U053
U053
    M5STACK
    U053
U053 数据手册
M5StickC ENV Hat (DHT12, BMP280, BMM150) SKU: U053 Hat ENV It is able to detect the temperature, humidity, air pressure and magnetic field. This product relates via I2C protocol which allows you to obtain 4 types of environment data thru just 2pins, together with the tiny body, makes it a powerful application for envitonment data collecting. Product Feature • • • temperature: o Range: -20 ~ 60 ℃ o Error: ±0.2℃ Humidity: o Range: 20 ~ 95 %RH o Error: 0.1% Air pressure: o Range: 300 ~ 1100hPa o Error: ±1hPa Typical Magnetic Field: - ±1300μT(x,y-axis),±2500μT(z-axis) - magnetic field resolution: 0.3μT Package Includes • 1x ENV Hat Application • • Weather Station Compass Schematic Example • Arduino Pin Map M5StickC GPIO0 GPIO26 5V GND HAT ENV SDA SCL 5V GND https://m5stack.com/collections/m5-unit/products/m5stickc-env-hat/12-99-19
很抱歉,暂时无法提供与“U053”相匹配的价格&库存,您可以联系我们找货
