HG24C04
TOW - Wirs Serlal EEPROM
Features
Wide Voltage Operation
-Bidirectional Data Transfer Protocol
- VCC = 1.8V to 5.5V
-1 MHz (2.5-5V), 400 kHz (1.8V) Compatibility
Operating Ambient Temperature: -40℃ to +85℃
-Write Protect Pin for Hardware Data Protection
Internally Organized:
- 16-byte Page 4K, Write Modes
- HG24C04, 512 X 8 (4K bits)
-Partial Page Writes Allowed
-Schmitt Trigger, Filtered Inputs for Noise Suppression
-Self-timed Write Cycle (5 ms max) High-reliability
- Endurance: 1 Million Write Cycles
- Data Retention: 100 Years
General Description
The
provides 4096 bits of
HG24C04
serial
electrically
erasable and programmable read
-only memory (EEPROM) organized as 512 words of 8 bits each. The device is optimized for use in
many industrial and commercial applications where low -power and
The HG24C04
TSSOP ,8-lead
is
available
in
space-saving
MSOP, 8 PAD DFN and
low-voltage operation are essentia l.
8-lead PDIP, 8-lead SOP, 8-lead
SOT23-5 packages
and
is accessed via a two-wire serial interface.
Pin Configuration
Pin Name
A0-A2
SDA
SCL
WP
GND
VCC
Founctions
Address Inputs
Serial Data
Serial Clock Input
Write Protect
Ground
Power Supply
8 - lead PDIP
http://www.hgsemi.com.cn
8 - lead SOP
1
2015 JAN
HG24C04
PACKAGING INFORMATION
HG 24C 04 M /TR
Hgsemi Designator
Product Family
/TR = Taping
Package Type
24C=Standard I2C-compatible
Serial EEPROM
M = SOP-8
N = DIP-8
Device Density
04 = 4 Kiloblt
MARKING
2
2015 JAN
HG24C04
Block Diagram
3
2015 JAN
HG24C04
Pin Descriptions
DEVICE/PAGE ADDRESSES (A2, A1 and A0):
The HG24C04 uses the A2 and A1 inputs for hard wire addressing and a total of four 4K devices may be addressed on
a single bus system. The A0 pin is a no conn ect and can be connected to ground.
SERIAL DATA (SDA): The SDA pin is bi-directional for serial data transfer. This pin is open-drain driven and may
be wire-Read with any number of other open-drain or open- collector devices.
SERIAL CLOCK (SCL): The SCL input is used to positive edge clock data into each EEPROM device and negative
edge clock data out of each device.
WRITE PROTECT (WP): The HG24C04 has a Write Protect pin that provides
hardware data protection. The Write Protect pin allows normal read/write operations when connected to ground
(GND). When the Write Protect pin is connected to VCC , the write protection feature is enabled and operates as
shown in the following
Table 2:Write Protect
WP Pin Status
At Vcc
At GND
Part of the Array Protected
HG24C04D
Full(4K)Array
Normal Read/Write Operations
Memory Organization
HG24C04, 4K SERIAL EEPROM: Internally organized with 32 pages of 16 bytes each, the 4K requires a 9-bit data
word address for random word addressing.
4
2015 JAN
HG24C04
Device Operation
CLOCK and DATA TRANSITIONS: The SDA pin is normally pulled high with an external device. Data on the SDA
pin may change only during SCL low time periods (see to Figure 1 on page 4). Data changes during SCL high periods
will indicate a start or stop condition as define d below.
START CONDITION: A high-to-low transition of SDA with SCL high is a start condition which must precede any
other command (see to Figure 2 on page 4).
STOP CONDITION: A low-to-high transition of SDA with SCL high is a stop condition. After a read sequence, the
stop command will place the EEPROM in a s tandby power mode (see Figure 2 on page 4).
ACKNOWLEDGE: All addresses and data words are serially transmitted to and from the EEPROM in 8-bit words.
The EEPROM sen ds a "0" to acknowledge that it has received each word. This happens during the ninth clock cycle.
STANDBY MODE: The HG24C04 features a low-power standby mode
which is enabled: (a) upon power-up and (b) after the recei pt of the STOP bit and the completion of any internal
operations.
MEMORY RESET: After an interruption in protocol, power loss or system reset, any two-wire part can be reset by
following these steps:
1. Clock up to 9 cycle s.
2. Look for SDA high in each cycle while SCL is high.
3. Create a start cond ition.
Figure 1: Data Validity
Figure 2: Start and Stop Definition
5
2015 JAN
HG24C04
Figure 3: Output Acknowledge
Device Addressing
The 4K EEPROM devices all require an 8 - bit device address word following a start condition to
enable the chip for a read or write operation (see to Figure 4 on page 7).
The device address word consists of a mandatory "1", "0" sequence for the first four most significant bits as shown.
This is common to all the Serial EEPROM devices.
The 4K EEPROM only uses the A2 and A1 device address bits with the third bit being a memory page address bit. The
two device add ress bits must compare to their corresponding hardwired input pins. The A0 pin is no conn ect.
The eighth bit of the device address is the read/write operation select bit. A read operation is initiated if this bit is high
and a write operation is initiated if this bit is low.
Upon a compare of the device add ress, the EEPROM will output a "0 ". If a compare is not made, the chip will return
to a standby state.
6
2015 JAN
HG24C04
Write Operations
BYTE WRITE: A write operation requires an 8-bit data word address follo wing the device
address wo rd and acknowledgm en t. Upon receipt of this address, the EEPROM will again respond with a "0"
and then clock in the first 8-bit data word. Following receipt of the 8-bit data word, the EEPROM will output a "0" and
the addressing device, such as a microcontroller, must terminate the write sequence with a stop condition. At this time
the EEPROM enters an internally timed write cycle, tWR, to the nonvolatile memory. All inputs are disabled during
this write cycle and the EEPROM will not respond until the write is comp lete (see Figure 5 on page 7).
PAGE WRITE: The 4K -devices are capable of 16-byte page writes.
A page write is initiated the same as a byte write, but the microcontroller does not send a stop condition after the first
data word is clocked in. Instead, after the EEPROM acknowledges receipt of the first data word, the microcontroller
can transmit up to seven 4K more data words. The EEPROM will respond with a "0" after
each data word received. The microcontroller must terminate the page write sequence with a stop condition (see Figure
6 on page 7).
The data word address lower three 4K bits are internally incremented following the receipt of
each data word. The higher data word address bits are not incremented, retaining the memory page row location. When
the word address, internally generated, reaches the page boundary, the following byte is placed at the beginning of the
same page. If more than eight 4K data words are tr ansmitted to the EEPROM, the data
word address will "roll over" and previous data will be overwritten.
ACKNOWLEDGE POLLING: Once the internally timed write cycle has started and the EEPROM inputs are disabled,
acknowled ge polling can be initiated. This involves sending a start condition followed by the device address word.
The read/write bit is representative of the operation desired. Only if the internal write cycle has completed will the
EEPROM respond with a "0", allowi ng the read or write sequence to continue.
Read Operations
Read operations are initiated the same way as write operations with the exception that the read/write select bit in the
device address word is set to "1". There are three read operations: current address read, random address read and
sequential read.
CURRENT ADDRESS READ: The internal data word address counter maintains the last accessed address,
and incremented by one.*This address stays valid between operations as long as the chip power is maintained.
The address "roll over" during read is from the last byte of the last memory page to the first byte of the
first page.The address "roll over" during write is from the last byte of the current page to the first byte of the same
page.
Once the device address with the read/write select bit set to "1" is clocked in and acknowledged by the EEPROM, the
current address data word is serially clocked out. The microcontroller does not respond with an input "0" but does
generate a following stop condition (see Figure 7 on page 8).
7
2015 JAN
HG24C04
Read Operations
*For 16K EEPROM, we also provide special addressing product for certain applications, that is, . only lower 8 bits of
the internal data word address counter maintains the last accessed address, the higher 3 bits (P2, P1, P0) wil l
follow the device address input at each current address read .So, please contact your dealer for specia l ordering .
RANDOM READ: A random read requires a "dummy" byte write sequence to load in the data word
address. Once the device address word and data word address are clocked in and acknowledg ed by
the EEPROM, the microcontroller must generate another start condition. The microcontroller now
initiates a current address read by sending a device address with the read/write select bit high. The
EEPROM acknowledges the device address and serially clocks out the data word. The
microcontroller does not respond with a "0" but does generate a following stop condition (see Fig ure
8 on page 8).
SEQUENTIAL READ: Sequential reads are initiated by either a current address read or a random
address read. After the
microcontroller receives a
data
word, it
responds with
an
acknowled ge. As long as the EEPROM receives an ack nowled ge, it will continue to
increment the data word address and serially clock out sequential data words. When the memory
address limit is reached, the data word address will "roll over" and the sequen tial read will
continue.The sequential read operation is terminated when the microcontroller does not respond with
a "0" but does generate a following stop condition (see Figure 9 on pag e 8).
Figure 4: Device Address
Figure 5: Byte Write
8
2015 JAN
HG24C04
Figure 6: Page Write
Figure 7: Current Address Read
Figure 8: Random Read
9
2015 JAN
HG24C04
Figure 9: Sequential Read
Electrical Characteristics
Absolute Maximum Stress Ratings
Comments
DC Supply Voltage……………………..-0.3V to +6.5V
Stresses above those listed under "Absolute Maximum Ratings"
may cause permanent damage to this device. These are stress
Input / Output Voltage ……...GND-0.3V to VCC+0.3V
ratings only. Functional operation of this device at these or any
other conditions above those indicated in the operational
Operating Ambient Temperature . . . . . -40℃ to +85℃
sections of this specification is not implied or intended.
Exposure to the absolute maximum rating conditions for
Storage Temperature . . . . . . . . . . . .
-65℃ to +150℃
extended periods may affect device reliability.
DC Electrical Characteristics
Applicable over recommended operating range from: TA = -40℃ to +85℃,VCC = +1.7V to +5.5V (unless otherwise noted)
Parameter
Symbol
Min.
Typ.
Max.
Unit
Supply Voltage
Vcc
1.8
5.5
V
Supply Current VCC = 5.0V
ICC1
0.4
1.0
mA
READ at 400KHz
ICC2
2.0
3.0
mA
WRITE at 400KHz
Standby Current
ISB
3.0
μA
VIN=VCC or GND
Input Leakage Current
ILI
3.0
μA
VIN=VCC or GND
Output Leakage Current
ILO
0.05
3.0
μA
VOUT=VCC or GND
Input Low Level
VIL1
-0.3
Vcc*0.3
V
Vcc=1.8V to 5.5V
Input High Level
VIH1
Vcc*0.7
Vcc+0.3
V
Vcc=1.8V to 5.5V
Input Low Level
VIL2
-0.3
Vcc*0.2
V
Vcc=1.7V
Input High Level
VIH2
Vcc*0.7
Vcc+0.3
V
Vcc=1.7V
Output Low Level VCC =5.0V
VOL3
0.4
V
IOL=3.0mA
Output Low Level VCC =3.0V
VOL2
0.4
V
IOL=2.1mA
Output Low Level VCC =1.7V
VOL1
0.2
V
IOL=0.15mA
10
Condition
2015 JAN
HG24C04
apac ance
ApplicableParameter
over recommended operatingSymbol
range from TAMin.
= 25℃, f = 1.0
MHz, VCCMax.
= +1.7V
Typ.
Unit
Condition
Input/Output Capacitance (SDA)
CI/O
8
pF
VI/O = 0V
Input Capacitance (A0, A1, A2, SCL)
CIN
6
pF
VIN = 0V
AC Electrical Characteristics
Parameter
Symbol
1.7v < Vcc < 2.5v
2.5v < Vcc < 5.5v
Min.
Typ.
Max.
Min.
Typ.
Max.
Units
Clock Frequency, SCL
fSCL
400
1000
KHz
Clock Pulse Width Low
tLOW
1.2
0.6
s
Clock Pulse Width High
tHIGH
0.6
0.4
s
Noise Suppression Time
tI
50
40
ns
tAA
0.05
0.9
0.05
0.55
s
tBUF
1.2
0.5
s
Start Hold Time
tHD.STA
0.6
0.25
s
Start Setup Time
tSU.STA
0.6
0.25
s
Data In Hold Time
tHD.DAT
s
Data In Setup Time
tSU.DAT
100
100
ns
Inputs Rise Time(1)
tR
0.3
0.3
s
Inputs Fall Time(1)
tF
300
100
ns
tSU.STO
0.6
0.25
s
Data Out Hold Time
tDH
50
50
ns
Write Cycle Time
tWR
1.5
5
1.5
5
ms
Endurance
1M
Write Cycles
Clock Low to Data Out Valid
Time the bus must be free before
a new transmission can start
Stop Setup Time
5.0V, 25℃, Byte Mode
11
2015 JAN
HG24C04
Bus Timing
Figure 10: SCL: Serial Clock, SDA: Serial Data I/O
Write Cycle Timing
Figure 11: SCL: Serial Clock, SDA: Serial Data I/O
Note:
12
2015 JAN
HG24C04
DIP8
13
2015 JAN
HG24C04
SOP8
14
2015 JAN
HG24C04
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
15
2015 JAN
