U053-D
U053-D
    M5STACK
    QMP6988,SHT30 湿度,压力,温度 传感器 M5StickC 平台评估扩展板
U053-D 数据手册
ENV III HAT SKU:U053-D Description ENV III HAT is a multifunctional environmental sensor adapted to the M5StickC series. It integrates SHT30 and QMP6988 internally to detect temperature, humidity, and atmospheric pressure data. SHT30 (0x44) is a high-precision, low-power digital temperature sensor. Humidity sensor. QMP6988 (0x56) is an absolute air pressure sensor specially designed for mobile applications with high accuracy. For projects that require rapid collection and detection of environmental data, ENV-III HAT is a balanced performance Good choice with cost performance. Product Features Temperature, humidity, air pressure High reliability and long-term stability High accuracy Include 1x ENV III HAT 1x double-sided tape Applications Weather station Storage barn environment monitoring Specification Resources Resources Parameter Parameter Maximum temperature measurement range -40 ~ 120 ℃ Highest measurement accuracy 0 ~ 60 ℃/±0.2℃ Humidity measurement range/error 10 ~ 90 %RH / ±2% Maximum measured value of air pressure/resolution/error 300 ~ 1100hPa / 0.06Pa / ±3.9Pa Communication protocol I2C: SHT30(0x44), QMP6988(0x56) Working temperature 32°F to 104°F (0°C to 40°C ) Net weight 4g Gross weight 8g Product Size 15*24*14mm Package Size 36*36*18mm Case Material Plastic ( PC ) PinMap M5StickC GPIO26 GPIO0 3.3V GND ENV III HAT SCL SDA 3.3V GND Schematic Related Link Datasheet QMP6988 SHT30 Example Arduino HAT ENV III TEST
U053-D 价格&库存
很抱歉,暂时无法提供与“U053-D”相匹配的价格&库存,您可以联系我们找货
