171/G
171/G
    GREENLEECOMMUNICATIONS(格林利)
    CONN FERRULE 18AWG YELLOW
171/G 数据手册
WIRE FERRULE INSUL Insulated Wire Ferrules Cat No: 171/G UPC No: 783310048497 Description • • Terminate stranded wire into terminal blocks Electrolytic copper and tin plating provide maximum conductivity and low contact resistance Specifications • • • • • • • • • • • • Color : Yellow Color Code : Old DIN Standard Dimension Inches L2 : 0.315 IN (8.000 MM) Finish : Tin Plated Insulation : Polypropylene Plastic Material : Electrolytic Copper Recommended Crimping Tools : K1GL, K32GL, K36GL, K30GL, Die 03283 Size : 0.574 IN (14.600 MM) Overall Length, 0.315 IN (8.000 MM) Sleeve Length Standard : CSA, LR 702418, NRTL/C, RoHS Type : Insulated Wire Size : 18-17 AWG (1.000 SQ-MM) Wire Type : Stranded
171/G 价格&库存
很抱歉,暂时无法提供与“171/G”相匹配的价格&库存,您可以联系我们找货
