WIRELESS / XBEE
XBee Adapter kit - v1.1
PRODUCT ID: 126
DESCRIPTION
This adapter board is designed to make adding wireless point-to-point or mesh
networking easy. I looked at all the XBee adapter boards available and decided to
design something better:
• Onboard 3.3V regulator to cleanly power your XBee, up to 250mA
• Level shifting circuitry means that its trivial to connect it to 5V circuitry such
as an Arduino without risk of damage
• Two LEDs, one for activity (RSSI), the other for power (Associate)
• 10-pin 2mm sockets included to protect the modem and allow easy
swapping, upgrading or recycling
• All the commonly used pins are brought out along the edge, making it easy to
breadboard or wire up
• Specifically created for use with an FTDI cable to connect to a computer via
USB. This means that you can use or upgrade the adapter with a computer simply
by plugging in a cable
• Works with XBee series 1 and 2 as well as Series 1&2 Pro modules
The kit includes a PCB and all components necessary to build the adapter,
unassembled. Tools are not included. This kit is really easy and will only take 15
minutes to build, even if you've never soldered before.
Please note that the adapter does not include an XBee module, they must be
purchased separately. Check out this page for a comparison of all the XBee's
available. If you want to connect this up to a computer's USB port you'll need a FTDI
cable or FTDI friend (also not included)
For more information, check out the project page for instructions, documentation,
tutorials and example code!
http://www.adafruit.com/products/126
7/16/2015
很抱歉,暂时无法提供与“126”相匹配的价格&库存,您可以联系我们找货
