74HC07
74HC07 HEX BUFFER (OPEN DRAIN)
HIGH SPEED:
tPD = 6ns (TYP.) at VCC = 6V
LOW POWER DISSIPATION:
ICC = 1µA(MAX.) at TA=25°C
HIGH NOISE IMMUNITY:
VNIH = VNIL = 28 % VCC (MIN.)
WIDE OPERATING VOLTAGE RANGE:
VCC (OPR) = 2V to 6V
PIN AND FUNCTION COMPATIBLE WITH
74 SERIES 07
DIP
SOP
TSSOP
ORDER CODES
PACKAGE
DIP
SOP
DESCRIPTION
The 74HC07 is an high speed CMOS HEX
OPEN DRAIN BUFFER fabricated with silicon
gate C2MOS technology.
The internal circuit is composed of 2 stages
including buffer output, which enables high noise
immunity and stable output.
TUBE
74HC07B
74HC07M
T&R
74HC07RM13TR
All inputs are equipped with protection circuits
against static discharge and transient excess
voltage.
PIN CONNECTION AND IEC LOGIC SYMBOLS
http://www.hgsemi.net
1
2015 JAN
74HC07
INPUT AND OUTPUT EQUIVALENT CIRCUIT
PIN DESCRIPTION
PIN No
SYMBOL
1, 3, 5, 9, 11,
13
2, 4, 6, 8, 10,
12
7
NAME AND FUNCTION
1A to 6A
Data Inputs
1Y to 6Y
Data Outputs
GND
VCC
Ground (0V)
14
Positive Supply Voltage
TRUTH TABLE
A
Y
L
H
L
Z
Z : High Impedance
ABSOLUTE MAXIMUM RATINGS
Symbol
VCC
Parameter
Supply Voltage
Value
Unit
-0.5 to +7
V
VI
DC Input Voltage
-0.5 to VCC + 0.5
V
VO
DC Output Voltage
IIK
DC Input Diode Current
-0.5 to VCC + 0.5
± 20
mA
IOK
DC Output Diode Current
± 20
mA
IO
DC Output Current
± 25
mA
ICC or IGND DC VCC or Ground Current
PD
Power Dissipation
Tstg
Storage Temperature
TL
Lead Temperature (10 sec)
V
± 50
mA
500(*)
mW
-65 to +150
°C
300
°C
Absolute Maximum Ratings are those values beyond which damage to the device may occur. Functional operation under these conditions is
not implied
(*) 500mW at 65 °C; derate to 300mW by 10mW/°C from 65°C to 85°C
RECOMMENDED OPERATING CONDITIONS
Symbol
VCC
Parameter
Value
Supply Voltage
Unit
2 to 6
V
VI
Input Voltage
0 to VCC
V
VO
Output Voltage
0 to VCC
V
Top
Operating Temperature
-55 to 125
°C
VCC = 2.0V
0 to 1000
ns
VCC = 4.5V
0 to 500
ns
VCC = 6.0V
0 to 400
ns
Input Rise and Fall Time
tr, tf
2
2015 JAN
74HC07
DC SPECIFICATIONS
Test Condition
Symbol
VIH
VIL
VOL
II
IOZ
ICC
Parameter
High Level Input
Voltage
Low Level Input
Voltage
Low Level Output
Voltage
Input Leakage
Current
Output Leakage
Current
Quiescent Supply
Current
Value
TA = 25°C
VCC
(V)
Min.
2.0
4.5
6.0
2.0
4.5
6.0
Typ.
Max.
1.5
3.15
4.2
-40 to 85°C
-55 to 125°C
Min.
Min.
Max.
1.5
3.15
4.2
Unit
Max.
1.5
3.15
4.2
V
0.5
1.35
1.8
0.5
1.35
1.8
0.5
1.35
1.8
V
2.0
IO=20 µA
0.0
0.1
0.1
0.1
4.5
IO=20 µA
0.0
0.1
0.1
0.1
6.0
IO=20 µA
0.0
0.1
0.1
0.1
4.5
IO=4.0 mA
0.17
0.26
0.33
0.40
6.0
IO=5.2 mA
0.18
0.26
0.33
0.40
6.0
VI = VCC or GND
± 0.1
±1
±1
µA
6.0
VI = VIH or VIL
VO = VCC or GND
±0.5
±5
± 10
µA
6.0
VI = VCC or GND
1
10
µA
V
AC ELECTRICAL CHARACTERISTICS (CL = 50 pF, Input tr = tf = 6ns)
Test Condition
Symbol
tTHL
tPLZ
tPZL
Parameter
Output Transition
Time
Propagation Delay
Time
Propagation Delay
Time
Value
TA = 25°C
VCC
(V)
2.0
4.5
6.0
2.0
4.5
6.0
2.0
4.5
6.0
Min.
RL = 1 K Ω
RL = 1 K Ω
3
Typ.
Max.
30
8
7
10
7
6
17
7
5
75
15
13
90
18
15
90
18
15
-40 to 85°C
-55 to 125°C
Min.
Min.
Max.
95
19
16
115
23
23
Unit
Max.
110
22
19
135
27
23
135
27
23
ns
ns
ns
2015 JAN
74HC07
CAPACITIVE CHARACTERISTICS
Test Condition
Symbol
Parameter
CIN
Input Capacitance
COUT
Output
Capacitance
Power Dissipation
Capacitance (note
1)
CPD
Value
TA = 25°C
VCC
(V)
Min.
-40 to 85°C
-55 to 125°C
Min.
Min.
Max.
Unit
Typ.
Max.
5.0
5
10
5.0
3
pF
5.0
4
pF
10
Max.
10
pF
1) CPD is defined as the value of the IC’s internal equivalent capacitance which is calculated from the operating current consumption without
load. (Refer to Test Circuit). Average operating current can be obtained by the following equation. ICC(opr) = CPD x VCC x fIN + ICC/6 (per gate)
TEST CIRCUIT
CL = 50pF or equivalent (includes jig and probe capacitance)
RT = ZOUT of pulse generator (typically 50Ω)
WAVEFORM : PROPAGATION DELAY TIME (f=1MHz; 50% duty cycle)
4
2015 JAN
很抱歉,暂时无法提供与“74HC07M/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.91444
- 50+0.73300
- 150+0.65524
- 500+0.55815
- 2500+0.51495
