1002292
    ETHERTRONICS
    CIRCUIT/CONN FPC CBL LTE 28.5MM
1002292 数据手册
PRODUCT: Cellular LTE Antenna Part No. 1002292 PresttaTM Standard Octa-Band Cellular Embedded Antenna 700/750/850/900/1800/1900/2100/2700 MHz KEY BENEFITS DESIGN ADVANTAGES Ethertronics’ Prestta series of Isolated Magnetic Dipole™ (IMD) embedded antennas address the challenges facing today’s product designers. IMD’s high performance and isolation characteristics offer better connectivity and minimal interference. Prestta antennas can be used in a variety of applications including:       M2M Automotive Automatic Meter Reading Healthcare Point of Sale Tracking... TECHNOLOGY ADVANTAGES Stays in Tune IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Ethertronics IMD antennas resist de-tuning; providing a robust radio link regardless of the usage position. Prestta antennas use patented IMD technology in a stamped metal configuration to provide high performance. IMD antennas requires a smaller design keep-out area, carry lower program development risk which yields a quicker time-to-market, without sacrificing RF performance. Reduced Costs and Time-to-Market  Standard antenna eliminates design fees and cycle time associated with a custom solution; getting products to market faster. Greater Flexibility with Unique Form Factors  Ethertronics’ IMD technology helps you deliver more advanced ergonomic designs without adverse impact on product performance.  SMD mountable design enables faster and lower cost manufacturing. RoHS Compliant  Ethertronics’ antennas are fully compliant with the European RoHS Directive 2002/95/EC. END USER ADVANTAGES Unique Form Factors Support Advanced Industrial Designs  Smaller, more efficient IMD embedded antennas break through restrictive design rules and provide new freedom in component placement. Superior Range  Better antenna function means longer range and greater sensitivity to critically precise signals—delivering greater customer satisfaction while building brand loyalty. SERVICE AND SUPPORT Extensive RF Experience  Our Prestta antennas are supported by documentation, and when needed, by the expertise of RF engineers who have integrated hundreds of antenna designs into wireless devices. Global Operations & Design Support  Ethertronics’ global operations supports an integrated network of design centers that can take projects from concept to production. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: Cellular Antenna - P/N 1002292 Ethertronics’ Cellular Internal (Embedded) Antenna Specifications. Below are the typical performances for a cellular application. Electrical Specifications Typical Characteristics. Antenna mounted directly on PC + ABS plastic carrier Mechanical Specifications Maximum Dimensions Cable / Connector 85.2 x 42.1 x 0.15 mm (1.25mm high at cable solder connection) U.fl compatible connector, Cable diameter 1.13mm, 28.5mm Cable length. Mounting Antenna backing using 3M468 Adhesive on FPC substrate Antenna Configuration 1 Antenna Configuration 2 Antenna located in Free Space Antenna located at the end of a PCB. 75 mm In this position, the antenna is located 1 mm away from the PCB and 5 mm above the PCB. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: Cellular Antenna - P/N 1002292 Return Loss in dB (Low Band) Free Space Over GND Plane Return Loss, in dB (High Band) Free Space Over GND Plane Typical Low Band Efficiency, 700-960MHz Free Space Over GND Plane Typical High Band Efficiency, 1700-2700MHz Free Space Over GND Plane ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: Cellular Antenna - P/N 1002292 Radiation Patterns Setup Conditions Antenna Configuration 1 Antenna Configuration 2 Antenna located in Free Space Antenna located at the end of a PCB. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: Cellular Antenna - P/N 1002292 Typical Radiation Patterns - Antenna Configuration 1 : In Free Space The Peak gain in the frequency band 700-960MHz is 0.5 dBi. The Peak gain in the frequency band 1710-2200MHz is 3.0 dBi. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: Cellular Antenna - P/N 1002292 Typical Radiation Patterns - Antenna Configuration 2 : Over the Ground Plane The Peak gain in the frequency band 820-960MHz is 3.0 dBi. The Peak gain in the frequency band 1710-2200MHz is 5.0 dBi. © 2013 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Prestta, Isolated Magnetic Dipole and the iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners. Specifications subject to change and are dependent upon actual implementation. 1002292 01FEB2014
1002292 价格&库存
很抱歉,暂时无法提供与“1002292”相匹配的价格&库存,您可以联系我们找货
推荐型号
