Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1750L
PRIMARY
BRN
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
Designed for drop in replacement of original
units.
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 9" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1.0dB reference @ 1KHz)
Distortion is less than 2% @ 70Hz
SECONDARY
GRN
4200 CT
Ohms
4 Ohms
RED
BLU
60 W ATTS
70Hz - 15kHz
BLK COM
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
4200 Ohms
4 Ohms
60W
B
60
W
att
s
Black
C
DCR
Primary Brown-Blue
Secondary Black-Green
98.6 Ohms
0.170 Ohm
Brown
Red
Green
E
Inductance
Impedance
Primary Blue-Brown
A
@ 1.0 kHz, 1.0 V OC
6.52H
41.6 KOhm
Leakage Inductance
Primary Blue-Brown
@ 1.0 kHz, 1.0 V SC
4.93mH
Dielectric Strength
Temperature Range
2000VRMS
-40 to 105 degC
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
D
F
Keithley 2010 DVM
Hp4192a impedance analyzer
Blue
G
Dimensions
A 4.050” ±0.063
B 3.050” REF
C 3.46" MAX
D
E
F
3.500” ±0.063
2.490” ±0.063
1.940” ±0.063
G
0.187x0.300”
TYPICAL TEST CIRCUIT
PRIMARY
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
R S/
OUT
2
www.hammondmfg.com
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission
of Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
很抱歉,暂时无法提供与“1750L”相匹配的价格&库存,您可以联系我们找货
