L293
PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES
600mA OUTPUT CURRENT CAPABILITY
PER CHANNEL
1.2A PEAK OUTPUT CURRENT (non repetitive) PER CHANNEL
ENABLE FACILITY
OVERTEMPERATURE PROTECTION
LOGICAL ”0” INPUT VOLTAGE UP TO 1.5 V
(HIGH NOISE IMMUNITY)
INTERNAL CLAMP DIODES
SOP(12+4+4)
Powerdip (12+2+2)
ORDERING NUMBERS:
DESCRIPTION
The Device is a monolithic integrated high voltage, high current four channel driver designed to
accept standard DTL or TTL logic levels and drive
inductive loads (such as relays solenoides, DC
and stepping motors) and switching power transistors.
To simplify use as two bridges each pair of channels is equipped with an enable input. A separate
supply input is provided for the logic, allowing operation at a lower voltage and internal clamp diodes are included.
This device is suitable for use in switching applications at frequencies up to 5 kHz.
L293M
L293N
The L293D is assembled in a 16 lead plastic
packaage which has 4 center pins connected together and used for heatsinking
The L293DD is assembled in a 20 lead surface
mount which has 8 center pins connected together and used for heatsinking.
ORDERING INFORMATION
DEVICE
Package Type
MARKING
Packing
Packing Qty
L293N
DIP16
L293D
TUBE
1000/box
L293M/
SOP20
L293DD
REEL
2000/reel
BLOCK DIAGRAM
http://www.hgsemi.com.cn
1
2018 AUG
L293
ABSOLUTE MAXIMUM RATINGS
Symbol
Parameter
Value
Unit
V
VS
Supply Voltage
36
V SS
Logic Supply Voltage
36
V
Input Voltage
7
V
Enable Voltage
7
V
Vi
V en
Io
P tot
Tstg, Tj
Peak Output Current (100 µs non repetitive)
Total Power Dissipation at Tpins = 90 °C
Storage and Junction Temperature
1.2
A
4
W
– 40 to 150
°C
PIN CONNECTIONS (Top view)
Powerdip(12+2+2)
SOP(12+4+4)
THERMAL DATA
Symbol
DIP
SOP
Rth j-pins
Thermal Resistance Junction-pins
Decription
max.
14
°C/W
Unit
Rth j-amb
Thermal Resistance junction-ambient
max.
80
50 (*)
°C/W
Rth j-case
Thermal Resistance Junction-case
max.
14
(*) With 6sq. cm on board heatsink.
2
2018 AUG
L293
ELECTRICAL CHARACTERISTICS (for each channel, VS = 24 V, VSS = 5 V, Tamb = 25 °C, unless
otherwise specified)
Symbol
Parameter
Test Conditions
Min.
Typ.
Max.
Unit
VS
Supply Voltage (pin 10)
VSS
36
V
V SS
Logic Supply Voltage (pin 20)
4.5
36
V
IS
Total Quiescent Supply Current
(pin 10)
Vi = L ; IO = 0 ; Ven = H
2
6
mA
Vi = H ; IO = 0 ; Ven = H
16
24
mA
Ven = L
ISS
Total Quiescent Logic Supply
Current (pin 20)
44
4
mA
60
mA
16
22
mA
Ven = L
16
24
mA
– 0.3
1.5
V
V IL
Input Low Voltage (pin 2, 9, 12,
19)
VIH
Input High Voltage (pin 2, 9,
12, 19)
VSS ≤ 7 V
2.3
VSS
V
VSS > 7 V
2.3
7
V
IIL
Low Voltage Input Current (pin
2, 9, 12, 19)
VIL = 1.5 V
– 10
µA
IIH
High Voltage Input Current (pin
2, 9, 12, 19)
2.3 V ≤ VIH ≤ VSS – 0.6 V
100
µA
– 0.3
1.5
V
VSS
V
30
Ven L
Enable Low Voltage
(pin 1, 11)
Ven H
Enable High Voltage
(pin 1, 11)
VSS ≤ 7 V
2.3
VSS > 7 V
2.3
Ien L
Low Voltage Enable Current
(pin 1, 11)
Ven L = 1.5 V
Ien H
High Voltage Enable Current
(pin 1, 11)
2.3 V ≤ Ven H ≤ VSS – 0.6 V
VCE(sat)H
Source Output Saturation
Voltage (pins 3, 8, 13, 18)
IO = – 0.6 A
VCE(sat)L
Sink Output Saturation Voltage
(pins 3, 8, 13, 18)
VF
7
V
– 100
µA
± 10
µA
1.4
1.8
V
IO = + 0.6 A
1.2
1.8
V
Clamp Diode Forward Voltage
IO = 600nA
1.3
V
tr
Rise Time (*)
0.1 to 0.9 VO
250
ns
tf
Fall Time (*)
0.9 to 0.1 VO
250
ns
ton
Turn-on Delay (*)
0.5 Vi to 0.5 VO
750
ns
toff
Turn-off Delay (*)
0.5 Vi to 0.5 VO
200
ns
– 30
(*) See fig. 1.
3
2018 AUG
L293
Figure 1: Switching Times
TRUTH TABLE (one channel)
Inpu t
Enable (*)
Output
H
L
H
L
H
H
L
L
H
L
Z
Z
Z = High output impedance
(*) Relative to the considered channel
Figure 2: Junction to ambient thermal resistance vs. area on board heatsink (SOP12+4+4 package)
4
2018 AUG
L293
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
5
2018 AUG
很抱歉,暂时无法提供与“L293N”相匹配的价格&库存,您可以联系我们找货
