OB2269
Description
CR
MI
JS
The OB2269 is a highly integrated currentmode
PWM controller IC for those high output
power of off line flyback convertor. The output
power is up to 120W.
OB2269 is integrated start-up circuit that
realizes low quiescent dissipation and overload
compensation.
OB2269 has comprehenisve protecit onf eature
to ensure reliability of application system.
The packaging of OB2269 has SOP8 and DIP8.
Features
Applications
Digital Cameras Charger
Power adaptor
Battery charger
r
to
uc
d
on
ic
m
Se
O
Digit frequency shuffling technology to
improve EMI performance.
External programmable PWM switching
frequency.
Leading edge Blanking on current sense
input.
Internal synchronized slope
compensation .
Burst mode control to improve efficiency
and optimize standby power consumption.
Low start-up current and low operating
current.
Comprehensive protection functions
1 、 Under voltage locked with
hysteresis (UVLO) on VDD
2、Over voltage protection (OVP) on
VDD.
3、Cycle-by-Cycle current limitation
4、Over load protection (OLP)
5、Over temperature protection
(OTP)
Current limitation compensation to
obtain the same output current in
universal AC line input.
800mA Drive Capability
www.jsmsemi.com
第1/11页
OB2269
Application Circuit
O
CR
MI
JS
Pin Assignment & Marking Information
r
to
uc
d
on
ic
m
Se
2269CP
www.jsmsemi.com
第2/11页
OB2269
Ordering Information
Part number
OB2269
OB2269
Package
SOP-8
DIP-8
Pin Description
1
2
3
4
Type
Description
GND
P
Ground.
FB
I
Feedback input pin.
VIN
I
Start-up and overload compensation current input pin
RI
I/O
Internal oscillator frequency setting pin.
RT
I/O
Temperature sensing input pin,connected through a NTC
O
5
Symbol
CR
MI
JS
Pin Number
resistor to GND.
I
7
VDD
P
8
GATE
O
Current sense input pin.
Chip DC power supply pin.
Totem-pole gate diver.
Recommended Out Power
Product
OB2269
Input:230VAC±15%
Adapter
120W
www.jsmsemi.com
Input:85-264VAC
r
to
uc
d
on
ic
SENSE
m
Se
6
Adapter
90W
第3/11页
OB2269
Block Diagram
O
CR
MI
JS
Value
Unit
30
V
32
V
10
mA
-0.3 to 7
V
VDD/VIN Input voltage
VDD clamp voltage
VDD clamp continuous current
FB input voltage
r
to
uc
d
on
ic
Parameter
m
Se
Absolute Maximum Rating
SENSE input voltage
-0.3 to 7
V
RT input voltage
-0.3 to 7
RI input voltage
-0.3 to 7
Operating ambient temperature
-20 to 85
Min/Max operating junction temperature
-55 to 150
V
V
Thermal resistance,Junction to ambient SOP8
150
℃/W
Thermal resistance,Junction to ambient DIP8
100
℃/W
Note: Stresses above absolute maximum ratings may cause permanents damage to the device.
Exposure to absolutely maximum-rated conditions for extended periods may affects device
reliability
www.jsmsemi.com
第4/11页
OB2269
Recommended Operating Conditions
Symbol
VDD
TA
Parameter
Supply Voltage
Operating Ambient Temperature
Min.
8
-20
Max.
25
85
Unit
V
ESD Information
Symbol
HBM
Test Conditions
CR
MI
JS
MM
Parameter
Human body model
on all pins
Machine model on
all pins
Min.
Typ.
Max.
Unit
JEDEC-STD
3
KV
JEDEC-STD
250
V
Electrical Characteristics (TA = 25 ℃ without special notation )
Symbol
Parameter
O
Supply Voltage (VDD Pin)
Idd_start-up VDD start-up current
VDD operating current
UVLO
(enter)
VDD under voltage lockout
enter
exit
VDD over voltage
protection enter
VDD clamp voltage
VDD_clamp
Voltage Feedback (FB Pin)
AVCS
PWM input gain
VFB_open open loop voltage
Idd = 10mA
ΔVFB / ΔVSENSE
Burst mode voltage
6
10
2.3
uA
mA
8.5
9
10
V
14.5
15
16
V
25.5
26.5
27.5
V
29
30
31
V
2.8
5.8
V/V
V
1.1
V
r
to
uc
VFB_burst
d
on
ic
OVP(enter)
VDD=12.5V, RI=24K
VDD=18V, RI=24K ,
FB=3.6V
m
Se
Idd
UVLO(exit)
Value
Unit
Min. Typ. Max
Conditions
IFB_short
FB pin short current
Short FB pin to GND and
measure current
780
uA
VTH_PL
Power limiting FB
threshold voltage
Iout =-10mA
3.7
V
TD_PL
Power limiting delay time
Current Sense(CS Pin)
Leading-edge blanking
T_blanking
time
ZSENSE_IN Input impedance
Current limitation threshold
VTH
voltage
Oscillator(RI Pin)
80
I(VIN)= 0 uA
www.jsmsemi.com
mS
250
nS
30
K
0.85
V
第5/11页
OB2269
Normal oscillation
frequency
Frequency temperature
stability
Fosc
Δf_temp
Δf_VDD
Frequency voltage stability
RI_range
Operating resistor range
VRI
Voltage of RI to GND
Fosc_BM
Burst mode base frequency
DC_MAX
Maximum duty cycle
VOH
V_Clamp
T_f
12
65
Output low level
VDD=18V, IO=-20mA
Output high level
VDD=18V, IO=20mA
output clamp voltage level
70
Khz
2
2
24
60
K
2
V
25
Khz
80
-5
+5
0.3
V
11
V
16
V
Output rising time
VDD=18V, CL=1nF
110
nS
Output falling time
VDD=18V, CL=1nF
40
nS
O
T_r
TA -20℃ to 100℃
VDD=16V, RI=24K
VDD=12V to 25V
RI=24K
VDD=18V, FB=3V
SENSE=0V
CR
MI
JS
VOL
60
RI=24K
Frequency modulation
range /Base frequency
Gate Drive Output(GATE Pin)
Δf_OSC
RI=24K
m
Se
Over Temperature Protection (RT pin)
Output current of RT pin
70
uA
V_OTP
OTP threshold voltage
OTP recovery threshold
voltage
OTP delay time
0.65
V
0.8
V
100
uS
2
mS
V_OTP_off
T_OTP
Start up and Current limitation compensation (VIN pin)
Current limitation
G_VIN
ΔIVIN/ΔVCS
compensation gain
www.jsmsemi.com
r
to
uc
d
on
ic
I_RT
第6/11页
OB2269
Application Information
The OB2269 is a highly integrated current mode PWM controller IC for those high output power
of off line flyback convertor. The output power is up to 120W. Its main features are optimized for
OB2269 in driving capability, quiescent dissipation, current limitation compensation and low cost
and reliability.
Start-up Current and Start-up Control
OB2269 has very low start-up current that is less than 10uA. Therefore, the voltage of VDD could be
CR
MI
JS
charged up above UVLO(exit ) threshold level quickly. A large value resistor can be used in the
start-up circuit to minimize quiescent dissipation. The typical resistance value of resistor is 2M
Ohms in start-up circuit of OB2269 The start-up resistor can be connected with the VIN pin or the
capacitor of VDD to provide start-up current.
O
Operating Current
m
Se
The Operating current of OB2269 is less than 2.3mA. Therefore, OB2269 can have good efficiency.
Frequency shuffling for EMI improvement
Burst Mode Operation
d
on
ic
The frequency Shuffling is implemented in OB2269 The oscillation frequency is modulated with a
random source so that the harmonic energy is spread out. The spread spectrum minimizes the
conduction EMI and therefore reduces system design challenge.
r
to
uc
At zero load or light load condition, the main power dissipation in a switching mode power supply
is from switching on the MOSFET, the core of transformer and the snubber circuit. The magnitude
of power dissipation is proportional to the number of switching frequency within certain period.
Less switching frequency can reduce the power dissipation.OB2269 adjusts the switching frequency
according to the loading condition. From light load to no load, the FB voltage drops. While the FB
voltage is less than 1.1V, the gate pin output is disabled and kept low, while the FB voltage is higher
than 1.2V, the gate output recovers to normal working mode. To reduce audio noise, the switching
frequency will be kept higher than 20KHz in burst mode.
Oscillator Operation
The oscillating frequency of OB2269 is set by the externally resistor between the RI pin and the
GND pin. It is recommended that the range of oscillation frequency is in between 20KHz and
www.jsmsemi.com
第7/11页
OB2269
100KHz. The relationship between the resistor and the oscillation frequency follows below
equation.
Fosc
1625
(KHz)
RI (K) 1
Current Sensing and Leading-Edge Blanking
Cycle-by-Cycle current limitation is offered in OB2269. The switching current is detected by a
resistor into the SENSE pin. An internal leading-edge blanking circuit chops off the SENSE voltage
spike at initial so that the external RC filtering on SENSE pin is no longer required. The current
CR
MI
JS
limiting comparator is disabled and thus cannot turn off the external MOSFET during the blanking
period. PWM duty cycle is determined by the voltage in the SENSE pin and the FB pin
Internal Synchronized Slope Compensation
Built-in slope compensation circuit adds voltage ramp onto the current sense input voltage for
O
PWM generation. This greatly improves the close loop stability at CCM and prevents the
m
Se
sub-harmonic oscillation and thus reduces the output ripple voltage.
d
on
ic
OB2269 is specially optimized for the high output power system. If the temperature from the
environment or the component is too high, it results in the system damage.OB2269 provides the
function of temperature sensing and the function of over temperature protection. The voltage on the
RT pin is determined by resistor between the RT pin and the GND pin. The resistor is usually a
r
to
uc
NTC resistor. With the Fixed internal current flowing through the resistor, the voltage on the RT pin
varies with the resistance value of NTC resistor. When the voltage on the RT pin is less than 0.65V,
OB2269 is shut down and recovers when the voltage on the RT pin is higher than 0.8V.
Gate Drive
OB2269 Gate pin is used to drive Gate of the external MOSFET. OB2269 has 800mA of sinking
and sourcing current that can minimize the switching dissipation of the MOSFET. Therefore, higher
efficiency can be obtained. The internally totem pole circuit of the GATE pin can control the
MOSFET to be turned on slowly and turned off faster. There is very good compromise between
high efficiency and low radiation EMI.
www.jsmsemi.com
第8/11页
OB2269
Protection Controls
OB2269 has comprehensive protection functions, including Cycle-by- Cycle current limitation
(OCP), Over Load Protection (OLP) and over voltage clamp, Under Voltage Lockout on VDD
(UVLO), Over Temperature Protection (OTP).
O
CR
MI
JS
To obtain the same output current capability in the universal AC line voltage range, OB2269 has
current limitation compensation. To obtain good current limitation compensation, the start-up
resistor must be connected with the VIN pin.
r
to
uc
d
on
ic
m
Se
www.jsmsemi.com
第9/11页
OB2269
Package Information:
SOP-8
O
CR
MI
JS
r
to
uc
d
on
ic
m
Se
www.jsmsemi.com
第10/11页
OB2269
DIP-8
O
CR
MI
JS
r
to
uc
d
on
ic
m
Se
www.jsmsemi.com
第11/11页
很抱歉,暂时无法提供与“OB2269”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.82342
- 50+0.72136
- 150+0.67762
- 500+0.62306
- 2500+0.54374
- 5000+0.52916
