!
• Connect the two motor wires from
the first motor to the M1 terminal on
the Shield.
the second motor to the M2
terminal on the Shield.
• Connect the positive side of the
power terminal to the positive side
of the barrel jack.
• Connect the negative side of the
power terminal to the negative side
of the barrel jack.
Necessary Libraries
You'll need to install a few libraries on your Metro board.
First make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/Amd) for your board.
Next you'll need to install the necessary libraries to use the hardware--carefully follow
the steps to find and install these libraries from Adafruit's CircuitPython library bundle
(https://adafru.it/uap). Our CircuitPython starter guide has a great page on how to
install the library bundle (https://adafru.it/ABU).
If you choose, you can manually install the libraries individually on your board:
• adafruit_pca9685
• adafruit_bus_device
• adafruit_register
• adafruit_motor
• adafruit_motorkit
Before continuing make sure your board's lib folder or root filesystem has the
adafruit_pca9685.mpy, adafruit_register, adafruit_motor, adafruit_bus_device and
adafruit_motorkit files and folders copied over.
Page 41 of 49
Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the
CircuitPython >>> prompt.
CircuitPython Usage
To demonstrate the usage, we'll initialise the library and use Python code to control
DC and stepper motors from the board's Python REPL.
First you'll need to import and initialize the MotorKit class.
from adafruit_motorkit import MotorKit
kit = MotorKit()
DC Motors
The four motor spots on the Shield are available as motor1 , motor2 , motor3 , and
motor4 .
In this example we'll use motor1 .
Note: For small DC motors like sold in the shop you might run into problems with
electrical noise they generate and erratic behavior on your board. If you see erratic
behavior like the motor not spinning or the board resetting at high motor speeds this
is likely the problem. See this motor guide FAQ page for information on capacitors
you can solder to the motor to reduce noise (https://adafru.it/scl).
Now to move a motor you can set the throttle attribute. We don't call it speed
because it doesn't correlate to a particular number of revolutions per minute (RPM).
RPM depends on the motor and the voltage which is unknown.
For example to drive motor M1 forward at a full speed you set it to 1.0 :
kit.motor1.throttle = 1.0
To run the motor at half throttle forward use a decimal:
kit.motor1.throttle = 0.5
Or to reverse the direction use a negative throttle:
Page 42 of 49
kit.motor1.throttle = -0.5
You can stop the motor with a throttle of 0 :
To let the motor coast and then spin freely set throttle to None .
kit.motor1.throttle = None
That's all there is to controlling DC motors with CircuitPython! With DC motors you can
build fun moving projects like robots or remote controlled cars that glide around with
ease.
Stepper Motors
Similar DC motors, stepper motors are available as stepper1 and stepper2 . step
per1 is made up of the M1 and M2 terminals, and stepper2 is made up of the M3
and M4 terminals.
We'll use stepper1 in our example.
The most basic function (and the default) is to do one single coil step.
kit.stepper1.onestep()
You can also call the onestep function with two optional keyword arguments. To use
these, you'll need to import stepper as well.
from adafruit_motor import stepper
Then you have access to the following options:
• direction , which should be one of the following constant values:
◦ stepper.FORWARD (default)
◦ stepper.BACKWARD .
Page 43 of 49
• style , which should be one of the values:
◦ stepper.SINGLE (default) for a full step rotation to a position where one
single coil is powered
◦ stepper.DOUBLE for a full step rotation to position where two coils are
powered providing more torque
◦ stepper.INTERLEAVED for a half step rotation interleaving single and
double coil positions and torque
◦ stepper.MICROSTEP for a microstep rotation to a position where two
coils are partially active.
• release() which releases all the coils so the motor can free spin, and also
won't use any power
The function returns the current step 'position' in microsteps which can be handy to
understand how far the stepper has moved, or you can ignore the result.
To take a double-coil step backward call:
kit.stepper1.onestep(direction=stepper.BACKWARD, style=stepper.DOUBLE)
You can even use a loop to continuously call onestep and move the stepper, for
example a loop of 200 microsteps forward for smooth movement:
for i in range(200):
kit.stepper1.onestep(style=stepper.MICROSTEP)
That's all there is to controlling a stepper motor from CircuitPython! Steppers are
handy motors for when you need smooth or precise control of something--for
example 3D printers and CNC machines use steppers to precisely move tools around
surfaces.
Full Example Code
For DC motors:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
"""Simple test for using adafruit_motorkit with a DC motor"""
import time
import board
kit = MotorKit(i2c=board.I2C())
Page 44 of 49
time.sleep(0.5)
For stepper motors:
"""Simple test for using adafruit_motorkit with a stepper motor"""
import time
import board
for i in range(100):
time.sleep(0.01)
Python Docs
Python Docs (https://adafru.it/DeE)
Stacking Shields
One of the cool things about this shield design is that it is possible to stack shields.
Every shield you stack can control another 2 steppers or 4 DC motors (or a mix of the
two)
Page 45 of 49
You can stack up to 32 shields for a total of 64 steppers or 128 DC motors! Most
people will probably just stack two or maybe three but hey, you never know. (PS if you
drive 64 steppers from one of these shields send us a photo, OK?)
Note that stacking shields does not increase the servo connections - those are hardwired to the Arduino digital 9 & 10 pins. If you need to control a lot of servos, you can
use our 16-channel servo shield and stack it with this shield to add a crazy large # of
servos. (http://adafru.it/1411)
Stacking shields is very easy. Each shield you want to stack on top of must have
stacking headers installed. Check our instructions for how to do so. (https://adafru.it/
ciP) The top shield does not have to have stacking headers unless you eventually
want to put something on top of it.
The only thing to watch for when stacking shields is every shield must have a unique
I2C address. The default address is 0x60. You can adjust the address of the shields to
range from 0x60 to 0x7F for a total of 32 unique addresses.
Each board in the chain must be assigned a unique address. This is done with the
address jumpers on the lower edge of the board. The I2C base address for each
board is 0x60. The binary address that you program with the address jumpers is
added to the base I2C address.
To program the address offset, use a drop of solder to bridge the corresponding
address jumper for each binary '1' in the address.
The right-most jumper is address bit #0, then to the left of that is address bit #1, etc
up to address bit #4
Page 46 of 49
Board 0: Address = 0x60 Offset = binary 0000 (no jumpers required)
Board 1: Address = 0x61 Offset = binary 0001 (bridge A0 as in the photo above)
Board 2: Address = 0x62 Offset = binary 0010 (bridge A1, to the left of A0)
Board 3: Address = 0x63 Offset = binary 0011 (bridge A0 & A1, two rightmost jumpers)
Board 4: Address = 0x64 Offset = binary 0100 (bridge A2, middle jumper)
etc.
Note that address 0x70 is the "all call" address for the controller chip on the
shield. All boards will respond to address 0x70 - regardless of the address
jumper settings.
The Adafruit_MotorShield library has the ability to control multiple shields, unlike the
older AF_Motor library. First we must create a Motor Shield Controller for each shield,
with the assigned address.
Adafruit_MotorShield AFMSbot(0x61); // Rightmost jumper closed
Adafruit_MotorShield AFMStop(0x60); // Default address, no jumpers
One motor shield is going to be called AFMSbot (bottom shield, so we remember) and
one is AFMStop (top shield) so we can keep them apart. When you create the shield
object, specify the address you set for it above.
Then we can request the motors connected to each one
Page 47 of 49
// On the top shield, connect two steppers, each with 200 steps
Adafruit_StepperMotor *myStepper2 = AFMStop.getStepper(200, 1);
Adafruit_StepperMotor *myStepper3 = AFMStop.getStepper(200, 2);
// On the bottom shield connect a stepper to port M3/M4 with 200 steps
Adafruit_StepperMotor *myStepper1 = AFMSbot.getStepper(200, 2);
// And a DC Motor to port M1
Adafruit_DCMotor *myMotor1 = AFMSbot.getMotor(1);
You can request a stepper or DC motor from any port, just be sure to use the right
AFMS controller object when you call getMotor or getStepper!
Then, both shields must have begin called, before you use the motors connected
AFMSbot.begin(); // Start the bottom shield
AFMStop.begin(); // Start the top shield
You can try out this code for yourself by setting up two shields and running the File>Examples->Adafruit_MotorShield->StackingTest example
Resources
• Wikipedia has tons of information (https://adafru.it/aOF) on steppers
• Jones on stepper motor types (https://adafru.it/aOH)
• Jason on reverse engineering the stepper wire pinouts (https://adafru.it/aOI)
PCB files are on GitHub (https://adafru.it/DeF)
Schematic, click to embiggen
Page 48 of 49
Page 49 of 49
