PS5100LT
PS5100LT
5.0AMPS. SCHOTTKY BARRIER RECTIFIERS
FEATURE
MECHANICAL DATA
.For surface mounted application
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge current capability
.High temperature soldering guaranteed:
260℃/10 seconds at terminals.
.Terminal: Solder plated
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy
.ESD Ratings:(JESD22-A114) Human Body Model ,
Level 2
PS-277B
D
b2
A
D2
A2
L
W1
E2
W
E1
E
L1
e
b1
b1
A2
NO
Dimensions
NO
Dimensions
A
1.20±0.1
e
1.84Typ
A2
0.25±0.05
E1
5.3±0.1
b1
0.9±0.1
E2
3.3±0.2
b2
1.8±0.1
L
0.6±0.1
D
3.95±0.1
L1
0.6±0.1
D2
3.00Typ
W
1.3±0.2
E
6.5±0.1
W1
0.8±0.15
All Dimensions in mm
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20%
Type Number
SYMBOL
PS5100LT
units
VRRM
VRMS
VDC
IF(AV)
100
V
70
V
100
V
5.0
A
IFSM
120.0
A
VF
0.60
V
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC blocking Voltage
Average Forward Rectified Output Current
Peak Forward Surge Current 8.3ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Forward Voltage at 5.0A DC
Maximum DC Reverse Current
@TJ=25°C
atrated DCblocking voltage
@TJ =100°C
IR
CJ
R(JA)
R(JC)
TSTG
TJ
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Storage Temperature
Operating Junction Temperature
0.1
20.0
650
45
31
pF
°C/W
-55 to +150
°C
-55 to +150
°C
Note:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Polymide PCB, 2oz. Copper. Cathode pad dimensions 18.8mm x 14.4mm. Anode pad dimensions 5.6mm x 14.4mm.
1
mA
PS5100LT
RATING AND CHARACTERISTIC CURVES (PS5100LT)
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
5.0
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
2.5
Single Phase Half Wave
60Hz Resistive or
inductive Load
TJ=25℃
Pulse Width=300μs
1% Duty Cycle
2
LEAD TEMPERTURE,(℃)
1.0
FIG.4-TYPICAL REVERSE CHARACTERISTICS
8.3ms Single Half
Sine-Wave (JEDEC
Method)
INSTANEOUS REVERSE
CURRENT,(mA)
PEAK FORWARD SURGE
CURRENT,(A)
120
0.8
INSTANEOUS FORWARD VOLTAGE,(V)
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
160
0.6
80
40
TJ=25℃
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
2
PS5100LT
Marking、Pad Layout 、MOQ and Packaging illustration
1、Marking
PS5100LT
PY XXXXX
SYMBOL
A
B
C
A
C
B
2、Suggested Pad Layout
Explanation
Product Name
Trademark
Date Code
Dimensions
Value (in mm)
Z
6.6
X1
1.4
X2
3.6
Y1
0.8
Y2
4.7
C
3.87
E1
0.9
3、MOQ
3000pcs / Tape & Reel
4、Packaging
d
Top cover tape thickness
0.10mm(0.004") max.thick
W1
W1
Embossed
carrier tape
° MAX
° MAX
A
SPECIFICATIONS
Embossed cavity
Carrier width
SYM
BOL
A
4.45(0.175)Max
SPECIFICATIONS
mm(inch)
SYM
ITEM
BOL
K
Carrier depth
Carrier length
B
7.0(0.276)Max
Punch hole pitch
P
Sprocket hole
d
ø1.55(0.061)Typ
Sprocket hole pitch
P0
4.00(0.157)Typ
Reel outer diameter
D
330.0(13.0)Typ
Embossment center
P1
2.00(0.079)Typ
Reel inner diameter
D1
74.0(2.913)Min
Overall tape thickness
T
0.25(0.010)Typ
Feed hole diameter
D2
13.0(0.512)Typ
Tape width
W
16.0(0.630)Typ
Sprocket hole position
J
1.75(0.069)Typ
Reel width
W1
16.5(0.650)Min
Punch hole position
H
7.50(0.295)Typ
PACKAGE
mm(inch)
ITEM
PS-277B
3
PACKAGE
PS-277B
1.60(0.063)Typ
8.00(0.315)Typ
很抱歉,暂时无法提供与“PS5100LT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.06964
- 50+0.93021
- 150+0.87038
- 500+0.79586
- 3000+0.75352
- 6000+0.73354
