1750F
1750F
    HAMMONDMANUFACTURING
    TRANSFORMER TUBE GUITAR AMP
1750F 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1750F TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER PRIMARY • BRN • • • • • Designed for drop in replacement of original units. Constructed to look similar to original factory units (where possible). Material used & design specifications were kept as close as possible to the original part to preserve the stock "tone". Open style with minimum 7" long primary and secondary leads Frequency response 70Hz - 15KHz (0/-1.5dB reference @ 1KHz) Distortion is less than 3% @ 70Hz SECONDARY GRN COM RED 6950 CT Ohms BLK 8 Ohms BLU 70Hz - 15kHz 15W ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power Typical 6950 Ohms 8 Ohms 15W BL 17 50 C GRN U - 15 RE W G R D -B 7 0 N - R N H zBL : 6 15 IN K: 95 kH CA NA 8 0  z DA CT MA DE F BLK DA TE B DCR Primary Red-Brown Primary Red-Blue Secondary Black-Green 97.36 Ohms 97.36 Ohms 0.409 Ohm BRN A RED D G Inductance Impedance Primary Blue-Brown Secondary Black-Green @ 1.0 kHz, 1.0 V OC 3.99H 24.8K Ohm 8.71mH 66.28 Ohm Leakage Inductance Primary Blue-Brown @ 1.0 kHz, 1.0 V SC 7.03mH Dielectric Strength Temperature Range 1500VRMS -40 to 105 degC TEST CONDITIONS Measurement instruments: D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B Keithley 2010 DVM Hp4192a impedance analyzer BLU NOTE: ALL LEADS 7" OUT MIN. Dimensions A 3.250” ±0.063 B 1.687” ±0.125 C 1.995” ±0.063 D G 2.813” ±0.063 0.187” ±0.015 TYPICAL TEST CIRCUIT PRIMARY R S/ SECONDARY 2 RL * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. R S/ OUT 2 www.hammondmfg.com This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. www.hammondmfg.com
1750F 价格&库存
很抱歉,暂时无法提供与“1750F”相匹配的价格&库存,您可以联系我们找货
