Hook-up Wire Spool Set - 22AWG Solid Core - 6 x 25 ft
PRODUCT ID: 1311
Description
Perfect for bread-boarding, free wiring, etc. This box contains 6 spools of solid-core wire. The
wire is easy to solder to and when bent it keeps its shape pretty well. We like to have a few
spools of this stuff around which is why this set is quite nice! We suggest picking up wire
strippers to match. Wire gauge is 22 AWG which we've found is the best all-around gauge, it
works best with breadboards and perfboards but also fits in terminal blocks nicely
This box has a wooden dowel rod to hold the spools in place and let them spin, and there are
little punch-outs you can pass the wire through so it'll stay nice organized.
Technical Details
Box size: 10" long x 2" wide x 2" high
Weight of Set: 340.71g
External Insulation Diameter: 1.5mm / 0.06"
Weight per Spool: 51g
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1311”相匹配的价格&库存,您可以联系我们找货
