XL-3010SURUBC
Technical Data Sheet
1205红蓝 侧面贴片式发光二极管
characteristic
* 外观尺寸(L/W/H):3.2*1.0*2.1mm
Outline Dimensions (L / w / h): 3.2 x 1 . 0 x 2.1 mm
* 发光角度:120度
Wide viewing angle :120°
* 发光颜色及胶体: 红蓝双色/透明胶体
Luminous color and colloid: Red and blue / transparent colloid
* 环保工艺符合ROHS标准
Environmental protection meets ROHS standard
* EIA规范标准包装
EIA standard packaging
* 适用于SMT贴片自动化生产
And is suitable for automatic production of SMT patches
* 适用于回流焊制程
Suitable for reflow soldering process
product application
* 医用设备:内窥镜、血氧仪
Medical equipment: endoscope、oximeter
* 汽车电子: 背光按键灯、指示灯
Automotive electronics: backlight key light、 indicator light
* 工业产品:电子仪表盘、工业设备
Industrial products: electronic instrument panel、industrial equipment
* 智能家居: 白色家电、数码管LED
Smart home: white appliances, nixie tube LED
* 通讯产品: 手机按键灯、路由器、电视盒
Communication products: mobile phone button lamp, router
1
Catalogue
Electrical Characteristics............................................................................................................................. 3
Typical Characteristic Curves......................................................................................................................5
Reliability Test Items And Conditions........................................................................................................7
Outline Dimensions.......................................................................................................................................8
Packaging.......................................................................................................................................................9
Guideline for Soldering.............................................................................................................................. 11
Precautions....................................................................................................................................................13
2
Limit parameters (Temperature=25°C):
参数名称
Parameter
正向工作电流
Forward working current
正向峰值电流
Pulse forward current
功率消耗
Power Dissipation
反向电压
Reverse voltage
储存环境温度
Storage ambient temperature
最大绝对额定值
Absolute Maximum Rating
符号
Symbol
红Red
蓝Blue
单位
Unit
IF
30
30
mA
IFP
80
135
mA
PD
75
135
mW
VR
5
5
V
-40ºC To +85ºC
°C
Tstg
注:1/10占空比,0.1ms脉冲宽度。Note:1/10 Duty Cycle,0.1ms Pulse Width
Electro-Optical Charasteristics (Temperature=25°C):
符号
Symbol
peak
D
1/2
C
VF
IR
参数
Parameter
装置
Device
典型值
Typ.
最大值
Max.
单位
Units
试验条件
Test Conditions
nm
IF=20mA
464
620
472
625
nm
IF=20mA
Blue
Red
25
nm
IF=20mA
Blue
Red
Blue
Red
Blue
Red
100
25
3.0
1.9
pF
VF=0V;f=1MHz
V
IF=20mA
uA
VR = 5V
Blue
Red
Blue
Red
峰值波长
Peak Wavelength
主导波长
Dominant Wavelength
谱线半宽
Spectral Line Halfwidth
电容
Capacitance
正向电压
Forward Voltage
反向电流
Reverse Curren
3.4
2.1
5
5
选择指南 Selection Guide
零件号
颜色
透镜类型
Part No.
Colour
Lens Type
XL-3010SURUBC
BLUE (GaN)
RED (InGaAIP)
WATER CLEAR
亮度Iv (mcd)
@ 20mA
最小
典型
Min.
Typ.
100
200
70
150
发光角度
Viewing Angle
2 1/2
120
注: 2 1/2是与光学中心线的角度,其中发光强度为光学中心线值的1/2。
Note: 2 1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline value.
3
Brightness grading
颜色
Colour
红
Red
蓝
Blue
代码
Code
最小值
Minimum value
最大值
Maximum
T17
70
150
P00
100
200
单位
Unit
测试条件
Test conditions
mcd
IF=5mA
Voltage grading
颜色
Colour
红
Red
蓝
Blue
代码
Code
最小值
Minimum value
最大值
Maximum
A04
2.0
2.2
U05
3.0
3.3
代码
Code
最小值
Minimum value
最大值
Maximum
HR02
620
625
TB22
466
472
单位
Unit
测试条件
Test conditions
V
IF=5mA
单位
Unit
测试条件
Test conditions
nm
IF=5mA
Wavelength grading
颜色
Colour
红
Red
蓝
Blue
4
典型特性曲线(1)
Typical Characteristics Curves(1)
红Red
5
Typical Characteristics Curves(2)
蓝Blue
6
不良数量
/抽样
Bad
quantity/s
ampling
序号
Order
number
试验项目
Test time
参考标准
Reference
standard
试验条件
Condition of
experiment
持续时间
Duration
取样数
Sampli
ng
number
1
温度循环
Temperatur
e cycle
JEITA ED4701
-40℃~25℃~100℃~
25℃
30 分钟 5 分钟 30 分钟
5 分钟
循环 100
回合Cycle
it for 100
rounds
50
0/50
2
冷热冲击
Hot and
cold impact
MIL-STD202G
-40℃~100℃
15 分钟 15 分钟
循环 500
回合Cycle
it for 500
rounds
50
0/50
高温储存
Hightemperature
storage
低温储存
Low
temperature
storage
常温寿命
试验
Normal
temperature
life trial
JEITA ED4701 200
201
Ta=100℃
1000 小 时
1000hours
50
0/50
JEITA ED4701 200
201
Ta=-40℃
1000 小 时
1000hours
50
0/50
Ta=25±5℃
IF=20mA
1000 小 时
1000hours
50
0/50
Ta=60℃ RH=85%
IF=20mA
1000 小 时
1000hours
50
0/50
Tsol=235℃±5℃,5秒
使用助焊剂
Use solder
焊接一次
,5 秒
Welded
once, for 5
seconds
10
0/10
Tsol=250℃,10 秒
预处理pretreatment:
35℃ 95%RH 96小时
焊接二次
,每次 10
秒Weleld
twice for
10 seconds
each
10
0/10
3
4
5
6
高温高湿
试验High
temperature
and high
humidity
trial
7
可焊性
(回流焊
)Solderabil
ity
(reflow
soldering)
8
耐焊性
(回流焊
)Soldering
resistance
(reflow
soldering)
JEITA ED4701
300 303
JEITA ED4701
300 301
7
Outline Dimension
Suggest Soldering Pad Dimensions
备注:
Remarks:
1.单位:毫米(mm)
1 Unit: mm
2.公差: 如无特别标注则为±0.10mm
2. Tolerance: ± 0.10mm unless otherwise specified
8
1
Packaging (1)
编带包装 Fabric with packaging
卷轴尺寸 Scroll size
9
2
Packaging (2)
10
1
Guideline for Soldering (1)
1.
Hand Soldering
推荐使用功率低于 20W 的烙铁,焊接时烙铁的温度必须保持在 300℃以下,且每个电极只能进行一次焊
接,每次焊接的持续时间不得超过 3 秒。
人手焊接过程中的不慎操作易引起 LED 产品的损坏,应当小心谨慎。
A soldering iron of less than 20W is recommended to be used in Hand Soldering. Please keep the temperature of
the soldering iron under 300℃ while soldering. Each terminal of the LED is to go for less than 3 second and for one
time only.
Be careful because the damage of the product is often started at the time of the hand soldering.
2.
推荐使用以下无铅回流焊接温度图进行。
Reflow Soldering: Use the conditions shown in the under Figure ofPb-Free Reflow Soldering.
回流焊接Reflow soldering
手工焊接Hand welding
有铅 Lead
Solder
无铅 Lead-free
Solder
温度Temperature
350°C Max.
预热温度Pre-heat
140 ~ 160°C
180 ~ 200°C
预热时间Pre-heat time
120 sec. Max.
120 sec. Max.
焊接时间
Soldering time
3 sec. Max.
(onetime only)
峰值温度Peak temperature
230°C Max.
260°C Max.
焊接时间Soldering time
10 sec. Max.
10 sec. Max.
条件Condition
参考下图
参考下图
有铅回焊(Lead Solder)
无铅回焊(Lead-Free Solder)
· 回流焊接最多只能进行两次。
Reflow soldering should not be done more than two times.
· 在回流焊接升温过程中,请不要对 LED 施加任何压力。
Stress on the LEDs should be avoided during heating in soldering process.
· 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。
After soldering, do not deal with the product before its temperature drop down to room temperature.
11
2
Guideline for Soldering (2)
3.
Cleaning
在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30
秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。
超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的
情况预先测试清洗条件是否会对 LED 造成损伤。
It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for
3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents
will dissolve the package and the resin or not.
Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED
depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W. Before
cleaning, a pretest should be done to confirm whether any damage to LEDs will occur.
此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响,
请根据特定的PCB设计和焊接设备来确定焊接方案。
Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment.
The technics in practise is influenced by many factors, it should be specialized base on the PCB designs
and configurations of the soldering equipment..
12
1
Precautions (1)
1.
Storage
· 本产品使用密封防潮抗静电袋包装,并附有干燥剂,未开封的产品有一年的保存时间。
Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to a
minimum.
· 开封前,产品须存放在温度不高于 30℃,湿度不高于 60%RH 的环境中。
Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and be
used within a year.
· 开封后,产品须存放在温度不高于 30℃,湿度不高于 10%RH 的环境中,且应该在 168 小时(7 天) 内使
用完。建议工作环境为温度不高于 30℃,湿度不高于 60%RH。
After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH, and be
soldered within 168 hours (7 days). It is recommended that the product be operated at the workshop condition of
30℃ or less and humidity less than 60%RH.
· 对于尚未焊接的 LED,如果吸湿剂或包装失效,或者产品没有符合以上有效存储条件,烘焙可以起到一定
的性能恢复效果。烘焙条件: (60±5)℃,持续 24 小时。
If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment
should be performed based on the following condition: (60±5)℃ for 24 hours.
2.
Static Electricity
静电和电涌会导致产品特性发生改变,例如正向电压降低等,如果情况严重甚至会损毁产品。所以在使用时
必须采取有效的防静电措施。
所有相关的设备和机器都应该正确接地,同时必须采取其他防止静电和电涌的措施。
使用防静电手环,防静电垫子,防静电工作服、工作鞋、手套,防静电容器,都是有效的防止静电和电涌的措施。
Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such
as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light.
All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist
bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs.
13
2
Precautions (2)
3.
Design Consideration
设计电路时,通过 LED 的电流不能超过规定的最大值,同时,还需使用保护电阻,否则,微小的电压变
化将会引起较大的电流变化,可能导致产品损毁。
建议使用以下(A)电路,该电路能够很好的调节通过每个 LED 的电流; 不推荐使用(B)电路,该电路
在持续的电压驱动下,LED 的正向电压(VF )发生变化,电流会随之而发生变化,可能使某些 LED 承受高于
规定的电流值。
In designing a circuit, the current through each LED must not exceed the absolute maximum rating specified for
each LED. In the meanwhile, resistors for protection should be applied, otherwise slight voltage shift will cause big
current change, burn out may happen.
It is recommended to use Circuit A which regulates the current flowing through each LED rather than Circuit B.
When driving LEDs with a constant voltage in Circuit B, the current through the LEDs may vary due to the variation
in Forward Voltage (VF) of the LEDs. In the worst case, some LED may be subjected to stresses in excess of the
Absolute Maximum Rating.
(A)
(B)
LED 的特性容易因为自身的发热和环境的温度的改变而发生改变。温度的升高会降低 LED 的发光效率、
影响发光颜色等,所以在设计时应充分考虑散热的问题。
Thermal Design is paramount importance because heat generation may result in the Characteristics decline,
such as brightness decreased, Color changed and so on. Please consider the heat generation of the LEDs when
making the system design.
14
3
Precautions (3)
4.
Others
直接用手拿取产品不但会污染封装树脂表面,也可能由于静电等因素导致产品性能的改变。过度的压力也
直接影响封装内部的管芯和金线,因此请勿对产品施加过度压力,特别当产品处于高温状态下,例如在回
可能
流焊接过
程中。
When handling the product, touching the encapsulant with bare hands will not only contaminate its surface, but
also affect on its optical characteristics. Excessive force to the encapsulant might result in catastrophic failure of the
LEDs due to die breakage or wire deformation. For this reason, please do not put excessive stress on LEDs, especially
when the LEDs are heated such as during Reflow Soldering.
LED 的环氧树脂封装部分相当脆弱,请勿用坚硬、尖锐的物体刮、擦封装树脂部分。在用镊子夹取的时
候也应当小心注意。
The epoxy resin of encapsulant is fragile, so please avoid scratch or friction over the epoxy resin surface. While
handling the product with tweezers, do not hold by the epoxy resin, be careful.
5.
Safety Advice For Human Eyes
LED 发光时,请勿直视发光光源,特别是对于一些光强较高的 LED ,强光可能伤害你的眼睛。
Viewing direct to the light emitting center of the LEDs, especially those of great Luminous Intensity, will cause
great hazard to human eyes. Please be careful.
15
很抱歉,暂时无法提供与“XL-3010SURUBC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.30000
- 100+0.28000
- 300+0.26000
- 500+0.24000
- 2000+0.23000
- 5000+0.22400
