HSS3407A
P-Ch 30V Fast Switching MOSFETs
Product Summary
Description
VDS
-30
V
ch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
RDS(ON),max
70
mΩ
and load switch applications.
ID
-3.1
A
The HSS3407A is the high cell density trenched P-
The HSS3407A meet the RoHS and Green Product
requirement, with full function reliability approved.
l
l
l
l
SOT23s Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Rating
Symbol
Parameter
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
ID@TA=25℃
ID@TA=70℃
IDM
10s
Steady State
Units
-30
V
±20
V
Continuous Drain Current, VGS @ -10V
1
-3.7
-3.1
A
1
-3.0
-2.6
A
Pulsed Drain Current
2
-15
A
Total Power Dissipation
3
1.32
PD@TA=70℃
3
0.84
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
PD@TA=25℃
1
W
0.64
W
Thermal Data
Symbol
RθJA
RθJA
RθJC
www.hs-semi.cn
Parameter
Thermal Resistance Junction-Ambient
1
1
Thermal Resistance Junction-Ambient (t ≤10s)
Thermal Resistance Junction-Case
Ver 2.0
1
Typ.
Max.
Unit
125
℃/W
95
℃/W
80
℃/W
1
HSS3407A
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
2
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
Reference to 25℃ , ID=-1mA
-0.023
V/℃
VGS=-10V , ID=-3A
56
70
VGS=-4.5V , ID=-2A
73
95
-1.2
-1.6
-3
V
4
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
11
S
Qg
Total Gate Charge (-4.5V)
6.4
9.0
Qgs
Gate-Source Charge
2.3
3.2
Qgd
Gate-Drain Charge
1.9
2.7
Td(on)
VDS=-15V , VGS=-4.5V , ID=-3A
nC
2.8
5.6
Rise Time
VDD=-15V , VGS=-10V , RG=3.3Ω,
8.4
15.1
Turn-Off Delay Time
ID=-3A
39
78.0
Fall Time
6
12.0
Ciss
Input Capacitance
583
816
Coss
Output Capacitance
100
140
Crss
Reverse Transfer Capacitance
80
112
Min.
Typ.
Max.
Unit
-3.1
A
-15
A
-1
V
7.8
nS
2.5
nC
Tr
Td(off)
Tf
Turn-On Delay Time
uA
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
Parameter
Continuous Source Current
Pulsed Source Current
2,4
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Conditions
1,4
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
IF=-3A , dI/dt=100A/µs , TJ=25℃
Note :
2
1.The data tested by surface mounted on a 1 inch FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSS3407A
Typical Characteristics
165
ID=-3A
RDSON (mΩ)
135
105
75
45
2
4
6
-VGS (V)
8
10
Fig.2 On-Resistance v.s Gate-Source
Fig.1 Typical Output Characteristics
-IS -Source Current(A)
10
8
6
TJ=150℃
TJ=25℃
4
2
0.4
0.6
0.8
1
-VSD , Source-to-Drain Voltage (V)
Fig.3 Forward Characteristics of Reverse
Fig.4 Gate-Charge Characteristics
1.8
Normalized on resistance
Normalized -VGS(th)
1.5
1.0
0.5
1.4
1.0
0.6
0.2
0.0
-50
100
TJ ,Junction Temperature (℃)
150
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
-50
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized R DSON vs TJ
Ver 2.0
3
HSS3407A
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TC + PDM x RθJC
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.0
4
HSS3407A
Ordering Information
Part Number
HSS3407A
www.hs-semi.cn
Package code
SOT-23
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSS3407A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.29077
- 100+0.23634
- 300+0.20912
