ISM43341-M4G-L44-C
ISM43341-M4G-L44-C
    INVENTEKSYSTEMS
    SMD44
    RF TXRX MOD BLUETOOTH/WIFI CHIP
ISM43341-M4G-L44-C 数据手册
Product Brief Inventek eS-WiFi Family Embedding Connectivity Everywhere Wi-Fi 802.11b/g/n Wireless Networking Module Dual Band WiFi… Bluetooth… NFC… Small Footprint The Inventek ISM43341-M4G-L44 is an embedded wireless Internet Connectivity device that operate in the 2.4 & 5 Ghz spectrum. The Wi-Fi modules hardware consists of a ARM Cortex M4 host processor, Broadcom BCM43341 Dual-Band (2.4 GHz / 5 GHz) 802.11 g/n MAC/Baseband/Radio with Integrated Bluetooth 4.0, and NFC. Also, the device has two antenna options, a dual band chip antenna or an U.Fl connector for external antenna. The module provides USB, SPI and UART interfaces enabling easy connection to an embedded design. The Wi-Fi module requires no operating system and has a complete integrated TCP/IP Stack that only requires a simple AT command set to establish connectivity for your wireless product, minimizing development time and testing . The simple AT command, the low-cost, the small foot-print design (14.70 x 34.22 mm), and the ease of design-in make it ideal for a wide range of embedded wireless applications. Main Features  802.11 a, b, g ,n compliant based on Broadcom MAC/Baseband/Radio device  Bluetooth 4.0 & NFC  Fully contained TCP/IP stack minimizing host CPU requirements  Soft Access Point for up to 4 clients for configuration and ad-hoc networks  Host interfaces: USB (HID/VCP),UART, SPI up to 25 MHz.  Network features ICMP ( Ping), ARP, DHCP,TCP, UDP Configurable though simple AT commands  Low power operation (3.3V supply) built in  FCC and Ce certified in process low power modes  IEEE 802.11 b/g/n complaint  Www.Inventeksys.com Embedding Connectivity Everywhere Product Brief Inventek eS-WiFi Family Embedding Connectivity Everywhere Application Examples  freight management  PDA, Pocket PC, computing devices  Building automation and smart energy control  Industrial sensing and remote equipment monitoring Network Standard RF Frequency Warehousing, logistics and  PC and gaming peripherals  Printers, scanners, alarm and video systems Configuration Supply Voltage Package Operating Temperature IEEE 802.11b/g/n 2.400 GHz ~ 2.497 GHz 802.11n: 6.5, 13, 19.5, 26, 39, 52, 58.5, 65 Mbps 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11b: 1, 2, 5.5, 11 Mbps 802.11g/n: 64-QAM, 16-QAM, QPSK, BPSK 802.11b: CCK, DQPSK, DBPSK WEP (64/128-bit),WPA™ (PSK, TKIP) / WPA2™ (AES, CCMP, 802.1x Authentication) SPI, UART, USB ( HID And VCP) TCP, UDP, IPv4, ARP, ICMP, DHCP Client Power save modes, automatic roaming, auto-rate Ad-hoc and Infrastructure modes AT commands 3.1.2 or WICED SDK 3.1.2 or later 3.3V ± 5% 44-pin LGA, 14.70 mm x 34.22 mm -35°C to +80°C Certifications FCC and CE Data Rates Modulation Techniques Wireless Security Host Interfaces Network Protocols WLAN Functions Device Description Firmware Ordering Number ISM43340-M4G-L44 Wi-Fi 2.4 & 5 GHz 802.11 & Bluetooth 4.0 Module, TCP Stack on STM32F405 (1 Meg Flash) and On board Chip antenna UART or SPI ISM43340-M4G-L44-C ISM43340-M4G-L44 Wi-Fi 2.4 & 5 GHz 802.11 & Bluetooth 4.0, TCP Stack on STM32F405 (1 Meg Flash) and external connector for antenna, FCC certified UART or SPI ISM43340-M4G-L44-U ISM43341-M4G-L44 Wi-Fi 2.4 & 5 GHz 802.11, Bluetooth 4.0 and NFC, TCP Stack on STM32F405 (1 Meg Flash) and On board Chip antenna UART or SPI ISM43341-M4G-L44-C ISM43341-M4G-L44 Wi-Fi 2.4 & 5 GHz 802.11, Bluetooth 4.0 and NFC , TCP Stack on STM32F405 (1 Meg Flash) and external connector for antenna, FCC certified Evaluation Board, USB cable, with ISM43340M4G-L44, Quick Start Guide UART or SPI ISM43341-M4G-L44-U UART ISM43340-M4G-EVB ISM43341-M4G-EVB Evaluation Board with NFC, USB cable, with ISM43341-M4G-L44, Quick Start Guide UART ISM43341-M4G-EVB ISM340-USB USB Wi-Fi / BLE dongle, with ISM43341-M4GL44 or ISM43340-M4G-L44 USB ISM340 –USB ISM43340-M4G-EVB Contact Inventek Systems 2 Republic Road Billerica Ma 01862 Www.Inventeksys.com 978-667-1962 E-mail Sales@Inventeksys.com Engineering@Inventeksys.com www.Inventeksys.com Embedding Connectivity Everywhere ISM341-USB ( Includes NFC)
ISM43341-M4G-L44-C 价格&库存
很抱歉,暂时无法提供与“ISM43341-M4G-L44-C”相匹配的价格&库存,您可以联系我们找货
