SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
MZA
Series
Low impedance, 105℃
MZA
・Endurance : 2,000 to 5,000 hours at 105℃
・Low impedance
・Solvent resistant type(see PRECAUTIONS AND GUIDELINES)
・Vibration resistant structure
・RoHS2 Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
Lower Z
MVY
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +105℃
6.3 to 100Vdc
(at 20℃, 120Hz)
±20%(M)
I=0.01CV or 3μA, whichever is greater
Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage(Vdc)
6.3V 10V 16V 25V 35V 50V 63V 80V 100V
D61 to JA0
0.26 0.19 0.16 0.14 0.12 0.10 0.08 0.08
tanδ(Max.)
KE0 to MN0
0.16 0.14 0.12 0.12 0.10 0.10
When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase.
(at 20℃, 120Hz)
Rated voltage(Vdc)
Z(-25℃)/Z(+20℃)
2
2
2
2
2
2
2
2
2
Z(-40℃)/Z(+20℃)
3
3
3
3
3
3
3
3
3
Z(-55℃)/Z(+20℃)
4
4
4
3
3
3
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified time
at 105℃.
D61 to JA0 : 2,000 hours
Time
KE0 to MN0 : 5,000 hours
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. impedance Ratio)
Endurance
◆DIMENSIONS [mm]
● Terminal
● Terminal
● Size
● Size
Vent
(Except HA0)
φD±0.5
P
C±0.2
B±0.2
φD±0.5
W
0.3max.
L±0.3 (Note)
A±0.2
L±0.5
A±0.2
Note : L±0.5 for HA0 to MN0
D61
E61
F61
F80
HA0
JA0
KE0
KG5
LH0
LN0
MH0
MN0
W
0.3max.
B±0.2
Vent for JA0
(Except D61 to HA0)
Code : G(Vibration resistant structure)
code : HA0 to MN0
Size code
P
C±0.2
Code : A
code : D61 to MN0
: Dummy terminals
D
4
5
6.3
6.3
8
10
12.5
12.5
16
16
18
18
L
5.8
5.8
5.8
7.7
10.0
10.0
13.5
16.0
16.5
21.5
16.5
21.5
B
4.3
5.3
6.6
6.6
8.3
10.3
13.0
13.0
17.0
17.0
19.0
19.0
A
4.3
5.3
6.6
6.6
8.3
10.3
13.0
13.0
17.0
17.0
19.0
19.0
C
5.1
5.9
7.2
7.2
9.0
11.0
13.7
13.7
18.0
18.0
20.0
20.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
P
1.0
1.4
1.9
1.9
3.1
4.5
4.2
4.2
6.5
6.5
6.5
6.5
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E MZA AAA A DA AAA M AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7,10µF:100)
Taping·Tray code
Terminal code (A, G)
Voltage code (ex. 6.3V:6R3,10V:100,50V:500)
Series code
Category
Please refer to "Product code guide (surface mount type)"
◆MARKING
KE0 to MN0
EX) 25V1,000µF
D61 to JA0
EX) 16V220µF
0V
MZA
2j
220
CZA
●Rated
1000
25V
voltage symbol (D61 to JA0)
Rated voltage (Vdc)
Symbol
6.3
j
10
A
16
C
25
E
35
V
50
H
63
J
80
K
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
TM
AIchip
Low impedance, 105℃
MZASeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
Cap
(µF)
Size
code
Impedance Rated ripple
( Ω max./
current
100kHz) (mArms/
20℃ -40℃ 105℃ ,100kHz)
22
D61 1.35
47
D61 1.35
47
E61 0.70
100
E61 0.70
100
F61 0.36
220
F61 0.36
330
F80 0.34
470
HA0 0.16
1,000
HA0 0.16
1,500
JA0 0.08
22
D61 1.35
33
D61 1.35
33
E61 0.70
220
F80 0.34
330
HA0 0.16
470
HA0 0.16
680
HA0 0.16
1,000
JA0 0.08
10
D61 1.35
22
D61 1.35
22
E61 0.70
47
E61 0.70
47
F61 0.36
100
F61 0.36
220
F80 0.34
330
HA0 0.16
470
HA0 0.16
680
JA0 0.08
10
D61 1.35
22
E61 0.70
33
E61 0.70
33
F61 0.36
47
F61 0.36
100
F80 0.34
220
HA0 0.16
330
HA0 0.16
470
JA0 0.08
1,000
KE0 0.060 0.30
1,300
KG5 0.056 0.28
1,800
LH0 0.047 0.24
2,400
MH0 0.045 0.23
3,000
LN0 0.034 0.17
3,900
MN0 0.032 0.16
4.7 D61 1.35
10
D61 1.35
10
E61 0.70
22
E61 0.70
33
F61 0.36
47
F61 0.36
100
F80 0.34
100
HA0 0.16
220
HA0 0.16
90
90
160
160
240
240
280
600
600
850
90
90
160
280
600
600
600
850
90
90
160
160
240
240
280
600
600
850
90
160
160
240
240
280
600
600
850
1,320
1,470
1,820
2,060
2,400
2,640
90
90
160
160
240
240
280
600
600
Part No.
EMZA6R3ARA220MD61G
EMZA6R3ARA470MD61G
EMZA6R3ARA470ME61G
EMZA6R3ARA101ME61G
EMZA6R3ARA101MF61G
EMZA6R3ARA221MF61G
EMZA6R3ARA331MF80G
EMZA6R3 □ RA471MHA0G
EMZA6R3 □ RA102MHA0G
EMZA6R3 □ RA152MJA0G
EMZA100ARA220MD61G
EMZA100ARA330MD61G
EMZA100ARA330ME61G
EMZA100ARA221MF80G
EMZA100 □ RA331MHA0G
EMZA100 □ RA471MHA0G
EMZA100 □ RA681MHA0G
EMZA100 □ RA102MJA0G
EMZA160ARA100MD61G
EMZA160ARA220MD61G
EMZA160ARA220ME61G
EMZA160ARA470ME61G
EMZA160ARA470MF61G
EMZA160ARA101MF61G
EMZA160ARA221MF80G
EMZA160 □ RA331MHA0G
EMZA160 □ RA471MHA0G
EMZA160 □ RA681MJA0G
EMZA250ARA100MD61G
EMZA250ARA220ME61G
EMZA250ARA330ME61G
EMZA250ARA330MF61G
EMZA250ARA470MF61G
EMZA250ARA101MF80G
EMZA250 □ RA221MHA0G
EMZA250 □ RA331MHA0G
EMZA250 □ RA471MJA0G
EMZA250 □ RA102MKE0S
EMZA250 □ RA132MKG5S
EMZA250 □ RA182MLH0S
EMZA250 □ RA242MMH0S
EMZA250 □ RA302MLN0S
EMZA250 □ RA392MMN0S
EMZA350ARA4R7MD61G
EMZA350ARA100MD61G
EMZA350ARA100ME61G
EMZA350ARA220ME61G
EMZA350ARA330MF61G
EMZA350ARA470MF61G
EMZA350ARA101MF80G
EMZA350 □ RA101MHA0G
EMZA350 □ RA221MHA0G
WV
(Vdc)
35
50
63
80
100
Cap
(µF)
Size
code
( Ω max./
current
100kHz) (mArms/
330
620
820
1,200
1,600
1,800
2,400
4.7
10
10
22
33
47
100
220
330
430
620
820
1,000
1,300
4.7
10
22
33
47
68
100
240
300
430
560
680
910
3.3
4.7
10
22
33
47
150
220
330
430
470
680
110
130
200
270
330
430
JA0
KE0
KG5
LH0
MH0
LN0
MN0
D61
E61
F61
F61
F80
F80
HA0
JA0
KE0
KG5
LH0
MH0
LN0
MN0
E61
F61
F80
HA0
HA0
HA0
JA0
KE0
KG5
LH0
MH0
LN0
MN0
E61
F61
F80
HA0
HA0
JA0
KE0
KG5
LH0
MH0
LN0
MN0
KE0
KG5
LH0
MH0
LN0
MN0
0.08
0.060
0.056
0.047
0.045
0.034
0.032
2.9
1.52
0.88
0.88
0.68
0.68
0.34
0.18
0.11
0.10
0.087
0.087
0.050
0.050
4.8
2.2
2.1
0.70
0.70
0.70
0.45
0.19
0.17
0.15
0.12
0.085
0.070
5.0
3.0
2.4
1.3
1.3
0.70
0.22
0.17
0.15
0.12
0.085
0.070
0.28
0.21
0.18
0.15
0.11
0.091
0.30
0.28
0.24
0.23
0.17
0.16
0.55
0.50
0.44
0.44
0.25
0.25
1.54
1.19
1.05
0.84
0.58
0.49
1.54
1.19
1.05
0.84
0.58
0.49
2.24
1.68
1.44
1.2
0.88
0.73
850
1,320
1,470
1,820
2,060
2,400
2,640
60
85
165
165
195
195
350
670
980
1,090
1,320
1,420
1,910
2,180
50
80
120
250
250
250
400
880
1,000
1,220
1,430
1,790
1,960
25
40
60
130
130
200
810
1,000
1,220
1,430
1,790
1,960
740
900
1,090
1,280
1,580
1,690
Part No.
EMZA350 □ RA331MJA0G
EMZA350 □ RA621MKE0S
EMZA350 □ RA821MKG5S
EMZA350 □ RA122MLH0S
EMZA350 □ RA162MMH0S
EMZA350 □ RA182MLN0S
EMZA350 □ RA242MMN0S
EMZA500ARA4R7MD61G
EMZA500ARA100ME61G
EMZA500ARA100MF61G
EMZA500ARA220MF61G
EMZA500ARA330MF80G
EMZA500ARA470MF80G
EMZA500 □ RA101MHA0G
EMZA500 □ RA221MJA0G
EMZA500 □ RA331MKE0S
EMZA500 □ RA431MKG5S
EMZA500 □ RA621MLH0S
EMZA500 □ RA821MMH0S
EMZA500 □ RA102MLN0S
EMZA500 □ RA132MMN0S
EMZA630ARA4R7ME61G
EMZA630ARA100MF61G
EMZA630ARA220MF80G
EMZA630 □ RA330MHA0G
EMZA630 □ RA470MHA0G
EMZA630 □ RA680MHA0G
EMZA630 □ RA101MJA0G
EMZA630 □ RA241MKE0S
EMZA630 □ RA301MKG5S
EMZA630 □ RA431MLH0S
EMZA630 □ RA561MMH0S
EMZA630 □ RA681MLN0S
EMZA630 □ RA911MMN0S
EMZA800ARA3R3ME61G
EMZA800ARA4R7MF61G
EMZA800ARA100MF80G
EMZA800 □ RA220MHA0G
EMZA800 □ RA330MHA0G
EMZA800 □ RA470MJA0G
EMZA800 □ RA151MKE0S
EMZA800 □ RA221MKG5S
EMZA800 □ RA331MLH0S
EMZA800 □ RA431MMH0S
EMZA800 □ RA471MLN0S
EMZA800 □ RA681MMN0S
EMZA101 □ RA111MKE0S
EMZA101 □ RA131MKG5S
EMZA101 □ RA201MLH0S
EMZA101 □ RA271MMH0S
EMZA101 □ RA331MLN0S
EMZA101 □ RA431MMN0S
□ : Enter the appropriate terminal code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Size code
D61 to JA0
KE0 to MN0
Capacitance(µF)
Frequency(Hz)
3.3 to 4.7
10 to 100
220 to 470
680 to 1,500
110 to 200
220 to 620
680 to 1,800
2,400 to 3,000
3,900
120
0.35
0.40
0.50
0.60
0.40
0.50
0.60
0.75
0.85
1k
0.70
0.75
0.85
0.87
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.90
0.94
0.95
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
CAT. No. E1001U
