EMHL350ARA221MHA0G
EMHL350ARA221MHA0G
    NCC(贵弥功)
    EMHL350ARA221MHA0G
EMHL350ARA221MHA0G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MHL - High heat resistance, 125℃ Upgrade! Series ・Downsized and Longer life from current MVH series ・Endurance : 2,000 to 4,000 hours at 125℃ ・Rated voltage range : 10 to 35V. Nominal capacitance range : 47 to 680µF ・For automobile modules and other high temperature applications ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. MHL Downsized Longer life MVH ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +125℃ 10 to 35Vdc (at 20℃, 120Hz) ±20%(M) I=0.01CV Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage(Vdc) 10V 16V 25V 35V tanδ(Max.) 0.24 0.20 0.16 0.14 (at 20℃, 120Hz) Rated voltage(Vdc) 10V 16V 25V 35V Z(-25℃)/Z(+20℃) 3 2 2 2 Z(-40℃)/Z(+20℃) 6 4 4 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified time at 125℃. F61 & F80 :2,000 hours Time HA0 & JA0:4,000 hours Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size Code : A code : F61 to JA0 ● Size Code : G(Vibration resistant structure) code : F61 to JA0 Size code Vent for JA0 Vent for JA0 0.3max. W 0.3max. L±0.3 (Note) L±0.3 (Note) Note : L±0.5 for HA0 and JA0 A±0.2 Note : L±0.5 for HA0 and JA0 2 3 4 5 6 7 8 9 10 11 12 L A φD 6.3 5.8 6.6 6.3 7.7 6.6 8 10.0 8.3 10 10.0 10.3 B 6.6 6.6 8.3 10.3 C 7.2 7.2 9.0 11.0 W 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.9 1.9 3.1 4.5 A±0.2 : Dummy terminals ◆PART NUMBERING SYSTEM 1 P C±0.2 B±0.2 φD±0.5 P C±0.2 B±0.2 φD±0.5 W F61 F80 HA0 JA0 13 14 15 16 17 ◆MARKING 18 E MH L A A A A R A A A A M A A A G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470,100µF:101) Taping code Terminal code (A, G) Voltage code (ex. 35V:350) Series code Category EX) 35V47µF 2Q 47 V HL ●Rated voltage symbol Rated voltage (Vdc) Symbol A 10 C 16 E 25 V 35 Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U Ver.3 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip High heat resistance, 125℃ MHLSeries Upgrade! - ◆STANDARD RATINGS WV (Vdc) 10 16 25 35 Cap (µF) Size code 100 220 330 470 680 47 100 220 330 470 680 47 100 220 330 47 100 220 330 F61 F80 HA0 HA0 JA0 F61 F61 F80 HA0 JA0 JA0 F61 F80 HA0 JA0 F61 F80 HA0 JA0 ESR (Ω max./100kHz) 20℃ -40℃ 1.2 0.60 0.30 0.30 0.20 1.2 1.2 0.60 0.30 0.20 0.20 1.2 0.60 0.30 0.20 1.2 0.60 0.30 0.20 22 12 5.5 5.5 3.6 22 22 12 5.5 3.6 3.6 22 12 5.5 3.6 22 12 5.5 3.6 Rated ripple current (mArms/125℃, 100kHz) 110 220 296 296 440 110 110 220 296 440 440 110 220 296 440 110 220 296 440 Part No. EMHL100 □ RA101MF61G EMHL100 □ RA221MF80G EMHL100 □ RA331MHA0G EMHL100 □ RA471MHA0G EMHL100 □ RA681MJA0G EMHL160 □ RA470MF61G EMHL160 □ RA101MF61G EMHL160 □ RA221MF80G EMHL160 □ RA331MHA0G EMHL160 □ RA471MJA0G EMHL160 □ RA681MJA0G EMHL250 □ RA470MF61G EMHL250 □ RA101MF80G EMHL250 □ RA221MHA0G EMHL250 □ RA331MJA0G EMHL350 □ RA470MF61G EMHL350 □ RA101MF80G EMHL350 □ RA221MHA0G EMHL350 □ RA331MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 47 to 680 120 0.93 1k 0.97 10k 1.00 100k 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U Ver.3
EMHL350ARA221MHA0G 价格&库存
很抱歉,暂时无法提供与“EMHL350ARA221MHA0G”相匹配的价格&库存,您可以联系我们找货
