SW
X
00
PANEL SWITCHES
O
M
8
77
1
91
-1
M
13000X778 series
High performance pushbutton switches •
threaded bushing Ø 11.9 mm • momentary
DISTINCTIVE FEATURES
Fully sealed, black
Double shell case for high mechanical strength
and electrical insulation
CECC approved (CECC 96401-001)
Highly reliable contacts
Compact size
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load : 4 A 28 VDC
• Minimum load : 10 mA 50 mV, 10 µA 5 VDC
When used above 300 mA 28 VDC, the gold plating is removed
on contact areas and is considered only as a protection
against oxidation during storage.
• Initial contact resistance : 10 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength :
1,000 Vrms 50 Hz min. between terminals
2,000 Vrms 50 Hz min. between poles
2,000 Vrms 50 Hz min. between terminals and frame
• Contact bounce : 2 ms max.
• Electrical life :
- At 4 A 28 VDC : 10,000 cycles
- At low level (50 mV 10 mA) : 150,000 cycles
Volts
250 VAC
125 VAC
48 VDC
28 VDC
5 VDC
50 mV
Amps
10µA
10mA
1A
2A
4A
The company reserves the right to change specifications without notice.
1
ENVIRONMENTAL SPECIFICATIONS
• Front panel sealing : IP67 according to IEC 60529
• Shock test : 50 g - 11 ms (IEC 68-2-27)
• Vibrations : 10-500 Hz - 10 g (IEC68-2-6)
• Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F)
• Humidity test : 56 days, 93 % R.H., 40 °C (IEC 68-2-3)
• Salt spray test : 96 hours (IEC 68-2-11)
SEALING
• Front panel sealing by two O-rings
• Panel seal withstands 1 bar pressure and
remains sealed even when the switch is
operated.
• Epoxy sealed terminals
• Splash-proof case
GENERAL SPECIFICATIONS
- O-ring
• Total travel : 2 mm (.078) - Pre-travel : 1 mm (.039)
• Torque : 1.50 Nm (1.10 Ft.lb) max. applied to nut
• Panel thickness : 5 mm (.196) max.
• Actuator : brass, black chrome plated
4.10
(.161)
• Case : diallylphthalate (DAP)
with PBT external shell (epoxy sealed)
1.20
(.047)
2.50
(.098)
• Bushing : brass, black chrome plated
8.60
(.338)
TERMINALS
MATERIALS
1.70
(.066)
PANEL SWITCHES
13000X778 series
1.00
(.039)
• Contacts : silver inlay - gold plated over nickel barrier
APEM products may be recycled at end-of-life for the re-claiming of valuable metal
components.
ELECTRICAL FUNCTION
FLAT
AGENCY APPROVALS
CECC 96401-001
Many double pole models have full CECC approval.
Consult factory for details of approved models. To
order switches marked CECC, complete appropriate
box of ordering format.
1
3 2
PANEL CUT-OUT
Ø12.00
(.472 DIA)
5.10
(.200)
2
POSITIONS AND CONNECTIONS
BUTTON POSITION
AND CONNECTIONS
I
II
Function
DOUBLE POLE
13245
13445
ON
A 1-2
B 1-2
MOM
A 1-2
B 1-2
C 1-2
FLAT
A 1-3
B 1-3
THREE POLE
13255
13455
TERMINAL
IDENTIFICATION
A 1-3
B 1-3
C1-3
2
A
2
3
3
1
B
1
C
2
A
2
3
3
1
1
C135XPC
I
II
• Pre-travel : 1 mm (.039)
• Over-travel : 1 mm (.039)
C135XPC
1-06-2012
Ech:0.65
3
PANEL SWITCHES
13000X778 series
PANEL SWITCHES
13000X778 series
BUILD YOUR PART NUMBER
BASIC PART NUMBER
13
NUMBER OF POLES
SERIES
4
Double pole
-4
4 mm (.157) long
5
Three pole
-9
9 mm (.354) long
2
4
Solder lug terminals,
threaded bushing
Ø 11.9 (15/32)
X778
ELECTRICAL FUNCTION
TERMINALS AND BUSHINGS
Straight PC terminals,
threaded bushing
Ø 11.9 (15/32)
PLUNGERS
5
ON - MOM
High performance fully
sealed black switches.
OPTIONS
AGENCY APPROVAL
CECC
Double pole only
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice : please note that not all combinations of above numbers are available. Refer to following pages for further information.
Sealing boots can be used to further protect the switches against dust and water. See "Sealing Boots" section of website.
Mounting accessories : standard hardware supplied with all models : 1 hex nut 14 (.551) across flats, part number U41. The nut is
presented after basic models.
Switch guard available to prevent inadvertent plunger operation. See "Switch Guards" section of website.
4
FLAT
SOLDER LUG TERMINALS
DOUBLE POLE - 4 MM (.157) PLUNGER
16.00
(.629)
7.50
(.295)
ON
4.10
(.161)
1.50
(.059)
Ø11.90-32UNS
(15/32-32UNS)
MOM
15.10
(.594)
6.00
(.236)
Ø8.00
(.314 DIA)
13445-4X778
5 Maxi
(.196 Max)
2.50
(.098)
EPOXY
4.00
(.157)
16.00
(.629)
0.50
(.019)
4.00
(.157)
FLAT
DOUBLE POLE - 9 MM (.354) PLUNGER
16.00
(.629)
7.50
(.295)
ON
4.10
(.161)
1.50
(.059)
Ø11.90-32UNS
(15/32-32UNS)
MOM
15.10
(.594)
6.00
(.236)
Ø8.00
(.314 DIA)
13445-9X778
5 Maxi
(.196 Max)
2.50
(.098)
EPOXY
4.00
(.157)
16.00
(.629)
0.50
(.019)
9.00
(.354)
FLAT
16.00
(.629)
7.50
(.295)
Ø1.60
(.062 DIA)
1.50
(.059)
6.00
(.236)
Ø11.90-32UNS
(15/32-32UNS)
MOM
6.00
(.236)
ON
Ø8.00
(.314 DIA)
13245-4X778
8.60
(.338)
15.10
(.594)
5 Maxi
(.196 Max)
1.00
(.039)
EPOXY
4.00
(.157)
16.00
(.629)
4.00
(.157)
0.50
(.019)
STRAIGHT PC TERMINALS
4.00
(.157)
FLAT
16.00
(.629)
7.50
(.295)
6.00
(.236)
MOM
Ø1.60
(.062 DIA)
1.50
(.059)
6.00
(.236)
ON
Ø11.90-32UNS
(15/32-32UNS)
8.60
(.338)
15.10
(.594)
1.00
(.039)
13245-9X778
5 Maxi
(.196 Max)
Ø8.00
(.314 DIA)
EPOXY
4.00
(.157)
16.00
(.629)
9.00
(.354)
0.50
(.019)
4.00
(.157)
5
PANEL SWITCHES
13000X778 series
22.00
(.866)
7.50
(.295)
MOM
6.00
(.236)
Ø8.00
(.314 DIA)
ON
4.10
(.161)
1.50
(.059)
Ø11.90-32UNS
15/32-32UNS
13455-4X778
15.10
(.594)
6.00
(.236)
5 Maxi
(.196 Max)
2.50
(.098)
EPOXY
4.00
(.157)
16.00
(.629)
4.00
(.157)
0.50
(.019)
FLAT
THREE POLE - 4 MM (.157) PLUNGER
22.00
(.866)
7.50
(.295)
C1345XDT4
16.00
(.629)
9.00
(.354)
0.50
(.019)
FLAT
THREE POLE - 9 MM (.354) PLUNGER
Le:01-06-2012
1.50
(.059)
Ø11.90-32UNS
15/32-32UNS
MOM
4.10
(.161)
6.00
(.236)
ON
echelle: 0.65
15.10
(.594)
6.00
(.236)
Ø8.00
(.314 DIA)
13455-9X778
5 Maxi
(.196 Max)
2.50
(.098)
EPOXY
4.00
(.157)
C1345XDT4
22.00
(.866)
7.50
(.295)
C1345XDT9
16.00
(.629)
4.00
(.157)
0.50
(.019)
FLAT
Ø11.90-32UNS
15/32-32UNS
MOM
(.338)
Le:01-06-2012
Ø1.60
(.062 DIA)
6.00
(.236)
1.50
(.059)
echelle:8.60
0.65
6.00
(.236)
ON
15.10
(.594)
Ø8.00
(.314 DIA)
13255-4X778
5 Maxi
(.196 Max)
1.00
(.039)
EPOXY
4.00
(.157)
C1345XDT9
6.00
(.236)
4.00
(.157)
22.00
(.866)
7.50
(.295)
6
Ø1.60
(.062 DIA)
6.00
(.236)
MOM
1.50
(.059)
6.00
(.236)
ON
Ø11.90-32UNS
15/32-32UNS
C1325XDT4
echelle: 0.65
Le:01-06-2012
6.00
(.236)
13255-9X778
8.60
(.338)
5 Maxi C1325XDT4
15.10
(.196 Max)
(.594)
1.00
(.039)
EPOXY
4.00
(.157)
16.00
(.629)
9.00
(.354)
0.50
(.019)
FLAT
Ø8.00
(.314 DIA)
PANEL SWITCHES
13000X778 series
4.00
(.157)
STANDARD HARDWARE - HEX NUT
14.00
(.551)
2.30
(.090)
U41 (black)
Ø11.9-32UNS
(15/32-32UNS)
AGENCY APPROVAL
BASIC P/N
CECC CECC 96401-001 (double pole only)
Blank No agency approval required.
Marking : to order switches marked CECC, please complete above box with CECC.
7
PANEL SWITCHES
13000X778 series
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
134454X778
很抱歉,暂时无法提供与“134454X778”相匹配的价格&库存,您可以联系我们找货
