1760W
1760W
    HAMMONDMANUFACTURING
    TRANSFORMER TUBE GUITAR AMP
1760W 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1760W PRIMARY TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER • • • • • • SECONDARY BLU Designed for drop in replacement of original units. Constructed to look similar to original factory units (where possible). Material used & design specifications were kept as close as possible to the original part to preserve the stock "tone". Open style with minimum 9" long primary and secondary leads Frequency response 70Hz - 15KHz (0/-1dB reference @ 1KHz) Distortion is less than 1% @ 70Hz YEL 16 Ohm GRN 8 Ohm RED WHT 4 Ohm 2000 CT Ohm BRN COM BLK 70Hz - 15kHz 100W ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power Typical 2000 Ohms 4, 8 & 16 Ohms 100 W 13.24 Ohm 14.44 Ohm 0.110 Ohm 0.175 Ohm 0.279 Ohm Inductance Impedance Primary Brown-Blue Secondary Black-White Secondary Black-Green Secondary Black-Yellow @ 1.0 kHz, 1.0 V OC 4.55 H 30.4 KOhm 11.46 mH 221.4 Ohm 23.64 mH 421.5 Ohm 49.44 mH 786.2 Ohm Leakage Inductance Primary Brown-Blue @ 1.0 kHz, 1.0 V SC 1.280 mH Dielectric Strength Temperature Range 2000VRMS -40 to 105 degC TEST CONDITIONS Keithley 2010 DVM Hp4192a impedance analyzer B L M AD GRN C IN D ON TUR M M AC HA NU F MA G BRN YEL RED D E F BLU A G NOTE: ALL LEADS 9.0" OUT MIN. Dimensions A 4.063” ±0.063 B 3.465” ±0.125 C 3.500” ±0.063 D 3.500” ±0.063 E F G 2.250” ±0.063 2.790” ±0.063 0.187” X 0.300" ±0.015 TYPICAL TEST CIRCUIT PRIMARY R S/ SECONDARY 2 RL * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. B 16 C T E L : TE / Y DA G - BL / 0 W D :4 1 0 -R EW H TDA N / A B R O M CA N K:C E IN BLK WHT DCR Primary Brown-Red Primary Red-Blue Secondary Black-White Secondary Black-Green Secondary Black-Yellow Measurement instruments: D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B Hz W 15k 08 6 0 z - 2 0 0 : 17 70H U: RN R S/ OUT 2 www.hammondmfg.com This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. www.hammondmfg.com
1760W 价格&库存
很抱歉,暂时无法提供与“1760W”相匹配的价格&库存,您可以联系我们找货
