AW8646QNR
AW8646QNR
    AWINIC(艾为)
    VQFN24_4X4MM
    AW8646QNR
AW8646QNR 数据手册
AW8646 February 2019 V1.2 AW8646 Dual H-Bridge Stepper Motor Driver GENERAL DESCRIPTION  3V to 12V Supply Voltage Range  1.4A Full Scale current per H-Bridge  Rdson HS + LS: Typical 0.8Ω  Support up to 1/32th Microstepping  Decay Modes supported: The AW8646 is a flexible microstepping stepper motor driver. It is designed to operate bipolar stepper motor with up to 1/32th step mode for mobile phones, tablets, and other automated equipment applications. The device can be controlled by simple STEP/DIR interface allowing easy interfacing to controller circuits. The output block of each H-bridge driver consists of N-channel and Pchannel power MOSFETS configured as full Hbridges to drive the motor windings. Mixed Decay  Slow Decay  Fast Decay Support 1.8V Logic Level  Programmable off-time ti a Pins allow configuration of the motor in full-step up to 1/32th step modes. Decay mode is configurable so that adaptive decay, slow decay, fast decay, and mixed decay can be used. A low power sleep mode is provided to achieve very-low quiescent current draw. n  n  e Adaptive Decay Technology fi d  l FEATURES o 10,20, or 30s off-time Programmable Motor Torque Current  Short-Circuit Protection, Over-Temperature C  Protection, Under-Voltage Protection Fault Condition Indication  QFN 4mm X4mm X0.85mm-24L package The device offers a complete set of protection features including UVLO, overcurrent protection, short circuit protection, and over temperature. Fault conditions are indicated via the nFAULT pin. ic  AW8646 is capable of driving up to 1.4A (Full Scale) or 1A (RMS) current per H-Bridge in APPLICATIONS Mobile phones  Tablets  Printer  Video Security Cameras a w  www.awinic.com.cn 1 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 D0 T1 T0 ADECAY 24 23 22 21 20 19 18 GND AO1 1 ASEN 2 5 15 VDD 14 VREF fi d BSEN e 16 NC 25 EPAD 13 DIR 8 9 10 11 12 MODE0 MODE1 TOFF nEN STEP 3YYE - AW8646QNR XXXX - Production Tracing Code o 7 nFAULT BO1 6 n 4 n 17 VREG AO2 3 BO2 ti a nSLEEP AW8646QNR Marking (Top View) D1 AW8646QNR (Top View) l PIN CONFIGURATION AND TOP MARK a w in ic C Figure 1 Pin Configuration And Top Mark www.awinic.com.cn 2 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 PIN DEFINITION No. NAME DESCRIPTION 1 AO1 2 ASEN 3 AO2 H-bridge A output 4 BO2 H-bridge B output 5 BSEN 6 BO1 7 nFAULT Pulled low when a failure occurs, open-drain output requires external pull up 8 MODE0 Tri-level pin, low bit of step mode setting pins, controls step mode (full, half, up to 1/32th step) , see description section 9 MODE1 Tri-level pin, high bit of step mode setting pins, controls step mode (full, half, up to 1/32th step) , see description section 10 TOFF 11 nEN 12 STEP 13 DIR 14 VREF Full scale current reference input, Voltage on this pin sets the full scale current; short to VREG if not supplying an external reference voltage 15 VDD Power supply, Connect to motor power supply 16 NC 17 VREG 18 GND 19 ADECAY H-bridge A output ti a l Sense output of bridge A, If current regulation is not required it must connect to GND Sense output of bridge B, If current regulation is not required it must connect to GND fi d e n H-bridge B output Tri-level pin, decay mode off time set, sets the off-time during current control Driver enable control input pin. Logic low to enable device outputs, logic high to disable device outputs n Step input, A rising or falling edge increases one step C o Direction input, sets the direction of stepping No connect, Unused pin Internal regulator, Internal supply voltage in ic Ground pin, both the GND pin and device thermal pad must be connected to ground Adaptive Decay mode control pin, when set to logic low, decay modes controlled by D0 and D1 pins; when set to logic high, Adaptive Decay mode is enabled, must be set prior to coming out of sleep T0 Tri-level pin, Scales the torque current from 100% to 12.5% in 12.5% steps, see description section T1 Tri-level pin, Scales the torque current from 100% to 12.5% in 12.5% steps, see description section 22 D0 Tri-level pin, Decay mode setting pins, see description section 23 20 nSLEEP 24 D1 25 EPAD a w 21 www.awinic.com.cn Sleep mode input, Logic high to enable device; logic low to enter low-power sleep mode; internal pull down Tri-level pin, Decay mode setting pins, see description section Thermal pad, must be connected to GND 3 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 FUNCTIONAL BLOCK DIAGRAM VDD VREG LDO 2.2μF 0.1μF 10μF ti a OCP/UVL VREF VDD nEN AO1 STEP n Gate Drive DIR MODE0 Controller BO1 e n nFAULT o Gate Drive ic C ADECAY BO2 BSEN Bsensor OTP EPAD GND Figure 2 Functional Block Diagram a w in ASEN OCP/UVL VDD TOFF Logic supply nSLEEP D1 fi d Asensor T0 D0 Stepper Motor AO2 MODE1 T1 l VDD www.awinic.com.cn 4 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 TYPICAL APPLICATION CIRCUITS VDD C2 0.1μF 25V VREG 7 12 VDD VREF AO1 STEP l 1 RASEN 2 0.5ohm Stepper Motor e ASEN fi d AO2 3 AW8646 19 ADECAY 20 T0 21 T1 22 D0 23 nSLEEP 24 D1 BO2 4 BSEN 5 RBSEN 0.5ohm 6 n BO1 o GND     16 NC nFAULT 13 DIR 8 MODE0 9 MODE1 10 TOFF 11 nEN CPU 15 14 17 R1 10Kohm ti a VCC Logic supply C1 10μF 25V n C3 2.2μF 10V 18 EPAD 25 ic C Tri-level Inputs: T0,T1,MODE0,MODE1,D0,D1,TOFF Logic-level inputs: DIR, nEN, nSLEEP, ADECAY PWM signal: STEP The current of RxSEN is equal to the current of motor, refer to the application maxium motor current when calculate the power of RxSEN Figure 3 Typical Application Circuit of AW8646 All trademarks are the property of their respective owners. in Notice for Typical Application Circuits: 1:Please place C1,C2,C3 as close to the chip as possible. The capacitors should be placed in the same layer with the AW8646 chip. w 2:For the sake of driving capability, the power lines (especially the one to Pin C2) and output lines should be short and wide as possible. a 3:Table 1 lists the recommended external components for the device. COMPONENT C1 C2 C3 R1 RASEN RBSEN www.awinic.com.cn Table 1 PIN 1 VDD VDD VREG VCC ASEN BSEN PIN 2 GND GND GND nFAULT GND GND 5 External Components RECOMMENDED 25V, 10μF (minimum) ceramic capacitor rated for VDD 25V, 0.1μF ceramic capacitor rated for VDD 10V, 2.2μF ceramic capacitor >5kΩ Sense resistor, see applications section for sizing Sense resistor, see applications section for sizing Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 ORDERING INFORMATION Temperature Package Marking Moisture Sensitivity Level Environmental Information Delivery Form AW8646 QNR -40℃~85℃ QFN 4mmX4mm24L 3YYE MSL3 ROHS+HF 6000 units/Tape and Reel ti a l Part Number n ABSOLUTE MAXIMUM RATINGS(NOTE1) RANGE e PARAMETERS Power supply voltage (VDD) Power supply voltage ramp rate (VDD) Analog input pin voltage (VREF) 0V/s to 2 V/s fi d Internal regulator voltage (VREG) -0.3V to 16V -0.3V to 3.6V -0.3V to 3.6V -0.3V to 7V Continuous phase node pin voltage (AO1, AO2, BO1, BO2) -0.3V to (VDD+0.6)V Continuous shunt amplifier input pin voltage (ASEN, BSEN) -0.6V to 0.6V Peak drive current (AO1, AO2, BO1, BO2, ASEN, BSEN) Internally limited Junction-to-ambient thermal resistance θJA 60°C /W C o n Control pin voltage (nEN, STEP, DIR, T0, T1, MODE0, MODE1, D0, D1, TOFF, nSLEEP,nFAULT, ADECAY) Operating free-air temperature range -40°C to 85°C 165°C Storage temperature TSTG -65°C to 150°C ic Maximum operating junction temperature TJMAX Lead temperature (soldering 10 seconds) w in ESD(Including CDM HBM MM) 260°C (NOTE 2) HBM(Human Body Model) ±4kV CDM(Charge Device Model) ±1.5kV Latch-Up Test Condition: JEDEC STANDARD NO.78E +IT:200mA -IT:-200mA a NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: ANSI/ESDA/JEDEC JS-001 www.awinic.com.cn 6 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 ELECTRICAL CHARACTERISTICS VDD=5V, TA=25°C for typical values (unless otherwise noted) MAX 3 5 12 1.0 o C ic 7 4.0 mA 0.1 1 A 0.7 0.5 ms ms 0.5 ms 3.3 3.47 V 0.45 5.5 V V mV A A 100 –1 1 1 40 200 500 200 600 0 kΩ ns ns 0.45 0.9 1.3 V V 5.5 100 V mV –22 –1 A 1 40 A in w a www.awinic.com.cn V 2.5 0 1.3 n fi d 3.13 UNIT l TYP e VDD = 5 V, excluding winding IVDD VDD operating supply current current, nSLEEP = 1, nEN = 0 or 1 VDD sleep mode supply VDD = 5 V, nSLEEP = 0, nEN = 0 IVDDQ current or 1 tSLEEP Sleep time nSLEEP = 0 to sleep mode tWAKE Wake time nSLEEP = 1 to output transition VDD > VUVLO rising to output tON Power-on time transition VREG VREG voltage VDD > 4 V, IOUT = 0 A to 1 mA LOGIC-LEVEL INPUTS (STEP, DIR, nEN, nSLEEP, ADECAY) VIL Input logic low voltage VIH Input logic high voltage VHYS Input logic hysteresis IIL Input logic low current VIN = 0 V IIH Input logic high current VIN = 5 V nEN, STEP, DIR, ADECAY RPD Pulldown resistance nSLEEP tDEG Input deglitch time tPROP Propagation delay STEP edge to current change TRI-LEVEL INPUTS (T0, T1, MODE0, MODE1, D0, D1, TOFF) Tri-level input logic low VIL voltage VIZ Tri-level input Hi-Z voltage Tri-level input logic high VIH voltage VHYS Tri-level input hysteresis Tri-level input logic low IIL VIN = 0 V current Tri-level input logic high IIH VIN = 5 V current RPD Tri-level pulldown resistance To GND RPU Tri-level pullup resistance To VREG CONTROL OUTPUTS (nFAULT) VOL Output logic low voltage IO = 5 mA IOH Output logic high leakage VO = 3.3 V MOTOR DRIVER OUTPUTS (AO1, AO2, BO1, BO2) RDS(ON) High-side FET on resistance VDD = 5 V, I = 0.5 A, TJ = 25°C RDS(ON) Low-side FET on resistance VDD = 5 V, I = 0.5 A, TJ = 25°C tRISE Output rise time tFALL Output fall time tDEAD Output dead time Internal dead time PWM CURRENT CONTROL (VREF, ASEN, BSEN) Externally applied VREF IREF VREF = 1 to 3.3 V input current For 100% current step with VREF VTRIP xSEN trip voltage = 3.3 V MIN ti a TEST CONDITIONS n PARAMETER POWER SUPPLIES (VDD, VREG) VDD VDD operating voltage 180 480 kΩ kΩ 0.5 1 –1 V A 430 300 50 50 150 mΩ mΩ ns ns ns 2 A 500 mV Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 TEST CONDITIONS Reference Only TOFF = GND TOFF = Hi-Z TOFF = VREG Current control constant off time tOFF MIN TYP 6.6 20 10 30 MAX PROTECTION CIRCUITS Overcurrent Protection Trip Level Overcurrent Deglitch Time Overcurrent Protection Period Thermal shutdown temperature Thermal shutdown hysteresis tOCP tRETRY TTSD THYS 2 Die Temperature TJ Die Temperature TJ fi d TIMING REQUIREMENTS V A 0.1 s 1.6 ms n IOCP 2.7 2.8 s ti a VDD falling; UVLO Report VDD rising; UVLO Recovery VDD under voltage lockout e VUVLO UNIT V/V l PARAMETER Current sense amplifier gain K 160 °C 30 °C VDD=5V, TA=25°C for typical values (unless otherwise noted) C tWH(STEP) tWL(STEP) tSU(STEP) tH(STEP) DESCRIPTION Step Frequency Pulse Duration, STEP High Pulse Duration, STEP Low Setup Time, DIR or Mx to STEP Rising Hold Time, DIR or Mx to STEP Rising n NAME ƒSTEP o NO. 1 2 3 4 5 MIN 1.9 1.9 200 600 MAX 250 UNIT KHz s s ns ns ① ② ③ ic STEP ④⑤ Figure 4 Timing Diagram a w in DIR,MODE0,MODE1 www.awinic.com.cn 8 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 DETAILED FUNCTIONAL DESCRIPTION OVERVIEW ti a l The AW8646 is a bipolar stepper motors driver integrating 2 H-bridges that use NMOS low-side drivers and PMOS high-side drivers, two PWM current controller, and a microstepping sequencer. The AW8646 can be powered with a supply range between 3 to 12V. The AW8646 is capable of driving up to 1.4A (Full Scale) or 1A (RMS) current per H-Bridge. At each STEP rising edge or falling edge(some step mode), the sequencer of the device increased or decreased as step mode configuration. n The internal sequencer is able to execute high-accuracy microstepping setting the reference value of the PWM current controller and the direction of the current for both of the H-bridge. e The total PWM off-time, tOFF can be adjusted to 10, 20, or 30s. fi d The AW8646 has Adaptive Decay Technology that automatically adjusts the decay setting to minimize current ripple. This feature allows the device to quickly be integrated into a system. The torque current can be adjusted using digital input pins. This allows the controller to save power by decreasing the current consumption when not required. a w in ic C o n A low-power sleep mode is included, which allows the system to save power when not driving the motor. www.awinic.com.cn 9 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 FEATURE DESCRIPTION PWM MOTOR DRIVERS ti a l AW8646 contains two identical H-bridge motor drivers with current-control PWM circuitry. Figure 2 shows a block diagram of the circuitry. VDD STEP step_cnt OCP DIR n XO1 fi d pwm control Vref VREF e gatedrive Stepper Motor XO2 n OCP - K=6.6 XSEN o + buffer T1 C T0 DAC 3 in ic from step_cnt 5 SIN DAC Figure 5 PWM Motor Driver Circuitry MICRO-STEPPING SEQUENCER a w Through step and direction interface the device contains a microstepping sequencer to control the state of the H-bridges automatically. When the correct transition is applied at the STEP input, thesequencer moves to the next step, according to the direction set by the DIR pin. In 1/8 th, 1/16th,and 1/32th step modes, both the rising and falling edges of the STEP input may be used to advance the sequencer, depending on the MODE0/MODE1 setting. The nEN pin can disable the output stage. When nEN = 1, the sequencer inputs are still active and respond to the STEP and DIR input pins; only the output stage is disabled. The sequencer logic in the AW8646 allows a number of different stepping configurations. The MODE0 and MODE1 pins configure the stepping format (see Table 2). www.awinic.com.cn 10 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 Table 2 Step Mode Settings n ti a l MODE1 MODE0 STEP MODE 0 0 Full step, rising-edge only 0 Z 1/2 step, rising-edge only 0 1 1/4 step, rising-edge only Z 0 8 microsteps/step, rising-edge only Z Z 8 microsteps/step, rising and falling edges Z 1 16 microsteps/step, rising-edge only 1 0 16 microsteps/step, rising and falling edges 1 Z 32 microsteps/step, rising-edge only 1 1 32 microsteps/step, rising and falling edges For 1/8, 1/16, and 1/32-step modes, selections are available to advance the sequencer only on the rising edge of the STEP input, or on both the rising and falling edges. e The step mode may be changed on-the-fly while the motor is moving. The sequencer advances to the next valid state for the new MODE0 / MODE1 setting at the next rising edge of STEP. fi d The home state is 45°. The sequencer enters the home state after power-up, after exiting UVLO, or after exiting sleep mode. CURRENT REGULATION o n The current through the motor windings is regulated by an adjustable fixed-off-time PWM current regulation circuit. When an H-bridge is enabled, current rises through the winding at a rate dependent on the DC voltage, inductance of the winding, and the magnitude of the back EMF present. After the current reaches the current control threshold, the bridge enters a decay mode for a fixed period of time to decrease the current, which is configurable between 10 to 30 μs through the tri-level input TOFF. After the time expires, the bridge is reenabled, starting another PWM cycle. Fixed Off-Time Selection C Table 3 in ic TOFF TOFF Duration Z 10 s 0 20 s 1 30 s The PWM current control is set by a comparator which compares the voltage across a current sense resistor connected to the xSEN pin, with a reference voltage. The reference voltage can be supplied by an internal reference of 3.3 V (which requires VREG to be connected to VREF), or externally supplied to the VREF pin. The reference voltage is then scaled first by the 3-bit torque DAC, then by the output of a sine lookup table that is applied to a sine-weighted DAC (sine DAC). The voltage is attenuated by a factor of 6.6. a w The full-scale (100%) control current is calculated as follows: I FS  VREF xTORQUE 6.6xR XSEN where • IFS is the full scale regulated current • VREF is the voltage on the VREF pin • RXSEN is the resistance of the sense resistor • TORQUE is the scaling percentage from the torque DAC. Example: Using VREF is 3.3 V, torque DAC = 100%, and a 500 mΩ sense resistor, the full-scale control current www.awinic.com.cn 11 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 is 3.3 V / (6.6 × 500 mΩ) × 100% = 1 A. The current for both motor windings is scaled depending on the T0 and T1 pins as in Table 4. Table 4 l CURRENT SCALING (TORQUE) 100.0% 87.5% 75.0% 62.5% 50.0% 37.5% 25.0% 12.5% 0% (outputs disabled) n ti a T0 0 Z 1 0 Z 1 0 Z 1 e T1 0 0 0 Z Z Z 1 1 1 Torque DAC Settings fi d DECAY MODE After the control current threshold is reached, the drive current is interrupted, but due to the inductive nature of the motor, current must continue to flow for some period of time (called recirculation current). To handle this recirculation current, the H-bridge can operate in two different states, fast decay or slow decay (or a mixture of fast and slow decay). o n In fast-decay mode, after the PWM control current level is reached, the H-bridge reverses state to allow winding current to flow through the opposing FETs. As the winding current approaches 0, the bridge is disabled to prevent any reverse current flow. For fast-decay mode, see number 2 in Figure 3. ic VDD C In slow-decay mode, winding current is recirculated by enabling both of the low-side FETs in the bridge. For slow-decay mode, see number 3 in Figure 3. VDD VDD ① xO2 xO1 xO2 xO2 xO1 ② ③ a w in xO1 ① Drive ② Fast decay ③ Slow decay Figure 6 Decay Modes The AW8646 supports fast, slow, mixed, and Adaptive Decay modes. With stepper motors, the decay mode is chosen for a given stepper motor and operating conditions to minimize mechanical noise and vibration. In mixed decay mode, the current recirculation begins as fast decay, but at a fixed period of time (determined by the state of the D1 and D0 pins shown in Table 5) the current recirculation switches to slow decay mode for www.awinic.com.cn 12 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 the remainder of the fixed PWM period. Note that the D1 and D0 pins are tri-level inputs; these pins can be driven logic low, logic high, or high-impedance (Z). Table 5 Decay Pins Configuration fi d Current of A e n ti a l D1 D0 Decay Mode (Increasing Current) Decay Mode (Decreasing Current) 0 0 Slow decay Slow decay 0 Z Slow decay Mixed decay: 25% fast 0 1 Slow decay Mixed decay: 1 tBLANK Z 0 Mixed decay: 1 tBLANK Mixed decay: 1 tBLANK Z Z Mixed decay: 50% fast Mixed decay: 50% fast Z 1 Mixed decay: 25% fast Mixed decay: 25% fast 1 0 Slow decay Mixed decay: 50% fast 1 Z Slow decay Mixed decay: 12.5% fast 1 1 Slow decay Fast decay Figure 4 shows increasing and decreasing current. When current is decreasing, the decay mode used is fast, slow, or mixed as commanded by the D1 and D0 pins. Three DEC pin selections allow for mixed decay during increasing current. n increasing decreasing ic Current of B C SineDAC_A o increasing decreasing increasing decreasing in increasing decreasing w SineDAC_B Figure 7 Increasing and Decreasing Current a Adaptive Decay Technology simplifies the decay mode selection by dynamically changing to adjust for current level, step change, supply variation, BEMF, and load. To enable Adaptive Decay mode, pull the ADECAY pin to logic high. The state of the ADECAY pin is only evaluated when exiting sleep mode. (ADECAY pin must be high before exiting sleep to enable Adaptive Decay mode.) Figure 5 shows Adaptive Decay mode adjusts the time spent in fast decay to minimize current ripple and quickly adjust to current-step changes. If the drive time is longer than the minimum (t BLANK), in order to reach the current trip point, the decay mode applied is slow decay. When the minimum drive time (tBLANK) provides more current than the regulation point, fast decay of 1 tBLANK is applied. If the second drive period also provides more current than the regulation point, fast decay of 2 t BLANK is applied. If a third (or more) consecutive period provides more current than the regulation point, fast decay using 25% of tOFF time is applied. When the www.awinic.com.cn 13 Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 minimum drive time is insufficient to reach the current regulation level, slow decay is applied until the current exceeds the current reference level. ti a l Current Iref fi d OVERCURRENT PROTECTION (OCP) e Figure 8 Adaptive Decay mode n STEP n An analog current limit circuit on each FET limits the current through the FET by limiting the gate drive. If this analog current limit persists for longer than the OCP deglitch time t OCP, all FETs in the H-bridge are disabled and the nFAULT pin is driven low. The device remains disabled until the retry time, t RETRY, occurs. The OCP is independent for each H-bridge. o Overcurrent conditions are detected independently on both high-side and low-side devices; that is, a short to ground, supply, or across the motor winding all result in an OCP event. Note that OCP does not use the current sense circuitry used for PWM current control, so OCP functions without the presence of the xSEN resistors. C THERMAL SHUTDOWN (TSD) If the die temperature exceeds safe limits, all FETs in the H-bridge are disabled and the nFAULT pin is driven low. After the die temperature falls to a safe level, operation automatically resumes. The nFAULT pin is released after operation has resumed. ic UNDERVOLTAGE LOCKOUT (UVLO) in If at any time the voltage on the VDD pin falls below the UVLO falling threshold voltage, V UVLO, all circuitry in the device is disabled, and all internal logic is reset. Operation resumes when VDD rises above the UVLO rising threshold. The nFAULT pin is driven low during an under voltage condition and is released after operation has resumed. Table 6 Fault Behavior Error Report nFAULT unlatched H-Bridge Disabled Internal Circuits Shut down OCP nFAULT unlatched Disabled Operating TSD nFAULT unlatched Disabled Operating a w Fault VDD UVLO www.awinic.com.cn 14 Recovery System and fault clears on recovery System and fault clears on recovery and motor is driven after time, TRETRY System and fault clears on recovery Copyright © 2018 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW8646 February 2019 V1.2 DEVICE FUNCTIONAL MODES l The AW8646 device is active unless the nSLEEP pin is driven low. In sleep mode, the VREG regulator is disabled and the H-bridge FETs are disabled (Hi-Z). The time TSLEEP must elapse after a falling edge on the nSLEEP pin before the device enters sleep mode. The AW8646 is brought out of sleep mode by bringing the nSLEEP pin high. The time TWAKE must elapse, after nSLEEP is brought high, before the outputs change state. Table 7 ti a If the nEN pin is brought high, the H-bridge outputs are disabled, but the internal logic is still active. An appropriate edge on STEP (depending on the step mode) advances the sequencer, but the outputs do not change state until nEN is driven low. Operating Modes Condition H-Bridge VREG Operating 3V
AW8646QNR 价格&库存
很抱歉,暂时无法提供与“AW8646QNR”相匹配的价格&库存,您可以联系我们找货
AW8646QNR
  • 1+6.43750
库存:1
