L293D
L293D
    XBLW(芯伯乐)
    DIP16_20X7.1MM
    双路全桥驱动,工作电压(Vcc)(v)4.5-36V,静态电流Iq(Typ)24mA,驱动电流 Iout600mA
L293D 数据手册
XBLW L293D-L293WS PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES General Description The Device is a monolithic integrated high volt-age, high current four channel driver designed to accept standard DTL or TTL logic levels and drive inductive loads (such as relays solenoides, DC and stepping motors) and switching power transistors. To simplify use as two bridges each pair of chan- nels is equipped with an enable input. A separate supply input is provided for the logic, allowing op- eration at a lower voltage and internal clamp di- odes are included. This device is suitable for use in switching appli- cations at frequencies up to 5 kHz. The L293D is assembled in a 16 lead plastic packaage which has 4 center pins connected to- gether and used for heatsinking The L293WS is assembled in a 20 lead surface mount which has 8 center pins connected to- gether and used for heatsinking. Features  600mA OUTPUT CURRENT CAPABILITY PER CHANNEL  1.2A PEAK OUTPUT CURRENT (non repetitive) PER CHANNEL  ENABLE FACILITY  OVERTEMPERATURE PROTECTION  LOGICAL "0" INPUT VOLTAGE UP TO 1.5 V (HIGH NOISE IMMUNITY)  INTERNAL CLAMP DIODES ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY L293D L293WS DIP-16 SOP-20 L293D L293WS Tube Tape 1000/Box 1000/Reel XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第1页共8页 XBLW L293D-L293WS PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES Block Diagram ABSOLUTE MAXIMUM RATINGS Symbol VS VSS Vi Ven Io Ptot Tstg,Tj Parameter Supply Voltage Logic Supply Voltage Input Voltage Enable Voltage Peak Output Current (100 μs non repetitive) Total Power Dissipation at Tpins = 90℃ Storage and Junction Temperature XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 Value Unit 36 36 7 7 1.2 4 -40 to 150 V V V V A W ℃ 第2页共8页 XBLW L293D-L293WS PIN CONNECTIONS(Top view) PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES Thermal Data Symbol Decription Rthj-pins Thermal Resistance Junction-pins Rthj-amb Thermal Resistance junction-ambient Rth j-case Thermal Resistance Junction-case (*) With 6sq. cm on board heatsink. XBLW version 1.0 max. max. max. 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 DIP SO Unit 80 14 14 50(*) - ℃/W ℃/W 第3页共8页 XBLW L293D-L293WS Electrical Characteristics PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES (for each channel,VS=24V,VSS=5V,Tamb=25℃,unless otherwise specified) Symbol Parameter Test Conditions VS Supply Voltage (pin 10) VSS Logic Supply Voltage (pin 20) Vi=L;lO=0;Ven=H Total Quiescent Supply Current IS Vi=H;lO=0;Ven =H (pin 10) Ven = L Vi=L;lO=0;Ven=H Total Quiescent Logic Supply Vi=H;lO =0;Ven=H ISS Current (pin 20) Ven = L VIL Input Low Voltage (pin 2,9,12,19) VSS≤7 V Input High Voltage (pin 2, 9,12, 19) VIH VSS>7V Low Voltage Input Current (pin IIL 2,9,12,19) VIL= 1.5V High Voltage Input Current (pin IIH 2.3V≤VIH≤Vss-0.6V 2.9,12,19) VenL Enable Low Voltage (pin 1,11) VSS≤7 V Enable High Voltage (pin 1,11) VenH VSS>7V Low Voltage Enable Current IenL Ven L= 1.5V (pin 1,11) High Voltage Enable Current IenH 2.3V≤Ven H≤VSS-0.6 V (pin 1,11) Source Output Saturation VCE(sat)H IO =-0.6 A Voltage (pins 3, 8,13,18) Sink Output Saturation Voltage VCE(sat)L IO =+0.6 A (pins 3, 8,13, 18) VF Clamp Diode Forward Voltage IO = 600nA tr Rise Time(*) 0.1 to 0.9 VO tf Fall Time(*) 0.9 to 0.1 VO ton Turn-on Delay(*) 0.5 Vi to 0.5 VO toff Turn-off Delay(*) 0.5 Vi to 0.5 VO (*) See fig. 1. Min. Vss 4.5 Typ. Max. 36 36 6 24 4 60 22 24 1.5 VSS 7 Unit V V mA mA mA mA mA mA V V V -10 μA 100 μA 1.5 VSS 7 V V V -100 μA ±10 μA 1.4 1.8 V 1.2 1.8 V 2 16 44 16 16 -0.3 2.3 2.3 30 -0.3 2.3 2.3 -30 1.3 250 250 750 200 V ns ns ns ns Truth Table(one channel) Input H L H L XBLW version 1.0 Enable(*) H H L L Output H L Z Z 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第4页共8页 XBLW L293D-L293WS PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES Figure 1: Switching Times Figure 2: Junction to ambient thermal resistance vs. area on board heatsink (SO12+4+4 package) XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第5页共8页 XBLW L293D-L293WS PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES Package Information Powerdip 16 DIM. a1 B b b1 D E e e3 F I L Z XBLW version 1.0 MIN. mm TYP. 0.51 0.85 MAX. MIN. 1.40 0.020 0.033 0.50 0.38 inch TYP. MAX. 0.055 0.020 0.50 20.0 0.015 8.80 2.54 17.78 0.020 0.787 0.346 0.100 0.700 7.10 5.10 3.30 0.280 0.201 0.130 1.27 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 0.050 第6页共8页 XBLW L293D-L293WS PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES SO20 DIM. A A1 B C D E e H h L K XBLW version 1.0 MIN. mm TYP. 2.35 0.1 0.33 0.23 12.6 7.4 MAX. MIN. 2.65 0.3 0.51 0.32 13 7.6 0.093 0.004 0.013 0.009 0.496 0.291 1.27 10 0.25 0.4 inch TYP. MAX. 0.104 0.012 0.020 0.013 0.512 0.299 0.050 10.65 0.394 0.75 0.010 1.27 0.016 0°(min.)8°(max.) 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 0.419 0.030 0.050 第7页共8页 XBLW L293D-L293WS PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第8页共8页
L293D 价格&库存
很抱歉,暂时无法提供与“L293D”相匹配的价格&库存,您可以联系我们找货
