RF100PD6
RF100PD6
    SYNAPSE
    模块
    RF TXRX MODULE 802.15.4 RP-SMA
RF100PD6 数据手册
® DATA SHEET RF Engine Model RF100 Part Numbers: RF100PC6 and RF100PD6 Document Revision v1.0 © 2011 Synapse, All Rights Reserved All Synapse products are patented or patent pending Specifications are subject to change without notice – confirm that data is current Synapse, the Synapse logo, SNAP, and Portal are all registered trademarks of Synapse Wireless, Inc. 500 Discovery Drive Huntsville, Alabama 35806 877-982-7888 Doc # 430144-01B Model RF100 Data Sheet Document Number 43014-01B Page 2 of 13 Table of Contents 1.0 Model RF100 OEM Module Overview 1.1 Specifications 1.2 Module Pin Definitions 1.3 Electrical Characteristics 1.4 Mechanical Drawings 1.5 Board Mounting Configurations 2.0 Agency Certifications 2.1 United States (FCC) 2.1.1 OEM Labeling Requirements 2.1.2 FCC Notices 2.1.3 FCC Approved Antennas 2.2 Canada (IC) 2.2.1 OEM Labeling Requirements Model RF100 Data Sheet Document Number 43014-01B 4 5 6 7 8 9 10 10 10 11 11 12 13 Page 3 of 13 1.0 Model RF100 OEM Modules Overview The Synapse RF Engine™ Model Number RF100 is the all-in-one solution to your embedded wireless control and monitoring needs. Just apply power and you’re instantly connected in a SNAP® mesh network. Typical applications include a wireless serial port, sensor monitoring, actuator control, or an intelligent embedded controller. The RF100 offers unmatched performance in a 2.4GHz, IEEE 802.15.4 module. Combined with SNAP firmware, it is the off-the-shelf solution to bring your application to market quickly. SNAP’s on-board Python interpreter provides for rapid application development and over-the-air programming. The RF100 is approved as an FCC Part 15 unlicensed modular transmitter. The modules provide up to 16 channels of operation in the ISM 2.4GHz frequency band. The RF100PD6 module contains both a power amplifier for transmission and a low noise amplifier in the receive path for extended range. This Data Sheet details the RF100PC6 and RF100PD6, which includes: • • • • • • • • • • • SNAP Network Operating System already loaded Powerful, reliable wireless connection in 2.4GHz license-free band Spread spectrum (DSSS) technology surmounts noisy environments Optional, Transmit amplifier (18 dBm) for best-in-class range Receive amplifier (10 dBm) standard Multiple antenna choices: o RF100PD6 – SMA connector (reverse-polarity) for external antenna o RF100PC6 – Embedded “F” antenna Up to 3-mile range Low power modes, down to 1.6 μA with internal timer running Nineteen available general purpose I/Os including: o Up to eight analog inputs with 10-bit ADC o Two UART ports for control or transparent data 60k flash, with 20k free for over-the-air uploaded user applications FCC Certified on all 16 channels Available with AES-128 encryption for added network security (RF150PC6 and RF150PD6) Model RF100 Data Sheet Document Number 43014-01B Page 4 of 13 Figure 1.0 Block diagram showing the major subsystems comprising the RF100 1.1 Specifications Table 1.0 RF100 Specifications Performance Power Requirements General Networking Available I/O Agency Approvals RF100PD6 RF100PC6 Up to 3 miles at 250Kbps 18 dBm 250Kbps -102 dBm (1% PER) 2.7 - 3.4 V 115mA 60mA 1.6uA ISM 2.4 GHz Direct Sequence (DSSS) O-QPSK 1.333" x 1.333" - 40 to 85 deg C. Integrated FAntenna Options External RPSMA Antenna Topology SNAP Error Handling Retries and acknowledgement Number of Channels 16 UARTS with HW Flow Control 2 Ports - 8 total I/O GPIO 20 total; 8 can be analog-in with 10bit ADC FCC Part 15.247 FCC ID: U9O-RFET Industry Canada (IC) IC: 7084A-RFET CE available as a custom part. Call 1-877-982-7888. Model RF100 Data Sheet Outdoor LOS Range Transmit Power Output RF Data Rate Receiver Sensitivity Supply Voltage Transmit Current (Typ@3.3V) Idle/Receive Current (Typ@3.3V) Power-down Current (Typ@3.3V) Frequency Spreading Method Modulation Dimensions Operating Temperature Document Number 43014-01B Page 5 of 13 1.2 Module Pin Definitions Table 1.2 RF100 Module Pin Assignments Pin Name Description 1 GND 2 GPIO0_TPM1CH2 3 GPIO1_KBI0 GPI/O, Keyboard Interrupt 4 GPIO2_KBI1 GPI/O, Keyboard Interrupt 5 GPIO3_RX_UART0 GPI/O, or UART0 Data In 6 GPIO4_TX_UART0 GPI/O, or UART0 Data Out 7 GPIO5_KBI4_CTS0 GPI/O, Keyboard Interrupt, or UART0 CTS output 8 GPIO6_KBI5_RTS0 GPI/O, Keyboard Interrupt, or UART0 RTS input 9 GPIO7_RX_UART1 GPI/O, or UART1 Data In 10 GPIO8_TX_UART1 GPI/O, or UART1 Data Out 11 GPIO9_KBI6_CTS1 GPI/O, Keyboard Interrupt, or UART1 CTS output 12 GPIO10_KBI7_RTS1 13 GPIO11_AD7 GPI/O or Analog In 14 GPIO12_AD6 GPI/O, Analog In, CBUS CDATA, or SPI MOSI 15 GPIO13_AD5 GPI/O, Analog In, CBUS CLK, or SPI CLK 16 GPIO14_AD4 GPI/O, Analog In, CBUS RDATA, or SPI MISO 17 GPIO15_AD3 GPI/O, or Analog In 18 GPIO16_AD2 GPI/O, or Analog In 19 GPIO17_AD1 GPI/O, Analog In, or I2C SDA 20 GPIO18_AD0 GPI/O, Analog In, or I2C SCL 21 VCC 22 PTG0/BKDG 23 RESET* 24 GND Model RF100 Data Sheet Power Supply GPI/O, or Timer1 Channel 2 (ex. PWM out) GPI/O, Keyboard Interrupt, or UART1 RTS input Power Supply Background Debug Communications Module Reset, Active Low Power Supply Document Number 43014-01B Page 6 of 13 1.3 Electrical Characteristics Table 1.3 RF100 DC Characteristics Symbol VCC TOP VIH VIL 2 Parameter Condition Supply Voltage Operating Temp Input Hi Voltage Input Low Voltage VOL Output Low Voltage VOH Output High Voltage ILIN TX-ICC RX-ICC SHDN-ICC In Leakage Current Transmit Current Receive Current Sleep Current Typ Min All Digital Inputs All Digital Inputs All drive strengths (2,4,6,8 mA) All drive strengths (2,4,6,8 mA) VIN=VCC or VSS, all Pins VCC = 3.3V 1 2.7 -40 0.70xVcc Max 3.3 3.6 85 Units 0.35xVcc V °C V V 0.5 V VCC - 0.5 V 0.025 115 60 1.6 VCC = 3.3V 1.0 125 68 uA mA mA uA 1 All typical specifications are measured at 25°C. Absolute maximum stress rated voltage for VCC is -0.3 to 3.6. It is recommended that a bulk decoupling capacitor (47 uF tantalum rated at 6.3volts) be located close to the VCC pin 21 of the RF100 connector on host board. 2 Table 1.4 ADC Electrical Characteristics (Operating) Symbol Parameter Condition VREFH Voltage Reference, High Fixed VINDC Analog input voltage Single Ended Min Typical Max Unit Vcc Vcc+0.3 V Vcc+0.3 V -0.03 Table 1.5 ADC Timing/Performance Characteristics 5 Symbol Parameter RAS RES DNL INL EZS EG Source impedance at input Conversion Resolution Differential non-linearity Integral non-linearity Zero-scale error Gain error Condition Min Typical 5 2.031 ± 0.5 0.8 1.5 1 Max Unit 10k 3.516 kΩ mV LSB LSB LSB LSB Any analog source with a source impedance greater the 3kΩ will increase the sampling time. Model RF100 Data Sheet Document Number 43014-01B Page 7 of 13 1.4 Mechanical Drawings These drawings in Figure 1.1 show both the version of the module with integrated Fantenna and the version of the module with the SMA connector for use with an external antenna. Figure 1.1 Mechanical drawings of the RF100 Modules Model RF100 Data Sheet Document Number 43014-01B Page 8 of 13 1.5 Board Mounting Considerations The RF100 modules are designed to mount into a receptacle (socket) on the host board. Picture 1.1 shows an RF100PD6 module plugged in to a host board. The receptacle sockets are on standard 2mm centers. Suggested receptacles to be used on the host are: 1) 2) Thru-hole receptacle Surface mount receptacle Samtec Samtec MMS-112-01-T-SV MMS-112-02-T-SV It is recommended that the mounting holes provided in the module on either side of the SMA connector be used with supporting mounting hardware to hard mount the module to either the host board or to the enclosure to handle the mechanical stresses that can occur when an external antenna is screwed into the SMA. Picture 1.1 shows the RF100PD6 with SMA connector mounted to the host board. For the module with integrated F-antenna, in order to maximize RF range in the direction behind the module, it is recommended that no components and no metal (either traces or VCC and GND planes) be on any layers of the host board that lies underneath the module in the area designated by the “Keep Out Area” shown in the mechanical drawings of Figure 1.1. Host Board Model RF100 Data Sheet RF100PD6 Mounted Document Number 43014-01B Page 9 of 13 Picture 1.1 RF100PD6 Mounted To Host Board 2.0 Agency Certifications 2.1 United States (FCC) The Model RF100 modules comply with Part 15 of the FCC rules and regulations. Compliance with the labeling requirements, FCC notices and antenna usage guidelines is required. In order to comply with FCC Certification requirements, the Original Equipment Manufacturer (OEM) must fulfill the following requirements. 1. 2. 2.1.1 The system integrator must place an exterior label on the outside of the final product housing the RF100 Modules. Figure 2.1 below shows the contents that must be included in this label. RF100 Modules may only be used with the antenna that has been tested and approved for use with the module. Please refer to the antenna table provided in this section. OEM Labeling Requirements NOTICE: The OEM must make sure that FCC labeling requirements are met. This includes a clearly visible exterior label on the outside of the final product housing that displays the contents shown in Figure 2.1 below. MANUFACTURERS NAME BRAND NAME or TRADE NAME Figure 2.1 FCC Label Contains RF Engine FCC ID: U9O-RFE* This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interferences, and (2) this device must accept any interference received, including interference that may cause undesired operation. * The FCC ID for the RF Engine without external amplifier is “U9O-RFE” which is part number RF100PC1. The FCC ID for the RF Engine with external amplifier is “U9ORFET” which is part number RF100PD1. Model RF100 Data Sheet Document Number 43014-01B Page 10 of 13 2.1.2 FCC Notices WARNING: The RF100 modules have been tested by the FCC for use with other products without further certification (as per FCC Section 2.1091). Changes or modifications to this device not expressly approved by Synapse Wireless Inc. could void the user’s authority to operate the equipment. NOTICE: OEM’s must certify final end product to comply with unintentional radiators (FCC Section 15.107 and 15.109) before declaring compliance of their final product to Part 15 of the FCC Rules. NOTICE: The RF100 modules have been certified for remote and base radio applications. If the module will be used for portable applications, the device must undergo SAR testing. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: • Reorient or relocate the receiving antenna. • Increase the separation between the equipment and receiver. • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. • Consult the dealer or an experienced radio/TV technician for help. 2.1.3 FCC Approved Antennas The RF100 modules are FCC-approved for fixed base station and mobile applications on channels 11 thru 26 of the ISM 2.4GHz frequency band as defined in IEEE 802.15 specifications. The FCC requirement for mobile applications states that the antenna must be mounted at least 20 cm (8 in) from nearby persons. Notice: To reduce potential radio interference to other users, the antenna type and its gain should be chosen so that the equivalent isotropically radiated power (e.i.r.p.) is not Model RF100 Data Sheet Document Number 43014-01B Page 11 of 13 more than that permitted for successful communication. This module has been designed to operate with the antennas listed below in Table 2.1, and having a maximum gain greater than 5dB are strictly prohibited for use with this device. The required antenna impedance is 50 ohms. Table 2.1 Approved FCC Antennas Part Number Type Gain Application Min. Separation AC12000 AC12001 AC12002 AC12003 Dipole (quarter-wave RPSMA) Dipole (half-wave RPSMA) Dipole (quarter-wave RPSMA) Dipole (quarter-wave RPSMA) 3.2dBi 5.0dBi 4.9cBi 2.0dBi Fixed/Mobile Fixed/Mobile Fixed/Mobile Fixed/Mobile 20 cm. 20 cm. 20 cm. 20 cm. RF Exposure WARNING: This equipment complies with FCC radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance 20cm between the radiator and your body. This transmitter must not be co-located or operating in conjunction with any other antenna or transmitter. NOTICE: The preceding statement must be included as a CAUTION statement in OEM product manuals in order to alert users of FCC RF Exposure compliance. 2.2 Canada (IC) This device complies with Industry Canada license-exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of the device. Under Industry Canada regulations, this radio transmitter may only operate using an antenna of a type and maximum (or lesser) gain approved for the transmitter by Industry Canada. To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (e.i.r.p.) is not more than that necessary for successful communication. This radio transmitter Model: RF100, IC: 7084A-RF100 has been approved by Industry Canada to operate with the antenna types listed below with the maximum permissible gain and required antenna impedance for each antenna type indicated. Antenna types not included in this list, having a gain greater than the maximum gain indicated for that type, are strictly prohibited for use with this device. Table 2.2 Approved IC Antennas Part Number Type Gain Application Min. Separation AC12000 AC12001 AC12002 AC12003 Dipole (quarter-wave RPSMA) Dipole (half-wave RPSMA) Dipole (quarter-wave RPSMA) Dipole (quarter-wave RPSMA) 3.2dBi 5.0dBi 4.9cBi 2.0dBi Fixed/Mobile Fixed/Mobile Fixed/Mobile Fixed/Mobile 20 cm. 20 cm. 20 cm. 20 cm. Model RF100 Data Sheet Document Number 43014-01B Page 12 of 13 2.2.1 OEM Labeling Requirements Labeling requirements for Industry Canada are similar to those of the FCC. A clearly visible label on the outside of the final product housing must display the contents shown in Figure 2.2 below. Figure 2.2 IC Label MANUFACTURERS NAME BRAND NAME or TRADE NAME MODEL: Contains RF Engine IC: 7084A-RFE* * The IC ID for the RF Engine without amp is “7084A-RFE” which is part number RF100PC1. The IC ID for the RF Engine with amp is “7084A-RFET” which is part number RF100PD1. NOTE: The OEM can choose to implement a single label combined for both FCC and IC labeling requirements. If a combined single label is chosen, there must be a clearly visible label on the outside of the final product housing displaying the contents shown in Figure 2.3 below. MANUFACTURERS NAME BRAND NAME or TRADE NAME Figure 2.3 Combined FCC and IC Label Contains RF Engine FCC ID: U9O-RFE* Contains RFEngine IC: 7084A-RFE* This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interferences, and (2) this device must accept any interference received, including interference that may cause undesired operation. * The FCC ID for the RF Engine without amp is “U9O-RFE” and the IC ID is “7084ARFE” which is part number RF100PC1. The FCC ID for the RF Engine with amp is “U9O-RFET” and the IC ID is “7084ARFET” which is part number RF100PD1. Model RF100 Data Sheet Document Number 43014-01B Page 13 of 13
RF100PD6 价格&库存
很抱歉,暂时无法提供与“RF100PD6”相匹配的价格&库存,您可以联系我们找货
