2140
    HEYCO
2140 数据手册
“Stay Connected” with Bushings, Grommets, HEYcaps & Plugs ® Heyco Snap Bushings ® Mounting Hole Diameter Range: 1.000˝ (25,4 mm) to 2.500˝ (63,5 mm) MOUNTING HOLE DIAMETER in. PART NO. Black DESCRIPTION PART DIMENSIONS B Head Diameter in. mm. A Inside Diameter in. mm. White mm. C Overall Height in. mm. Multiple Locking Steps for Panel Thickness up to .125˝ (3,2 mm) 1.000 25,4 2140 2141 SB 1000-12 .77 19,4 1.13 28,6 1.093 1.125 27,8 28,6 2160 2163 2166 2161 2164 2167 SB 1093-13 SB 1093-14 SB 1093-15 .81 .88 .94 20,6 22,2 23,8 1.22 30,9 1.187 30,2 2182 2183 SB 1187-15 .94 23,8 1.31 33,3 1.250 31,8 2198 2201 2199 2202 SB 1250-15 SB 1250-16 .94 1.00 23,8 25,4 1.36 1.31 34,5 33,3 1.375 34,9 2207 2210 2208 2211 SB 1375-14 SB 1375-16 .88 1.01 22,2 25,8 1.49 37,9 38,1 2233 2236 2240 2234 2237 2241 SB 1500-17 SB 1500-18 SB 1500-21 1.06 1.13 1.31 27,0 28,6 33,3 1.61 40,9 1.500 1.625 41,3 2273 2274 SB 1625-21 1.31 33,3 1.74 44,2 1.750 44,5 2300 2301 SB 1750-22 1.38 34,9 1.88 47,6 1.875 47,6 2287 2288 SB 1875-24 1.50 38,1 2.00 50,8 50,8 2400 2406 2401 2414 SB 2000-26 SB 2000-28 1.64 1.75 41,6 44,5 2.13 54,0 2.000 .45 11,5 .72 18,3 • Convert raw-edged holes to smooth, neat, insulated holes. • Insulate and mechanically protect electrical and telecommunications cables, tubing, hose, rope, and utility lines. • Locking fingers snap into holes with fingertip pressure. • Locking fingers in fractional increments up to the maximum panel thickness. • Withstand a push back force of 35 pounds. • Available in multiple sizes for use in .250˝ (6,4 mm) to 6.00˝ (152,4 mm) diameter holes. • We offer the following brass-colored parts for lamp and lighting applications: Part No. 2012, SB 312-3 Brass Part No. 2033, SB 375-4 Brass Part No. 2041, SB 437-4 Brass Multiple Locking Steps for Panel Thickness up to .250˝ (6,4 mm) 2.093 53,1 2.250 57,2 2.500 63,5 2415 2419 2417 2420 2416 2418 2421 SB 2.093-29 SB 2.250-29-180 SB 2.250-29 SB 2.500-31 1.81 1.80 1.86 1.97 46,0 45,7 47,1 50,0 2.35 59,7 2.48 63,1 2.66 67,5 NEW! Standard colors black and white. Consult Heyco for other colors. Larger 3.000˝ (76,2 mm) to 6.000˝ (152,4 mm) Diameter Parts Small Packs Available MOUNTING HOLE DIAMETER in. PART NO. Black DESCRIPTION White PACKAGING BULK SMALL (Std) PACK* mm. PART DIMENSIONS A B C Inside Head Overall Diameter Diameter Height in. mm. in. mm. in. mm. Multiple Locking Steps for Panel Thickness up to .250˝ (6,4 mm) B 2461 2462 SB 3.000-39 300 5 2.47 62,7 3.15 80,0 .75 19,1 2424 2425 SB 3.000-44 300 5 2.75 69,9 3.16 80,2 .72 18,3 2407 2470 2408 2471 SB 3.375-45 SB 3.500-47 400 200 5 5 2.81 2.94 71,4 74,7 3.66 93,0 .72 18,3 101,6 2479 2480 SB 4.000-55 300 5 3.47 88,1 4.15 105,4 127,0 152,4 2409 2484 2410 2485 SB 5.000-70 SB 6.000-86 150 130 1 1 4.38 5.38 113,8 139,2 5.22 6.22 132,6 157,9 .74 18,8 3.000 76,2 3.375 3.500 85,7 88,9 4.000 5.000 6.000 C MULTIPLE PANEL DESIGN A Standard colors black and white. Consult Heyco for other colors. *Small Pack available in Black color only. To order, please add the suffix -P to Part No., e.g., 2461-P Material Certifications Flammability Rating Temperature Range Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories, File E15331 Certified by Canadian Standards Association, File 8919 94V-2 -.4°F (-18°C) to 221°F (105°C) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com Quick Specs 6-4
很抱歉,暂时无法提供与“2140”相匹配的价格&库存,您可以联系我们找货
  • 200+0.48462200+0.05874
  • 500+0.48236500+0.05847
  • 1500+0.482341500+0.05847
  • 3000+0.482333000+0.05847
  • 10000+0.4823210000+0.05847
  • 7500+0.453997500+0.05503
  • 15000+0.4518715000+0.05477
  • 22500+0.4518622500+0.05477
  • 30000+0.4518530000+0.05477
  • 37500+0.4518437500+0.05477
