ISM4390-M3H-L44-ED
ISM4390-M3H-L44-ED
    INVENTEKSYSTEMS
    模块
    RF TXRX MODULE WIFI TRACE + U.FL
ISM4390-M3H-L44-ED 数据手册
INVENTEK SYSTEMS EMBEDDED WIRELESS SOLUTIONS The IoT / Cloud Ready Solution Inventek Serial-to-Wi-Fi Portfolio All eS-WiFi (embedded Serial ) Wi-Fi modules have the following main features:  802.11 a/b/g/n Wi-Fi protocol support based on Broadcom WICED Technology.  Integrated TCP/IP Stack residing on Cortex ARM microcontroller.  AT command set or Broadcom WICED Firmware  Connects to any 8/16/32 bit host micro- computer.  Simultaneous STA and Access Point  Cloud connected options  Host Interfaces include UART and SPI (USB for select modules).  WEP, WPA, WPA2 and WPS Part Number Wi-Fi BT BLE NFC Band GHZ Micro Host Interface Antenna Dimensions (mm) Package FCC/IC Approved ISM4390-M3H-L44-ED Wi-Fi 2.4 Cortex M3 (48 MHz) UART-1Mbps + Micro-strip or External 14.5 x 30 44-pin LGA In Process ISM90—L57 Wi-Fi 2.4 Cortex M3 (48 MHz) UART-1Mbps + None 10.5 x 10.5 57- pin LGA No UART-1 Mbps, SPI5Mbps, USB HID External - U.FL Connector 14.5 x 30 44-pin LGA Yes ISM43362-M3G-L44-U Wi-Fi 2.4 Cortex M3 (120MHz) ISM43362-M3G-L44-E Wi-Fi 2.4 Cortex M3 (120MHz) UART-1 Mbps, SPI5Mbps, USB HID Micro-strip Etched 14.5 x 30 44-pin LGA Yes ISM43340--M4G-L44-C Wi-Fi BT BLE 2.4 & 5 Cortex M4 (168 MHz) UART-1Mbps, SPI5Mbps Chip or External 14.5 x 30 44-pin LGA In Process ISM43341--M4G-L44-C Wi-Fi BLE BT NFC 2.4 & 5 Cortex M4 (168 MHz) UART-1Mbps, SPI5Mbps Chip or External 14.5 x 30 44-pin LGA In Process eS-WiFi USB with integrated TCP/IP stack Part Number Wi-Fi Band Host Interface Antenna Dimensions (mm) Package ISM43362-M3G-USB 2.4 GHz USB HID 300 Kbps Internal Stamped Metal 10 x 17 w/o USB Connector USB Dongle Design Today and upgrade to latest 802.11 standards in the same footprint ! Talk advantage of future features and lower cost solutions ! Wi-Fi SIP Modules Inventek Systems offers Wi-Fi SIP modules for higher volume applications running a full Operating Systems 802.11 a/b/g/n Wi-Fi SIP based on Broadcom WiFi Technology.  IEEE 802.11b (DSSS 11Mbps)  72.2 Mbps for a single 802.11n stream  IEEE 802.11i (security)  Complete Drivers for Linux and Android Operating Systems  WPA™, WPA2™ (Wi-Fi Protected Access)  IEEE 802.11n D7.0 (OFDM 72.2 Mbps in single stream with 20MHz, Short GI)  4 bit SDIO interface for WLAN  4-Wire Bluetooth co-existence handshake interface support.   (DSSS 11Mbps) IEEE 802.11g (OFDM 54 Mbps) and IEEE 802.11b Part Number Wi-Fi BT BLE NFC Band GHz Host Interface Drivers Available Antenna Dimensions (mm) Package FCC/IC Approved ISM43362-L36 Wi-Fi 2.4 SDIO Linux, Android Micro-strip or external 24.4 x 14.5 36-pin LGA Yes ISM43362-B81 Wi-Fi 2.4 SDIO Linux, Android None 8.1 x 8.6 81 pin BGA No ISM43340-L77 Wi-Fi BT, BLE 2.4 & 5 SDIO Linux, Android None 13.3x 14.5 77 pin LGA No ISM43341-L77 Wi-Fi BT, BLE , NFC 2.4 & 5 SDIO Linux, Android None 13.3x 14.5 77 pin LGA No SIP DRIVERS BY PLATFORM Kernel Version Distribution BROADCOM BCM5892 TI SITARA Atmel SAM9N12 Intel x86 (x32) Intel x86 (x64) Freescale IMX Linux 3.x Ubuntu In development Q1 15 Available Available Available Available In development Q1 15 Linux 3.x Angstrom In development Q1 15 Available Available Available Available In development Q1 15 Linux 2.x Fedora In development Q1 15 Available Available Available Available In development Q1 15 Android TBD TBD In development Q1 15 In development Q1 15 In development Q1 15 In development Q1 15 In development Q1 15 In development Q1 15 Robust and Simple AT Commands (IWIN) Fast Time to Market      OS Independent—No drivers required No need for extensive networking or WiFi knowledge Soft Access Point for Wi-Fi network connects in end products Direct Connect option allow for simple peer to peer network Cloud Agents Ported to run on eS-WiFi Modules Simple Commands       Joining to network WiFi Security: WEP/WPA/WPA2-Personal Auto-connect on power up Scanning for networks Pinging Power Save Modes Making TCP or UDP connections Sending & Receiving Data Control of Only 8 AT Commands to send data ( IWIN ) Joining a Network Creating a Connection 1.C1=Inventek (Set SSID) 1.P2=5300 (Set TCP Local Port) 2.C2=hav3fun (Set Password ) 2.P5=1 (Start TCP Server) 3.C3=2 (Set Security Type) Sending & Receiving Data 4.C0 (Join Network ) 1. S0\r48415645 (Send Data) Four simple commands and your connected! 2. R0 (Receive Data) 48415645 Production Ready IOT Solutions Connecting Anything, to Anyone, at Anytime –Home Appliances –Medical Devices –HVAC Systems –Sensors –Energy Meters –Consumer Devices –Environmental Monitors. Simply Connecting Embedded Devices The Wi-Fi module hardware consists of an Cortex M3 host processor, integrated antenna and Broadcom Wi-Fi radio. The module has an USB, SPI and UART interfaces enabling connection in an embedded design. The Wi-Fi module requires no operating system and has a complete integrated TCP/IP Stack that only requires a simple AT command set to establish connectivity for any wireless product, minimizing development time, testing routines and certification. Typical Applications: PDA, Pocket PC, computing devices Building automation and smart energy control. Industrial sensing and remote monitoring. Warehousing, logistics and freight management PC and gaming peripherals Printers, scanners, alarm and video systems Medical applications Patient monitoring and remote diagnostics SoftAP Configuration: SoftAP is Running on eS-WiFi in a thermostat. The SoftAP will be accessed by a iPad, PC or Smartphone as a web browser to configure the Thermostat as a client on a network. 6-8 Wires Interconnect: eS-WiFi only requires six connections to integrate a UART (serial to Wi-Fi ) 802.11 b/g/n Wi-Fi solution to your embedded device. Complete with FCC certification Inventek integrates Cypress PSOC and Broadcom Wi-Fi for Embedded Device to Device Communication Wirelessly Managing the “health” of the system Managing environmental sensors (e.g. temp, humidity, lighting, power supplies, system cooling in real-time, system communications, Providing simple user interface and debug ports, Managing system communications Wirelessly Connect the “health” of the system to the Cloud Wirelessly Control the “health” of the system with your Smartphone Inventek Wi-Fi Evaluation Boards Inventek eS-WiFi Evaluation Boards The Inventek evaluation boards support supports the family of eS-Wifi 802.11 Wi-Fi modules. The modules are designed with a complete integrated TCP/IP stack and come with a simple to use AT command set making embedded Wi-Fi into your device simple. The eS-Wifi has a family of footprint compatible modules Based on Broadcom's leading edge WI-Fi radio’s. The Standard 44 pin Land Grid package allows simple migration for future cost reduction platforms. Part Number Description Availability ISM43362-M3G-E-EVB Serial to WiFi EVB , Broadcom BCM43362, STMF205, External Antenna ( Optional Ext.) Production ISM4390-M3H-ED-EVB Serial to WiFi EVB , Broadcom BCM4390 Sampling –9/14 ISM43341-M4G-L44-E Serial to WiFi EVB , Broadcom BCM4341, STMF405, Etched Antenna Sampling—10/14 Evaluation Boards Overview Cypress PSOC 3 or PSOC 5 Evaluation The Inventek evaluation boards support supports the family of Cypress PSOC 3 and PSOC 5 EVB’s. A simple custom PSOC module allows you to us the custom created PSOC creator to drag and drop a connection to any of the eS-Wi-Fi modules. The kit comes with a simple to use user guide, drivers and real life applications to create a wireless emPart Number Description Availability ISM4319-M3G-PSOC-EVB Serial to WiFi EVB , Broadcom BCM4319, STMF205, Etched Antenna Production CONTACT US and start your Embedded Connected design today INVENTEK SYSTEMS WIRELESS MODULE OFFERING: LEADING THE SMART, TIME TO MARKET IoT REVOLUTION Inventek Systems Corporate Office Contact Inventek Systems 2 Republic Road Billerica Ma 01862 978-667-1962 E-mail Sales@Inventeksys.com Engineering@Inventeksys.com www.Inventeksys.com Inventek Systems Sales Representatives: http://www.inventeksys.com/sales-reps/ Inventek Channel Partners/ Distributors: America : Japan : Canada : Mexico: Europe: Arrow Corporation, Avnet, Digi-Key, Macnica Macnica Arrow Corporation, Avnet, Digi-Key, Macnica, Motion Micro Arrow Corporation Texim – Europe
ISM4390-M3H-L44-ED 价格&库存
很抱歉,暂时无法提供与“ISM4390-M3H-L44-ED”相匹配的价格&库存,您可以联系我们找货
