INTEGRATED CIRCUITS
74LVC139
Dual 2-to-4 line decoder/demultiplexer
Product specification
Supersedes data of 1997 Jun 19
IC24 Data Handbook
1998 Apr 28
Philips Semiconductors
FEATURES
74LVC139
DESCRIPTION
• Wide supply voltage range of 1.2 to 3.6 V
• In accordance with JEDEC standard no. 8-1A
• Inputs accept voltages up to 5.5 V
• CMOS lower power consumption
• Direct interface with TTL levels
• Demultiplexing capability
• Two independent 2-to-4 decoders
• Multifunction capability
• Active LOW mutually exclusive outputs
• Output drive capability 50 transmission lines at 85°C
The 74LVC139 is a low-voltage, low-power, high-performance
Si-gate CMOS device, superior to most advanced CMOS
compatible TTL families.
The 74LVC139 is a dual 2-to-4 line decoder/demultiplexer. This device
has two independent decoders, each accepting two binary weighted
inputs (nA0 and nA1) and providing four mutually exclusive active LOW
outputs (nY0 to nY3). Each decoder has an active LOW input (nE).
When nE is HIGH, every output is forced HIGH. The enable can be
used as the data input for a 1-to-4 demultiplexer application.
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25°C; tr = tf ≤ 2.5 ns
PARAMETER
SYMBOL
tPHL/tPLH
Propagation delay
nA to nYn,
nE to nYn,
CI
Input capacitance
CONDITIONS
CL = 50 pF;
VCC = 3.3 V
Power dissipation capacitance per
multiplexer
CPD
VCC = 3.3 V
Notes 1 and 2
TYPICAL
UNIT
3.3
3.2
ns
5.0
pF
36
pF
NOTES:
1. CPD is used to determine the dynamic power dissipation (PD in µW)
PD = CPD × VCC2 × fi (CL × VCC2 × fo) where:
fi = input frequency in MHz; CL = output load capacity in pF;
fo = output frequency in MHz; VCC = supply voltage in V;
(CL × VCC2 × fo) = sum of the outputs.
2. The condition is V1 = GND to VCC
ORDERING INFORMATION
PACKAGES
TEMPERATURE RANGE
OUTSIDE NORTH AMERICA
NORTH AMERICA
PKG. DWG. #
16-Pin Plastic SO
–40°C to +85°C
74LVC139 D
74LVC139 D
SOT109-1
16-Pin Plastic SSOP Type II
–40°C to +85°C
74LVC139 DB
74LVC139 DB
SOT338-1
16-Pin Plastic TSSOP Type I
–40°C to +85°C
74LVC139 PW
74LVC139PW DH
SOT403-1
PIN CONFIGURATION
PIN DESCRIPTION
PIN NUMBER
1E 1
SYMBOL
16 VCC
1, 15
1E, 2E
1A0
2
15 2E
2, 3
1A0, 1A1
1A1
3
14 2A0
14, 13
2A0, 2A1
1Y0
4
13 2A1
4, 5, 6, 7
1Y0 to 1Y3
1Y1
5
9
12, 11, 10, 9
2Y0 to 2Y3
1Y2
6
10 2Y1
1Y3
7
11 2Y2
GND
8
12 2Y3
2Y0
NAME AND FUNCTION
Enable inputs (active LOW)
Address in
inputs
uts
Outputs
Out
uts (active LOW)
8
GND
Ground (0 V)
16
VCC
Positive supply voltage
SV00530
1998 Apr 28
2
853-2059 19309
74LVC139
LOGIC DIAGRAM
FUNCTIONAL DIAGRAM
1
1Y0
1E
2
4
1Y 0
2
1A 0
1Y 1
5
3
1A 1
1Y 2
6
1Y 3
7
2Y 0
12
3
1A1
1Y1
DECODER
1Y2
1Y3
1
2A 0
2Y 1
11
13
2A 1
2Y 2
10
2Y 3
9
14
13
4
5
6
7
1E
2Y0
14
2E
1Ao
1Ao
2A1
2Y1
DECODER
2Y2
2Y3
12
11
10
9
15
SV00531
15
2E
SV00534
LOGIC SYMBOL (IEEE/IEC)
DX
2
1
G ––
3
1
DX
14
G ––
3
13
1
15
1
5
2
6
3
7
1
11
2
10
3
9
(a)
X/Y
2
1
3
2
1
EN
X/Y
14
1
13
2
15
EN
1
5
2
6
3
7
1
11
2
10
3
9
(b)
SV00532
FUNCTION TABLE
INPUTS
OUTPUTS
nE
nA0
nA1
nY0
nY1
nY2
nY3
H
X
X
H
H
H
H
L
L
L
L
H
H
H
L
H
L
H
L
H
H
L
L
H
H
H
L
H
L
H
H
H
H
H
L
NOTES:
H = HIGH voltage level
L = LOW voltage level
X = don’t care
1998 Apr 28
3
74LVC139
RECOMMENDED OPERATING CONDITIONS
SYMBOL
VCC
PARAMETER
CONDITIONS
LIMITS
MIN
MAX
DC supply voltage (for max. speed performance)
2.7
3.6
DC supply voltage (for low-voltage applications)
1.2
3.6
UNIT
V
VI
DC input voltage range
VO
DC output voltage range
VCC
V
–40
+85
°C
ns/V
Tamb
Operating free-air temperature range in free air
tr, tf
Input rise and fall times
VCC = 1.2 to 2.7V
VCC = 2.7 to 3.6V
V
ABSOLUTE MAXIMUM RATINGS1
In accordance with the Absolute Maximum Rating System (IEC 134).
Voltages are referenced to GND (ground = 0V).
SYMBOL
VCC
PARAMETER
CONDITIONS
DC supply voltage
RATING
UNIT
–0.5 to +6.5
V
IIK
DC input diode current
VI t 0
–50
mA
VI
DC input voltage
Note 2
–0.5 to +5.5
V
IOK
DC output diode current
VO uVCC or VO t 0
"50
mA
VO
DC output voltage
Note 2
IO
DC output source or sink current
VO = 0 to VCC
IGND, ICC
Tstg
PTOT
DC VCC or GND current
Storage temperature range
Power dissipation per package
– plastic mini-pack (SO)
– plastic shrink mini-pack (SSOP and TSSOP)
above +70°C derate linearly with 8 mW/K
above +60°C derate linearly with 5.5 mW/K
–0.5 to VCC +0.5
V
"50
mA
"100
mA
–65 to +150
°C
500
500
mW
NOTES:
1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the
device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability.
2. The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
1998 Apr 28
4
74LVC139
DC ELECTRICAL CHARACTERISTICS
Over recommended operating conditions. Voltages are referenced to GND (ground = 0V)
LIMITS
SYMBOL
PARAMETER
TEST CONDITIONS
Temp = -40°C to +85°C
TYP1
MIN
VIH
HIGH level input voltage
VIL
LOW level input voltage
VOH
O
VOL
II
ICC
∆ICC
VCC = 1.2V
VCC
VCC = 2.7 to 3.6V
2.0
V
VCC = 1.2V
GND
V
VCC = 2.7 to 3.6V
HIGH level output voltage
LOW level output voltage
UNIT
MAX
0.8
VCC = 2.7V; VI = VIH or VIL; IO = –12mA
VCC*0.5
VCC = 3.0V; VI = VIH or VIL; IO = –100µA
VCC*0.2
VCC = 3.0V; VI = VIH or VIL; IO = –12mA
VCC*0.6
VCC = 3.0V; VI = VIH or VIL; IO = –24mA
VCC*0.8
VCC
V
VCC = 2.7V; VI = VIH or VIL; IO = 12mA
0.40
VCC = 3.0V; VI = VIH or VIL; IO = 100µA
0.20
VCC = 3.0V; VI = VIH or VIL; IO = 24mA
0.55
Input leakage current
VCC = 3
3.6V;
6V; VI = 5
5.5V
5V or GND
Quiescent supply current
VCC = 3.6V; VI = VCC or GND; IO = 0
Additional quiescent supply current per
input pin
VCC = 2.7V to 3.6V; VI = VCC –0.6V; IO = 0
V
"0 1
"0.1
"5
µA
0.1
10
µA
5
500
µA
NOTE:
1. All typical values are at VCC = 3.3V and Tamb = 25°C.
AC CHARACTERISTICS
GND = 0 V; tr = tf v 2.5 ns; CL = 50 pF; RL = 500; Tamb = –40C to +85C
LIMITS
SYMBOL
PARAMETER
VCC = 3.3V ±0.3V
WAVEFORM
VCC = 2.7V
MIN
TYP1
MAX
MIN
UNIT
MAX
tPHL/tPLH
Propagation delay
nAn to Yn
1, 3
1.5
3.3
6.0
7.5
ns
tPHL/tPLH
Propagation delay
nE to Yn
2, 3
1.5
3.2
5.5
6.5
ns
NOTE:
1. These typical values are at VCC = 3.3V and Tamb = 25°C.
1998 Apr 28
5
74LVC139
AC WAVEFORMS
TEST CIRCUIT
VM = 1.5 V at VCC 2.7 V
VM = 0.5 × VCC at VCC < 2.7 V
VOL and VOH are the typical output voltage drop that occur with the
output load.
S1
VCC
2 * VCC
Open
GND
500Ω
VI
VO
VI
E INPUT
PULSE
GENERATOR
VM
D.U.T.
50pF
RT
GND
t PHL
CL
500Ω
t PLH
V OH
nY OUTPUTS
SWITCH POSITION
VM
TEST
S1
VCC
VI
V OL
tPLH/tPHL
SV00561
Figure 1. Input (nA) to output (nY) propagation delays.
Open
< 2.7V
VCC
2.7–3.6V
2.7V
SV00903
Figure 3. Load circuitry for switching times.
VI
nI0, nI1, S
INPUTS
VM
GND
t PHL
t PLH
V OH
nY OUTPUT
VM
V OL
SV00562
Figure 2. Enable input (nE) to output (nYn) propagation delays.
1998 Apr 28
6
74LVC139
SO16: plastic small outline package; 16 leads; body width 3.9 mm
1998 Apr 28
7
SOT109-1
74LVC139
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
1998 Apr 28
8
SOT338-1
74LVC139
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
1998 Apr 28
9
SOT403-1
74LVC139
DEFINITIONS
Data Sheet Identification
Product Status
Definition
Objective Specification
Formative or in Design
This data sheet contains the design target or goal specifications for product development. Specifications
may change in any manner without notice.
Preliminary Specification
Preproduction Product
This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips
Semiconductors reserves the right to make changes at any time without notice in order to improve design
and supply the best possible product.
Product Specification
Full Production
This data sheet contains Final Specifications. Philips Semiconductors reserves the right to make changes
at any time without notice, in order to improve design and supply the best possible product.
Philips Semiconductors and Philips Electronics North America Corporation reserve the right to make changes, without notice, in the products,
including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips
Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright,
or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask
work right infringement, unless otherwise specified. Applications that are described herein for any of these products are for illustrative purposes
only. Philips Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing
or modification.
LIFE SUPPORT APPLICATIONS
Philips Semiconductors and Philips Electronics North America Corporation Products are not designed for use in life support appliances, devices,
or systems where malfunction of a Philips Semiconductors and Philips Electronics North America Corporation Product can reasonably be expected
to result in a personal injury. Philips Semiconductors and Philips Electronics North America Corporation customers using or selling Philips
Semiconductors and Philips Electronics North America Corporation Products for use in such applications do so at their own risk and agree to fully
indemnify Philips Semiconductors and Philips Electronics North America Corporation for any damages resulting from such improper use or sale.
Copyright Philips Electronics North America Corporation 1998
All rights reserved. Printed in U.S.A.
811 East Arques Avenue
P.O. Box 3409
Sunnyvale, California 94088–3409
Telephone 800-234-7381
print code
Document order number:
yyyy mmm dd
10
Date of release: 05-96
9397-750-04494
很抱歉,暂时无法提供与“74LVC139PW”相匹配的价格&库存,您可以联系我们找货
