XMS-03V(N)
XMS-03V(N)
    JST
    XMS-03V(N)
XMS-03V(N) 数据手册
Emboss Tape XA CONNECTOR Radial Tape 2.5mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– • Current rating: 3 A AC DC (AWG #22, #20) • Voltage rating: 250 V AC DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #28 to #20 • Applicable PC board thickness: 1.6 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. • Secure lock device • Solder crack preventive material • Low insertion force • Insertion guide mechanism • Applicable to automatic board mounting machine • Polarizing boss Standards––––––––––––––––––––––– 0 Recognized E 60389 1 Certified LR 20812 2 R9851220 PC board layout and Assembly layout 〈Through-hole type〉 Side entry type with a boss D ±0.05 2.8 (6.9) +0.1 (15.1) ±0.05 6.5 φ1.2 0 (11.3) φ0.9 0 2 ±0.05 +0.1 2.5 ±0.05 1.6 ±0.05 +0.1 φ0.9  0 2.5 min ±0.05 2.7min without a boss (8.1) Top entry type 2.7 9.2 2.5 ±0.05 1.6 ±0.05 2.5 〈SMT type〉 +0.1 ±0.05 φ0.9 0 Dimension D: Refer to the Model No. chart of header side entry type. Top entry type A±0.05 2.5 ±0.03 (8) (1) (11.9) ±0.1 4.65 4.25 3.3 3.3 ±0.1 1.2 ±0.1 (1.4) ±0.1 ±0.1 6.2 ±0.1 0.5 ±0.03 6.2 ±0.1 0.5 ±0.03 1.3 ±0.1 2.3 ±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side . 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 XA CONNECTOR Contact Applicable wire 1.9 Model No. SXA-001T-P0.6 SXA-01T-P0.6 SXA-001T-P0.6L AWG# Insulation O.D. (mm) 0.08∼0.33 28∼22 0.8∼1.9 8,000 0.22∼0.5 24∼20 1.5∼1.9 8,000 0.13∼0.33 26∼22 1.3∼1.7 8,000 6.5 3.1 Q'ty/reel mm2 Material and Finish 1.3 1.6 Phosphor bronze, tin-plated (reflow treatment) 2.3 RoHS compliance Note :1. SXA-001T-P0.6L is low-insertion force type contact, for easier insertion/withdrawal, which would be less resistant to the vibration. The crimp height is different from the standard contact. Note :2. Contact JST for gold-plated products. Contact Crimping machine Crimp applicator MKS-L SXA-001T-P0.6 AP-K2N SXA-001T-P0.6L Applicator Dies Contact Crimp applicator with dies MK/SXA/M-001-06 APLMK SXA/M001-06 *MKS-SC SC/SXA/M-001-06 APLSC SXA/M001-06 MKS-L MK/SXA-001-06L APLMK SXA001-06L *MKS-SC SC/SXA-001-06L APLSC SXA001-06L SXA-01T-P0.6 Crimping machine Crimp applicator AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SXA/M-01-06 APLMK SXA/M01-06 *MKS-SC SC/SXA/M-01-06 APLSC SXA/M01-06 Note :1. *Strip-crimp applicator Note :2. Contact JST for fully automatic crimping applicator. Housing Standard type 2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 20 B 2.5 2.4 9.5 6.9 A Circuit No.1 5.8 XAP-02V-1 XAP-03V-1 XAP-04V-1 XAP-05V-1 XAP-06V-1 XAP-07V-1 XAP-08V-1 XAP-09V-1 XAP-10V-1 XAP-11V-1 XAP-12V-1 XAP-13V-1 XAP-14V-1 XAP-15V-1 ― XAP-20V-1 XARP-02V XARP-03V XARP-04V XARP-05V XARP-06V XARP-07V XARP-08V XARP-09V XARP-10V XARP-11V XARP-12V XARP-13V XARP-14V XARP-15V XARP-18V ― 2.5 5.0 7.5 10.0 12.5 15.0 17.5 20.0 22.5 25.0 27.5 30.0 32.5 35.0 42.5 47.5 7.3 9.8 12.3 14.8 17.3 19.8 22.3 24.8 27.3 29.8 32.3 34.8 37.3 39.8 47.3 52.3 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 500 500 ― 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 500 500 ― Retainer mountable type B 2.5 2.4 7.4 0.6 RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 10.5 A Circuit No.1 ex. 5.8 XAP-02V-1-oo(blank)…natural (white) K…black R…red E…blue Y…yellow L…lemon yellow M…green O…orange N…brown H…gray P…purple LE…light blue PK…pink FY…vivid yellow Z…ivory ex. 2 XARP-02V-oo (blank)…natural (white) K…black R…red E…blue L…lemon yellow XA CONNECTOR Retainer 2.5 0.95 2.5 A XMS-02V XMS-03V XMS-04V XMS-05V XMS-06V XMS-07V XMS-08V XMS-09V XMS-10V XMS-11V XMS-12V XMS-13V XMS-14V XMS-15V 7.8 RoHS compliance Through-hole type shrouded header Top entry type without a boss A B 6.4 2 3 Circuit No.1 4 5 7 6.5 8.8 6 8 3.4 9 10 11 2.5 φ0.6 3.2 12 13 A 14 15 20 Top entry type with a boss B 2.5 7.5 1,000 5.0 10.0 400 7.5 12.5 400 10.0 15.0 400 12.5 17.5 400 15.0 20.0 250 17.5 22.5 250 20.0 25.0 250 22.5 27.5 250 25.0 30.0 200 27.5 32.5 200 30.0 35.0 100 32.5 37.5 100 35.0 40.0 100 47.5 52.5 100 RoHS compliance This product displays (LF)(SN) on a label. Note: Contact JST for gold-plated products. 6.5 8.8 1.5 2 3.4 3 4 5 φ0.6 φ1 A 1.6 6 1.6 3.2 7 8 9 Side entry type with a hook 10 11 12 B 12.6 13 14 S02B-XASS-1 S03B-XASK-1 S04B-XASK-1 S05B-XASK-1 S06B-XASK-1 S07B-XASK-1 S08B-XASK-1 S09B-XASK-1 S10B-XASK-1 S11B-XASK-1 S12B-XASK-1 S13B-XASK-1 S14B-XASK-1 A B D 2.5 7.5 1.25 250 5.0 10.0 2.50 250 7.5 12.5 3.75 200 10.0 15.0 5.00 200 12.5 17.5 6.25 200 15.0 20.0 7.50 200 17.5 22.5 8.75 100 20.0 25.0 10.00 100 22.5 27.5 11.25 100 25.0 30.0 12.50 100 27.5 32.5 13.75 100 30.0 35.0 15.00 100 32.5 37.5 16.25 100 3.2 H JST 3.5 7.6 Circuit No.1 Circuit No.1 Mark B02B-XASK-1-A B03B-XASK-1-A B04B-XASK-1-A B05B-XASK-1-A B06B-XASK-1-A B07B-XASK-1-A B08B-XASK-1-A B09B-XASK-1-A B10B-XASK-1-A B11B-XASK-1-A B12B-XASK-1-A B13B-XASK-1-A B14B-XASK-1-A B15B-XASK-1-A B20B-XASK-1-A 6.4 Circuit No.1 2.5 B02B-XASK-1 B03B-XASK-1 B04B-XASK-1 B05B-XASK-1 B06B-XASK-1 B07B-XASK-1 B08B-XASK-1 B09B-XASK-1 B10B-XASK-1 B11B-XASK-1 B12B-XASK-1 B13B-XASK-1 B14B-XASK-1 B15B-XASK-1 B20B-XASK-1 B 1.8 φ0.6 2.5 A 2.7 9.2 RoHS compliance This product displays (LF)(SN) on a label. Note: 1. Dimension D…See PC board layout. 2. Contact JST for gold-plated products. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. S02B-XASK-1S…natural (ivory) K…black R…red E…blue M…green Y…yellow 3 XA CONNECTOR Through-hole type shrouded header N type Top entry type without a boss 2 3 4 B 6.4 Circuit No.1 5 6 7 9 6.5 8.8 8 10 3.4 11 12 13 2.5 φ0.6 3.2 14 15 A 18 Top entry type with a boss B02B-XASK-1N B03B-XASK-1N B04B-XASK-1N B05B-XASK-1N B06B-XASK-1N B07B-XASK-1N B08B-XASK-1N B09B-XASK-1N B10B-XASK-1N B11B-XASK-1N B12B-XASK-1N B13B-XASK-1N B14B-XASK-1N B15B-XASK-1N B18B-XASK-1N B02B-XASK-1N-A B03B-XASK-1N-A B04B-XASK-1N-A B05B-XASK-1N-A B06B-XASK-1N-A B07B-XASK-1N-A B08B-XASK-1N-A B09B-XASK-1N-A B10B-XASK-1N-A B11B-XASK-1N-A B12B-XASK-1N-A B13B-XASK-1N-A B14B-XASK-1N-A B15B-XASK-1N-A ― A B 2.5 7.5 1,000 5.0 10.0 400 7.5 12.5 400 10.0 15.0 400 12.5 17.5 400 15.0 20.0 250 17.5 22.5 250 20.0 25.0 250 22.5 27.5 250 25.0 30.0 200 27.5 32.5 200 30.0 35.0 100 32.5 37.5 100 35.0 40.0 100 42.5 47.5 100 RoHS compliance This product displays (LF)(SN) on a label. B 6.4 Circuit No.1 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 6.5 B02B-XASK-1N-AS…natural (white) K…black R…red E…blue Y…yellow L…lemon yellow M…green O…orange N…brown H…gray P…purple LE…light blue PK…pink FY…vivid yellow 3.4 1.5 8.8 ex. 2.5 φ0.6 φ1 A 1.6 1.6 3.2 2 3 4 Side entry type without a hook 5 6 7 12.6 B Circuit No.1 8 9 10 11 7.6 12 H JST 13 A B 02.5 7.5 250 05.0 10.0 250 07.5 12.5 200 10.0 15.0 200 12.5 17.5 200 15.0 20.0 200 17.5 22.5 100 20.0 25.0 100 22.5 27.5 100 25.0 30.0 100 27.5 32.5 100 30.0 35.0 100 32.5 37.5 100 3.2 14 S02B-XASS-1N-BN S03B-XASS-1N-BN S04B-XASS-1N-BN S05B-XASS-1N-BN S06B-XASS-1N-BN S07B-XASS-1N-BN S08B-XASS-1N-BN S09B-XASS-1N-BN S10B-XASS-1N-BN S11B-XASS-1N-BN S12B-XASS-1N-BN S13B-XASS-1N-BN S14B-XASS-1N-BN Circuit No.1 Mark 4 φ0.6 2.5 A 9.2 RoHS compliance This product displays (LF)(SN) on a label. Note: 1. As for side entry type, we recommend to use a product with a boss (hook) because stress is applied directly to fillet part when handling the wire. When using the side entry type product without a boss (hook), please handle the wire with care. XA CONNECTOR SMT type shrouded header A 2 B A 1.4 8 1 3 Circuit No.1 4 5 7.1 9.4 6 7 8 9 12 13 15 BM02B-XASS-TF BM03B-XASS-TF BM04B-XASS-TF BM05B-XASS-TF BM06B-XASS-TF BM07B-XASS-TF BM08B-XASS-TF BM09B-XASS-TF BM12B-XASS-TF BM13B-XASS-TF BM15B-XASS-TF B 2.5 10.0 500 5.0 12.5 500 7.5 15.0 500 10.0 17.5 500 12.5 20.0 500 15.0 22.5 500 17.5 25.0 500 20.0 27.5 500 27.5 35.0 500 30.0 37.5 500 35.0 42.5 500 B 1.4 A 8 1 Circuit No.1 7.1 9.4 RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. BM02B-XASS-TFS…natural K…black R…red E…blue Through-hole type shrouded header on radial-tape Top entry type without a boss A 2 B A 3 Circuit No.1 4 6.4 5 2.5 6 6.5 8.8 7 2.8 8 φ  0.6 B02B-XASS-1-T B03B-XASS-1-T B04B-XASS-1-T B05B-XASS-1-T B06B-XASS-1-T B07B-XASS-1-T B08B-XASS-1-T − B03B-XASS-1-A-T B04B-XASS-1-A-T B05B-XASS-1-A-T B06B-XASS-1-A-T B07B-XASS-1-A-T B08B-XASS-1-A-T B 2.5 7.5 1,000 5.0 10.0 1,000 7.5 12.5 500 10.0 15.0 500 12.5 17.5 500 15.0 20.0 500 17.5 22.5 500 3.2 RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. Top entry type with a boss B03B-XASS-1-A-TS…natural (ivory) R…red E…blue M…green Taping specifications B A 6.4 Circuit No.1 6.4 6 3.2 18 1.6 2.8 1.6 φ  0.6 20 6.5 8.8 1.5 2.5 12.7 φ4 Note: Conforms to JIC C 0806 of "Tape packaging of components with unidirectional leads on continuous tapes". 5 XA CONNECTOR Packaging specifications Package type Distance between folds Box size Distance between the end of the tape and the first connector s center line (either end) D TERMIN H ALS & CONN W Distance between the end of the tape and the first connector's center line (either end) 6 316(W)×45(D)×330(H) mm 19.05 mm 1,000 pcs./box 2, 3 circuits 500 pcs./box 4∼8 circuits Note: Products of different packaging specifications are also available. Contact JST for details. Quantity ECTORS R Tail tape Flat pack (zigzag folded) 24 indexing holes per fold (304.8 mm) Leader tape
XMS-03V(N) 价格&库存
很抱歉,暂时无法提供与“XMS-03V(N)”相匹配的价格&库存,您可以联系我们找货
