PXA CONNECTOR
2.5mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
Secondary retainer mountable 2.5mm pitch
high-box type, with 20.5mm mounting
height.
Fully shrouded header has the walls
between every circuit to consider as the
structure against vibration or prying.
• Secure locking device
• Fully shrouded header
• Header for use specifically with resin coated
("potted") PC boards
• PC board layout is exactly same as
XA connector
• Secondary retainer
• Current rating: 3A AC, DC (AWG #22)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 1,000V AC/minute
• Applicable wire: AWG #26 to #22
• Applicable PC board thickness: 1.6mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
PC board layout (viewed from component side) and Assembly layout
(8.95)
±0.1
1.6 ±0.05
φ0.9 +0.10
(20.5)
2.5 ±0.05
1.6 ±0.05
A
φ1.2 +0.10
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimension differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should
be larger. The dimensions above should serve as a guideline. Contact JST for details.
Contact
Applicable wire
mm2
AWG#
Model No.
SPXA-001T-P0.6
0.13∼0.33
Insulation O.D. (mm)
個数//
Q'ty
リreel
ール
1.2∼1.9
7,000
26∼22
Material and Finish
7.3
3.1
1.15
Phosphor bronze, tin-plated (reflow treatment)
2.9
2.3
RoHS compliance
Contact
Crimping
machine Crimp applicator
SPXA-001T-P0.6 AP-K2N
1
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SPXA-001-06 APLMK SPXA001-06
PXA CONNECTOR
Housing
B
A
7.4
0.6
2.5
Circuits
Model No.
2
PXARP-02V
PXARP-03V
PXARP-06V
3
6
Dimensions (mm)
A
B
Q'ty /bag
2.5
7.3
1,000
5.0
9.8
1,000
12.5
17.3
1,000
10.5
Material
PA 66, UL94V-0, natural (white)
RoHS compliance
Circuit No.1
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
PXARP-02V-00(blank)…natural (white)
K…black R…red E…blue
Shrouded header
6.4
B
Dimensions (mm)
A
B
Circuits
Model No.
2
BH02B-PXASK
BH03B-PXASK
BH06B-PXASK
3
6
Q'ty /box
2.5
7.5
400
5.0
10.0
400
12.5
17.5
200
17.0
Material and Finish
3.3
1.5
RoHS compliance This product displays (LF)(SN) on a label.
φ1.0
2.5
A
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: Glass-filled PA 66, UL94V-0, natural (ivory)
1.6
Circuit No.1
1.6
7.35
ex.
BH02B-PXASKS…natural (ivory)
Retainer
Circuits
Model No.
A
2
XMS-02V
XMS-03V
XMS-06V
2.5
1,000
5.0
1,000
12.5
1,000
3
A
6
Q'ty / bag
2.5
Material
2.5
7.8
(0.95)
RoHS compliance
2
很抱歉,暂时无法提供与“XMS-03V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 150+0.32492
- 300+0.31658
- 450+0.30929
- 600+0.30096
- 750+0.29367
