Product Specifications
PART NO.:
VL470T5763A-E6YA
REV: 1.0
General Information
2GB 256Mx64 DDR2 SDRAM NON-ECC UNBUFFERED SODIMM 200-PIN
Description
The VL470T5763A is a 128Mx64 DDR2 SDRAM high density SODIMM. This single rank memory module consists of
eight CMOS 256Mx8 bits with 8 banks DDR2 synchronous DRAMs in BGA packages and a 2K EEPROM in an 8-pin
TSSOP package. This module is a 200-pin small-outline dual in-line memory module and is intended for mounting
into an edge connector socket. Decoupling capacitors are mounted on the printed circuit board for each DDR2
SDRAM.
Features
Pin Description
200-pin, small-outline dual in-line memory module (SODIMM)
JEDEC pin out
Fast data transfer rate: PC2-5300
VDD = VDDQ = 1.8V +/-0.1V
JEDEC standard 1.8V (SSTL_18 compatible)
VDDSPD = 1.7V to 3.6V
Differential data strobe (DQS, DQS# ) option
Differential clock inputs (CK, CK#)
Four-bit pre-fetch architecture
DLL aligns DQ and DQS transition with CK
Nominal and dynamic on-die termination (ODT)
Programmable CAS# latency: 5 (DDR2-667)
Write latency = Read latency - 1 tCK
Eight internal component banks for concurrent operation
Programmable burst; length (4, 8)
Adjustable data-output drive strength
Auto & self refresh, (8K/64ms refresh)
Serial presence detect (SPD) with EEPROM
Gold edge contacts
Lead-free, RoHS compliant
PCB: Height 30.00mm (1.181”), double sided component
o
o
Operating temperature (TOPER): - Commercial (0 C
很抱歉,暂时无法提供与“VL-MM8-2SBN”相匹配的价格&库存,您可以联系我们找货
