XL-3216SURUBC
Technical Data Sheet
1206红蓝
Characteristic
* 外观尺寸(L/W/H):3.2*1.6*0.8mm
Outline Dimensions (L / w / h): 3.2x1.6x0.8mm
* 发光颜色及胶体: 高亮度红蓝双色/透明胶体
Luminous color and colloid: high brightness Red and blue / transparent colloid
* 环保工艺符合ROHS标准
Environmental protection products meet ROHS requirements
* EIA规范标准包装
EIA standard packaging
* 适用于SMT贴片自动化生产
And is suitable for automatic production of SMT patches
* 适用于回流焊制程
Suitable for reflow soldering process
Product application
* 医用设备:内窥镜、血氧仪
Medical equipment: endoscope、oximeter
* 汽车电子: 背光按键灯、指示灯
Automotive electronics: backlight key light、 indicator light
* 工业产品:电子仪表盘、工业设备
Industrial products: electronic instrument panel、industrial equipment
* 智能家居: 白色家电、数码管LED
Smart home: white appliances, nixie tube LED
* 通讯产品: 手机按键灯、路由器、电视盒
Communication products: mobile phone button lamp, router
1
Catalogue
Electrical Characteristics.............................................................................................................................3
Reliability Test Items And Conditions.............................................................................................................6
Typical photoelectric characteristic curve................................................................................................7
Outline Dimensions.......................................................................................................................................8
Packaging......................................................................................................................................................9
Guideline for Soldering.............................................................................................................................. 11
Precautions....................................................................................................................................................13
2
极限参数 Limit parameters(Ta=25℃):
参 数
parameter
符 号
Symbol
最大额定值
Maximum rating
消耗功率
Power consumption
Pd
最大脉冲电流(1/10占空比,0.1ms脉宽)
Maximum pulse current (1 / 10 duty cycle,
0.1ms pulse width)
IFP
正向直流工作电流
Forward DC working current
IF
反向电压
Reverse voltage
VR
工作环境温度
Working ambient temperature
Topr
-30°C ~ + 85°C
存储环境温度
Storage ambient temperature
Tstg
-40°C ~ + 90°C
焊接条件
Welding conditions
Tsol
抗静电能力
Antistatic ability
ESD
R
55
B
80
R
100
B
100
R
25
B
25
R
5
B
5
单 位
Unit
mW
mA
mA
V
回流焊Reflow soldering : 260°C ,10s
手动焊Manual welding : 300°C ,3s
2000
V
3
Electro-Optical Charasteristics
参数
parameter
符号
Symbol
光强
lightintensity
IV
半光强视角
Half light angle
2θ1/2
峰值波长
Peak wavelength
主波长
Main wavelength
半波宽
Half wave width
正向电压
Forward voltage
反向电流
Reverse current
备注:
Remarks:
λP
λD
Δλ
VF
IR
(Temperature=25°C)
颜色
colour
最小值
Min
代表值
Typ
最大值
Max
红
Red
150
蓝
Blue
180
120
红
Red
630
蓝
Blue
470
红
Red
620
630
蓝
Blue
465
475
红
Red
蓝
Blue
30
红
Red
1.8
2.6
蓝
Blue
2.8
3.5
红
Red
1
蓝
Blue
单位
Unit
测试条件
Test
conditions
mcd
IF = 20mA
deg
IF = 20mA
nm
IF = 20mA
nm
IF = 20mA
nm
IF=20mA
V
IF=20mA
uA
VR=5V
1
1. 发光强度是由光纤和过滤器的组合测定的,因此接近视觉感应曲线
1. The luminous intensity is measured by the combination of optical fiber and filter, so it is close to the visual
induction curve
2.半光强视角是轴向发光强度一半时的离轴角.
2. The angle of half light intensity is the off-axis angle when the axial luminous intensity is half
3. 主波长λd源自CIE色度图,代表单一的波长,它定义了器件的颜色
3. Main wavelength λ D is derived from CIE chromaticity diagram, representing a single wavelength, which
defines the color of the device
4
Brightness grading
颜色
Colour
代码
Code
最小值
Minimum value
最大值
Maximum
红Red
E53
37
59
蓝Blue
K68
53
77
单位
Unit
测试条件
Test conditions
mcd
IF=5mA
Voltage grading
颜色
Colour
代码
Code
最小值
Minimum value
最大值
Maximum
红Red
F4
1.9
2.1
蓝Blue
A07
2.6
2.8
单位
Unit
V
测试条件
Test conditions
IF=5mA
Wavelength grading
颜色
Colour
代码
Code
最小值
Minimum value
最大值
Maximum
红Red
HR21
619
624
蓝Blue
HB06
469
472
单位
Unit
nm
测试条件
Test conditions
IF=5mA
5
测试项目
Test items
测试条件
Test conditions
测试次数
Number of tests
参考标准
Reference
standard
失效判
定
标准
Failure
determi
nation
standar
d
JEITA ED4701
300.301
﹟1
0/22
JEITA ED4701
303 303A
﹟2
0/22
300 个循环
300 cycles
JESD22A104
﹟1
0/22
300 个循环
300 cycles
JESD22A106
﹟1
0/22
失效LED数
量(PCS
)Number
of failed
LEDs
(PCS)
1. 回流焊最高温度=260℃
,10秒,2次回流焊;
1. Maximum temperature of
reflow soldering =260 ℃, 10
防潮等级
Moisture proof
grade
seconds, 2 reflow soldering;
2.回流焊之前存储条件:30
℃,相对湿度=70%,168H
;2. Storage conditions
before reflow soldering: 30
℃, relative humidity =70%,
168h;
回流焊最高温度=245±5℃
焊接信赖性
(无铅回流焊)
Welding
reliability
(lead free
reflow
soldering)
冷热循环
thermal cycling
冷热冲击
Thermal Shock
,5秒(无铅回流焊)
reflow soldering =245 ± 5
℃, 5 seconds (lead-free
reflow soldering)
-40℃ 30分钟~25℃ 5分钟~
100℃ 30分钟~25℃ 5分钟
-40 ℃ for 30 minutes ~ 25
℃ for 5 minutes~
100 ℃ for 30 minutes ~ 25
℃ for 5 minutes
-35℃ 15分钟
转换时间3分钟
85℃ 15分钟
-35 ℃ for 15 minutes
Conversion time 3 minutes
85 ℃ for 15 minutes
6
高温存储
High temperature storage
Ta=100℃
1000 小时
1000 hours
JESD22A103
﹟1
0/22
低温存储
Low temperature storage
Ta=-40℃
1000 小时
1000 hours
JESD22A119
﹟1
0/22
常温老化
Normal temperature
aging
Ta=25℃
IF=20mA
1000小时
1000 hours
JESD22A108
﹟1
0/22
失效标准:
Failure criteria
标准﹟
standard
﹟1
﹟2
项目
project
测试条件
Test conditions
失效标准
Failure criteria
正向电压(VF)
Forward voltage
IF=20mA
>U.S.L*1.1
光强(IV)
light intensity
IF=20mA
<L.S.L*0.7
反向电流(IR)
Reverse current
VR=5V
>U.S.L*2.0
焊接可靠性
Welding reliability
锡膏覆盖焊盘比例小于95%
The proportion of solder paste
covering pad is less than 95%
7
典型光电特性曲线
Typical optical characteristics curves
8
外形
Overall Dimension
备注: 1. 单位 : 毫米(mm)
Remarks:
1. Unit: mm
2.公差 :如无特别标注则为± 0.10 mm
2. Tolerance: ± 0.10 mm unless otherwise specified
9
包装(1)
Packaging (1)
φ60
载带与圆盘尺寸 Belt and disc dimensions
φ13.0
备注:
Remarks:
1. 尺寸单位为毫米(mm);
1 Dimensions are in millimeters (mm);
2.尺寸公差如无标注,为±0.15mm;
2. The dimensional tolerance is ± 0.15mm if not marked;
10
包装(2)
Packaging (2)
11
1
Guideline for Soldering (1)
1.
Hand Soldering
推荐使用功率低于 20W 的烙铁,焊接时烙铁的温度必须保持在 300℃以下,且每个电极只能进行一次焊
接,每次焊接的持续时间不得超过 3 秒。
人手焊接过程中的不慎操作易引起 LED 产品的损坏,应当小心谨慎。
A soldering iron of less than 20W is recommended to be used in Hand Soldering. Please keep the temperature of
the soldering iron under 300℃ while soldering. Each terminal of the LED is to go for less than 3 second and
for one time only.
Be careful because the damage of the product is often started at the time of the hand soldering.
2.
推荐使用以下无铅回流焊接温度图进行。
Reflow Soldering: Use the conditions shown in the under Figure ofPb-Free Reflow Soldering.
· 回流焊接最多只能进行一次。
Reflow soldering should not be done more than once .
· 在回流焊接升温过程中,请不要对 LED 施加任何压力。
Stress on the LEDs should be avoided during heating in soldering process.
· 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。
After soldering, do not deal with the product before its temperature drop down to room temperature.
建议焊接温度曲线:
Recommended welding temperature curve
有铅制程
Lead process
无铅制程
Lead-free Process
12
2
Guideline for Soldering (2)
3.
Cleaning
在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30
秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。
超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的
情况预先测试清洗条件是否会对 LED 造成损伤。
It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for
3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the
solvents will dissolve the package and the resin or not.
Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED
depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W.
Before cleaning, a pretest should be done to confirm whether any damage to LEDs will occur.
此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响,
请根据特定的PCB设计和焊接设备来确定焊接方案。
Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment.
The technics in practise is influenced by many factors, it should be specialized base on the PCB designs
and configurations of the soldering equipment..
13
1
Precautions (1)
1.
Storage
· 本产品使用密封防潮抗静电袋包装,并附有干燥剂,未开封的产品有一年的保存时间。
Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to a
minimum.
· 开封前,产品须存放在温度不高于 30℃,湿度不高于 60%RH 的环境中。
Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and be
used within a year.
· 开封后,产品须存放在温度不高于 30℃,湿度不高于 10%RH 的环境中,且应该在 168 小时(7 天) 内使
用完。建议工作环境为温度不高于 30℃,湿度不高于 60%RH。
After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH, and be
soldered within 168 hours (7 days). It is recommended that the product be operated at the workshop condition of
30℃ or less and humidity less than 60%RH.
· 对于尚未焊接的 LED,如果吸湿剂或包装失效,或者产品没有符合以上有效存储条件,烘焙可以起到一定
的性能恢复效果。烘焙条件: (60±5)℃,持续 24 小时。
If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment
should be performed based on the following condition: (60±5)℃ for 24 hours.
2.
Static Electricity
静电和电涌会导致产品特性发生改变,例如正向电压降低等,如果情况严重甚至会损毁产品。所以在使用时必须采
取有效的防静电措施。
所有相关的设备和机器都应该正确接地,同时必须采取其他防止静电和电涌的措施。
使用防静电手环,防静电垫子,防静电工作服、工作鞋、手套,防静电容器,都是有效的防止静电和电涌的措施。
Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such
as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light.
All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist
bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs.
14
2
Precautions (2)
3.
Design Consideration
设计电路时,通过 LED 的电流不能超过规定的最大值,同时,还需使用保护电阻,否则,微小的电压变
化将会引起较大的电流变化,可能导致产品损毁。
建议使用以下(A)电路,该电路能够很好的调节通过每个 LED 的电流; 不推荐使用(B)电路,该电路
在持续的电压驱动下,LED 的正向电压(VF )发生变化,电流会随之而发生变化,可能使某些 LED 承
受高于规定的电流值。
In designing a circuit, the current through each LED must not exceed the absolute maximum rating specified for
each LED. In the meanwhile, resistors for protection should be applied, otherwise slight voltage shift will
cause big current change, burn out may happen.
It is recommended to use Circuit A which regulates the current flowing through each LED rather than Circuit B.
When driving LEDs with a constant voltage in Circuit B, the current through the LEDs may vary due to the
variation in Forward Voltage (VF) of the LEDs. In the worst case, some LED may be subjected to stresses in
excess of the Absolute Maximum Rating.
(A)
(B)
LED 的特性容易因为自身的发热和环境的温度的改变而发生改变。温度的升高会降低 LED 的发光效率、
影响发光颜色等,所以在设计时应充分考虑散热的问题。
Thermal Design is paramount importance because heat generation may result in the Characteristics decline,
such as brightness decreased, Color changed and so on. Please consider the heat generation of the LEDs
when making the system design.
15
3
Precautions (3)
4.
Others
直接用手拿取产品不但会污染封装树脂表面,也可能由于静电等因素导致产品性能的改变。过度的压力也可能直接
影响封装内部的管芯和金线,因此请勿对产品施加过度压力,特别当产品处于高温状态下,例如在回流焊接过程中。
When handling the product, touching the encapsulant with bare hands will not only contaminate its surface, but
also affect on its optical characteristics. Excessive force to the encapsulant might result in catastrophic failure of the
LEDs due to die breakage or wire deformation. For this reason, please do not put excessive stress on LEDs, especially
when the LEDs are heated such as during Reflow Soldering.
LED 的环氧树脂封装部分相当脆弱,请勿用坚硬、尖锐的物体刮、擦封装树脂部分。在用镊子夹取的时
候也应当小心注意。
The epoxy resin of encapsulant is fragile, so please avoid scratch or friction over the epoxy resin surface. While
handling the product with tweezers, do not hold by the epoxy resin, be careful.
不可用在PH
很抱歉,暂时无法提供与“XL-3216SURUBC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15000
- 100+0.14000
- 300+0.13000
- 500+0.12000
- 2000+0.11500
- 5000+0.11200
