1760K
1760K
    HAMMONDMANUFACTURING
    TRANSFORMER TUBE GUITAR AMP
1760K 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1760K TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER • • • • • • PRIMARY Designed for drop in replacement of original units. Constructed to look similar to original factory units (where possible). Material used & design specifications were kept as close as possible to the original part to preserve the stock "tone". Open style with minimum 9" long primary and secondary leads Frequency response 70Hz - 15KHz (0/-1dB reference @ 1KHz) Distortion is less than 1% @ 70Hz SECONDARY GRN 8 Ohm BLU YEL 4 Ohm 4000 CT Ohm WHT 2 Ohm BRN BLK COM RED 50 Watts 70Hz - 15kHz ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power Typical 4000 Ohms 2, 4 & 8 Ohms 50 W Hz B  5k 0 K z -1 CT 4 /8 DATE 7 6 70 H000  /2 / WHT 1 T S U : 4 OM C T L W A -B N: 5 0 -REDL/GR RN /YE DA B HT A AN K/W IN C BL ADE Y EL M DCR Primary Brown-Blue Secondary Black-White Secondary Black-Yellow Secondary Black-Green C 89.43 Ohms 0.091 Ohm 0.183 Ohm 0.219 Ohm BLK IN D O N TU R M M AC H A NU F MA @ 1.0 kHz, 1.0 V OC 5.38 H 33.8 KOhm 8.53 mH 91.74 Ohm 17.59 mH 172.15 Ohm 33.62 mH 298.4 Ohm Leakage Inductance Primary Brown-Blue @ 1.0 kHz, 1.0 V SC 3.136 mH Dielectric Strength Temperature Range 2000VRMS -40 to 105 degC RED D E BRN G Dimensions A 4.063” ±0.063 B 3.238” ±0.125 C 3.485” ±0.063 D 3.500” ±0.063 E F G 2.000” ±0.063 2.560” ±0.063 0.177” X 0.300" ±0.015 TYPICAL TEST CIRCUIT PRIMARY Keithley 2010 DVM Hp4192a impedance analyzer A NOTE: ALL LEADS 9.0" OUT MIN. TEST CONDITIONS Measurement instruments: D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B BLU GRN F Inductance Impedance Primary Brown-Blue Secondary Black-White Secondary Black-Yellow Secondary Black-Green G R S/ SECONDARY 2 RL OUT * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. R S/ 2 www.hammondmfg.com This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. www.hammondmfg.com
1760K 价格&库存
很抱歉,暂时无法提供与“1760K”相匹配的价格&库存,您可以联系我们找货
