AP.10G GPS/Galileo 1 Stage SMD Active Patch 11.5*10*10mm
Part No:
AP.10G.01
Description:
10mm SMD 14dB Active GPS/Galileo Patch Antenna With Front End Saw Filter
Features:
Unique SMD GPS/Galileo active patch
Wide Input Voltage 1.5V to 3.3V
Ultra low power consumption
RoHS & Reach Compliant
SPE-11-8-100-G
1.
Introduction
3
2.
Specifications
4
3.
Passive Antenna Characteristics
6
4.
Active Antenna Characteristics
9
5.
Radiation Patterns
12
6.
Mechanical Drawing
14
7.
PCB Footprint
15
8.
Recommended Reflow Soldering Profile
16
9.
Packaging
17
Changelog
18
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-11-8-100-G
www.taoglas.com
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
one stage 14dB active GPS/Galileo patch antenna is the smallest SMD GPS/Galileo high
1.The AP.10G.01
Introduction
performance embedded antenna currently available in the world. Using extremely sensitive high dielectric
constant powder formulation and tight process control the 10mm x 10mm x 4mm patch antenna is accurately
tuned to have its frequency band right at 1575.42MHz for GPS/Galileo systems.
SMD structure gives high reliability in integration. With an ultra low power consumption one stage
1.A patented
Introduction
LNA with Saw Filter, this small active patch has the performance of an ordinary active patch, but at only a quarter
of the size.
Typical Applications Include:
1.
Introduction
Medical Devices
Navigation
Sports Tracking
1.The AP.10G
Introduction
has been designed to be directly mounted onto a PCB board via SMD process. With this in mind the
AP.10G is supplied on a tape and reel and is compatible with pick and place machines used in the electronic
component industry. For integration instructions or concerns, please contact your regional Taoglas customer
support team.
SPE-11-8-100-G
www.taoglas.com
2.
Specifications
3.
GNSS Frequency Bands Covered
Antenna L1Characteristics2.
Specifications
L2
L5
L6
GPS/QZSS
3.
1227.6MHz
1176.45MHz
1278.75MHz
L2PT
1246MHz
L1CR
1575.42MHz
L1PT
1602MHz
L5R
L3PT
Antenna
Characteristics
1176.45MHz
1201.5MHz
GLONASS
Galileo
4.
1575.42MHz
E5a
1176.45MHz
E5b
1201.5MHz
E4
1215MHz
E3
1256MHz
E6
1278.75MHz
E2
1561MHz
L1
1575.42MHz
Antenna □Radiation□Patterns3.
Antenna
B1
BeiDou
Characteristics2.
1561MHz
Compass
3.
B2
B3
Specifications
1207.14MHz
1268.52MHz
E5B(B2)/ E6(B3)
1268.56MHz
E2(B1)
1561MHz
Omnistar
1542.5MHz
WAAS/EGN OS
1575.42MHz
Antenna □Characteristics2.
SBAS
Specifications
3.
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Characteristics
4.
Characteristics2.
SPE-11-8-100-G
Specifications
www.taoglas.com
GNSS Electrical
Frequency (MHz)
1575.42 ± 1.023MHz
VSWR (max.)
2.0:1
Gain (Patch)
Typ -10dBic @ Zenith
Gain (Patch and LNA)
8 ± 4dBic @ 90o
Axial Ratio (dB)
Max 4.0dB @ Zenith
Polarization
RHCP
Impedance
50Ω
Connector
SMD via solder pads
LNA and Filter Electrical Properties
Frequency (MHz)
1575.42 ± 1.023MHz
Gain 1.5V - 3.3V
18dB
Noise 1.5V - 3.3V
2.6dB
Power consumption 1.5V - 3.3V
3.5mA
F0=1575.42MHz
F0±30MHz 9dB min.
Outer Band Attenuation
F0±50MHz 14dB min.
F0±100MHz 16dB min.
Pout at 1dB Gain Compression
point
Typ. 1dBm
Mechanical
Planner Dimension
10mm x 10mm x 4mm (add 7.3mm depth for vertical PCB)
Connection
SMD via solder pads
Weight
10g
Enviromental
Operation Temperature
-20°C to + 85°C
Storage Temperature
-30°C to + 85°C
Relative Humidity
40% to 95%
Moisture Senseitvity Level (MSL)
SPE-11-8-100-G
3 (168Hours)
www.taoglas.com
3.
4.
3.1
Return Loss
-1
Characteristics
-3
4.
-5
Return Loss [dB]
4.
-7
-9
-11
Characteristics
-13
-15
1400
4.
1425
1450
1475
1500
1525
1550
1575
1600
1625
1650
1675
1600
1625
1650
1675
1700
Frequency [MHz]
Characteristics
3.2
Efficiency
100%
4.
90%
Antenna
Radiation Patterns
80%
4.
4.
Efficiency [%]
70%
60%
Antenna
Radiation Patterns
50%
40%
30%
20%
10%
4.
0%
Antenna
Patterns3.
1400 Radiation
1425
1450
1475
1500
1525Antenna
1550
1575
1700
Frequency [MHz]
Characteristics
4.
SPE-11-8-100-G
www.taoglas.com
3.3
Average Gain
Aver Gain [dB]
-10
-15
-20
-25
-30
1400
1425
1450
1475
1500
1525
1550
1575
1600
1625
1650
1675
1700
1600
1625
1650
1675
1700
Frequency [MHz]
3.4
Peak Gain
Gain [dBi]
-5
-10
-15
-20
-25
1400
1425
1450
1475
1500
1525
1550
1575
Frequency [MHz]
SPE-11-8-100-G
www.taoglas.com
3.5
Axial Ratio vs Frequency
16
Axial Ratio [dB]
14
L1/E1/B1/G1
12
10
8
6
4
2
1425
1450
1475
1500
1525
1550
1575
1600
1625
1650
1675
1700
Frequency [MHz]
SPE-11-8-100-G
www.taoglas.com
4.
4.
4.1
Group Delay
100
Characteristics
90
80
4.
70
smoothed data
Group Delay (ns)
4.
Raw data
L1/E1/B1/G1
60
50
40
30
Characteristics
10
1.5
1.52
1.54
1.56
1.58
Antenna
Frequency
[GHz]
1.6
1.62
1.64
Characteristics
4.2
Phase Centre Variation
100
4.
90
Antenna
Radiation Patterns
80
70
4.
60
Antenna
Radiation Patterns
PCV [cm]
4.
50
40
30
L1/E1/B1/G1
4.
Antenna
Radiation
Patterns3.
Antenna1600
1500
1525
1550
1575
1625
1650
Frequency [MHz]
Characteristics
4.
SPE-11-8-100-G
www.taoglas.com
4.3
Phase Centre Offset
100
90
80
PCO [cm]
70
60
50
40
L1/E1/B1/G1
30
1525
1550
1575
1600
1625
1650
Frequency [MHz]
4.4
LNA Gain and Out Band Rejection @3.0V
SPE-11-8-100-G
www.taoglas.com
4.5
LNA Noise Figure @3.0V
SPE-11-8-100-G
www.taoglas.com
5.
Radiation Patterns
5.1
Test Setup
4.
4.
Z
4.
4.
X
Antenna Radiation
Patterns
4.
4.
4.
SPE-11-8-100-G
Y
www.taoglas.com
5.2
1575MHz 3D and 2D Radiation Patterns
XY Plane
SPE-11-8-100-G
XZ Plane
YZ Plane
www.taoglas.com
6.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-11-8-100-G
Mechanical Drawing
www.taoglas.com
7.
PCB Footprint
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-11-8-100-G
www.taoglas.com
8.
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
6.
Packaging
Mechanical Drawing
Phase
7.
7.
Profile Features
Pb-Free Assembly (SnAgCu)
Preheat
Temperature Min(Tsmin)
Temperature Max(Tsmax)
Time(ts) from (Tsmin to Tsmax)
150°C
20\0°C
60-120 seconds
Ramp-up
Avg. Ramp-up Rate (Tsmax to TP)
3°C/second(max)
Temperature(TL)
Total Time above TL (tL)
217°C
30-100 seconds
Temperature(TP)
Time(tp)
260°C
2-5 seconds
Reflow
Application
Note
Peak
Time from 25°C to Peak Temperature
7.
8 minutes max
CompositionNote6.
of solder pastePackaging
Application
96.5Sn/3Ag/0.5Cu
Solder Paste Model
7.
SHENMAO PF606-P26
Mechanical
Drawing
6.
Packaging5.
SPE-11-8-100-G
Mechanical Drawing
www.taoglas.com
9.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-11-8-100-G
Mechanical Drawing
www.taoglas.com
Changelog for the datasheet
SPE-11-8-100 - AP.10G.01
Revision: G (Current Version)
Date:
Changes:
Changes Made by:
2021-11-01
Updated Data.
Gary West
Previous Revisions
Revision: F
Revision: A (Original First Release)
Date:
Changes:
Changes Made by:
2021-10-07
Added MSL, updated format
Erik Landi
Date:
Notes:
Author:
2011-10-14
Initial Release
Staff
Revision: E
Date:
Changes:
Changes Made by:
2014-05-13
Added reflow
AINE DOYLE
Revision: D
Date:
Changes:
Changes Made by:
2012-04-03
Staff
Revision: C
Date:
Changes:
Changes Made by:
2012-03-07
Staff
Revision: B
Date:
2012-01-18
Changes:
Changes Made by:
SPE-11-8-100-G
Staff
www.taoglas.com
© Taoglas
SPE-11-8-100-G
www.taoglas.com
很抱歉,暂时无法提供与“AP.10G.01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+156.07743250+18.88965
- 500+148.32553500+17.95146
- 国内价格 香港价格
- 1+202.938211+24.56109
- 100+156.07739100+18.88964
