P1624
P1624
    LAIRD(莱尔德)
    ANT YAGI VHF ECO 158-162.5MHZ
P1624 数据手册
P-PLC Heavy Duty Yagi Antennas 30-75 MHz / 129-174 MHz PLC1509 HEAVY-DUTY PLC SERIES 7.1 OR 11.1 dBi GAIN Laird's PLC Yagis are heavy-duty point-to-point antennas, commonly used in data transmission and control station applications. With a frequency range of 30-75 MHz and 129-174 MHz they feature a preset Reddi-Match and can be quickly and easily assembled at the installation site. Precisely machined boom-to-element blocks prevent corrosion and noise buildup. Outstanding performance and mechanical integrity make these antennas an excellent value. VHF YAGI SELECTOR GUIDE PLC1506 MODEL FREQ. MHz GAIN NO. F to B -3dB BEAMWIDTH dBi ELEM dB E-PLANEo H-PLANEo CONNECTOR TYPE W/ SURFACE AREA ft2 (m2) 1.49 (0.138) 125 (200) 100 (161) 72 (182.9) 7.2 (3.2) 1.44 (0.133) 125 (200) 100 (161) 70 (177.8) 7.2 (3.2) W/ SURV. mph (kph) W/ 1/2" ICE LENGTH in (cm) WT. lb (kg) PLC-1346 134-142 7.1 6 20 53 74 UHF PLC-1426 142-150 7.1 6 20 53 74 UHF PLC-1506 150-158 7.1 6 20 53 74 UHF 1.39 (0.129) 125 (200) 100 (161) 66 (167.6) 7.2 (3.2) PLC-1586 158-166 7.1 6 20 53 74 UHF 1.34 (0.124) 125 (200) 100 (161) 64 (162.6) 7.1 (3.2) PLC-1666 166-174 7.1 6 20 53 74 UHF 1.29 (0.120) 125 (200) 100 (161) 64 (162.6) 7.0 (3.15) PLC-1369 136-142 11.1 9 20 35 45 UHF 2.77 (0.256) 125 (200) 100 (161) 161 (408.9) 11.1 (5.0) PLC-1509 150-158 11.1 9 20 35 45 UHF 2.42 (0.224) 125 (200) 100 (161) 144 (365.7) 10.3 (4.6) PLC-1589 158-166 11.1 9 20 35 45 UHF 2.32 (0.214) 125 (200) 100 (161) 137 (347.0) 10.4 (4.7) PLC-1669 166-174 11.1 20 35 45 UHF 2.25 (0.208) 125 (200) 100 (161) 131 (332.7) 10.0 (4.5 ) 9 Common specifications: Power handling - 400 Watts; Element material - 1/2 in (1.3 cm) 6063-T832 aluminum tube; Boom material: 1-1/8 in (2.9 cm) 6063-T832 aluminum tube; Maximum mast diameter: 2-1/8 in (5.4 cm); Mounting style; U-bolts and plate. MODEL FREQ. MHz GAIN NO. F to B -3dB BEAMWIDTH dBi ELEM dB E-PLANEo H-PLANEo CONNECTOR TYPE W/ SURFACE AREA ft2 (m2) W/ SURV. mph (kph) W/ 1/2" ICE LENGTH in (cm) WT. lb (kg) 2.7 (1.21) P142-4 138-142.5 6.5 4 18 65 80 UHF 0.53 (0.049) 125 (200) 100 (161) 44 (110) P150-4 146-150.5 6.5 4 18 65 80 UHF 0.52 (0.048) 125 (200) 100 (161) 44 (110) 2.7 (1.21) P154-4 150-154.5 6.5 4 18 65 80 UHF 0.51 (0.047) 125 (200) 100 (161) 44 (110) 2.7 (1.21) P158-4 154-158.5 6.5 4 18 65 80 UHF 0.50 (0.046) 125 (200) 100 (161) 44 (110) 2.7 (1.21) P162-4 158-162.5 6.5 4 18 65 80 UHF 0.49 (0.049) 125 (200) 100 (161) 44 (110) 2.6 (1.17) P166-4 162-166.5 6.5 4 18 65 80 UHF 0.48 (0.044) 125 (200) 100 (161) 44 (110) 2.6 (1.17) P174-4 170-174.5 6.5 4 18 65 80 UHF 0.46 (0.042) 125 (200) 100 (161) 44 (110) 2.6 (1.17) Common Specifications: Power handling - 400 Watts; Element material - 3/16in (.48 cm) 6063-T832 aluminum rod; Boom material: 7/8 in (2.2 cm) 6063-T832 aluminum tube; Maximum mast diameter: 2-1/8 in (5.4 cm); Mounting style; U-bolt and bracket. P-PLC Heavy Duty Yagi Antennas 30-75 MHz / 129-174 MHz Typical 6 Element PLC 0° 0° 30° 330° 30° 330° 10 10 300° 60° 20 300° 30 30 270° 10 20 30 30 20 90° 10 270° 10 20 20 120° 20 20 240° 90° 10 120° 10 10 210° 30 30 30 30 240° 60° 20 150° 180° 150° 210° 180° Typical 9 Element PLC Americas: +1.847 839.6925 IAS-AmericasSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: IAS-AsiaSales@lairdtech.com Middle East and Africa: +44.1628.858941 IAS-MEASales@lairdtech.com www.lairdtech.com ANT-DS-P-PLC Heavy Duty Yagi Antennas 0516 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2016 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
P1624 价格&库存
很抱歉,暂时无法提供与“P1624”相匹配的价格&库存,您可以联系我们找货
