SPECIFICATION
Part No.
AP.10D.01
Product Name
10mm SMT 25dB Active GPS Patch Antenna
Features
Unique SMT GPS active patch
High performance 25dB LNA
Patented T mounting antenna structure
Ultra low power consumption
RoHS compliant
REVISION STATUS
Version
Date
Page
Revision Description
Prepared
Approved
01
Apr 9th 2008
All
New product
TW Product Centre
Zita Lin
02
Oct 1st 2008
3
Temperature range
Ireland
Dermot O'Shea
02
Oct 23rd 2008
4
Ireland
Dermot O'Shea
Suggested Layout
added
© All Rights Reserved
Taoglas Limited, Unit 7 Peare Campus, Moyne Business Park, Old Dublin Road, Enniscorthy, Co. Wexford, Ireland
www.taoglas.com
1.0 Introduction
The AP.10D.01 active GPS patch antenna is the smallest SMT GPS high performance
embedded antenna currently available in the world. Using extremely sensitive high dielectric
constant powder formulation and tight process control the 10mm x 10mm x 4mm patch
antenna is accurately tuned to have its frequency band right at 1575.42MHz for GPS systems.
A patented T mounting antenna structure gives high reliability in integration. With a low power
consumption two stage LNA , this small active patch has the performance of an ordinary
active patch, but at only a quarter of the size. This product is suited to small form factor
mobile devices such as GPS Smartphones, Personal Location, Medical devices, Telematic
devices and Automotive navigation and tracking. Custom gain, connector and cable versions
are available.
2.0 Specification
Antenna
Frequency
1575.42 ± 1.023MHz
Gain
Typ -3dBic @ Zenith
Impedance
50Ω
Polarization
RHCP
Axial Ratio
Max 4.0dB @ Zenith
Dimension
10mm x 10mm x 4mm (add 7.3mm depth for vertical PCB)
Frequency
1575.42 ± 1.023MHz
LNA
Gain
Noise Figure
Output Impedance
Output VSWR
Min. 23dB, Typ. 25dB @ 25oC ± 5oC
Typ. 1.4dB @ 25oC ± 5oC
Max 1.8dB @ 85oC
50Ω
Max. 2.0
Connection
Connection
SMT via solder pads
www.taoglas.com
Total Specification
Frequency
1575.42 ± 1.023MHz
22 ± 4dBic @ 90o
Gain
Output Impedance
50Ω
Polarization
RHCP
Output VSWR
Max 2.0
Operation
-20°C to + 85°C
Temperature
Storage Temperature
-30°C to + 85°C
Relative Humidity
Input Voltage
Current
40% to 95%
Min. 2.7V,
Typ. 3.0V,
Typ. 10mA,
Max. 3.3V
Max. 13mA
www.taoglas.com
3.0 Technical Drawing
www.taoglas.com
很抱歉,暂时无法提供与“AP.10D.01”相匹配的价格&库存,您可以联系我们找货
